Author Topic: Dual Build: Roden 1/32nd Albatros DIII (OAW): Jasta 10, WNW ALbatrosDV: Jasta11  (Read 155815 times)
This'll bring it all together Rick. Looking very good so far. Best of luck as you continue!  8)
Thanks for the kind comments!
Your standard work, which means excellent, dear friend! ;)
Ondra
Thanks for dropping by and commenting. I appreciate your continued support of my builds!
The major rigging is complete. Now for the finishing touches:
Paint the cockpit leather pad, Paint the Tailskid, Touch up a myriad of glitches, add the windscreen, add the small pipe to Bos radiator, add the water pipe, do the control surface rigging,add the under wing crosses, etc.
Next photos should be in the completed section.  ;D
guitarlute101
Great work Rick!
Wow Rick, another beauty.  Looks great.
Great work Rick!
Thanks for the comment! Greatly appreciated.
Thanks Juan!
I couldn't resist adding this one.
Rick that really does look the part. Funny isn't it how all those final touches seem to take so long... so near to completion but not quite yet!
Offline Trackpad
What they all said, Rick: beautiful work. Congratulations! Best of luck as you bring her into land once the final bits and bobs are addressed.  8)
Cheers!
Thanks Stephen. Should only be a couple of days now....providing I have NO Setbacks  ::)
Thanks Gary. Greatly appreciated seeing how beautifully your DV is turning out!
Truly magnificent work, Amigo!  Not only are you the King of Stripey Aircraft, but also the Albatros King!  With each one you build, you're drawing me closer to building one of my own.
She's looking sweet, Rick!  And I'm still learning on what-to-do-when from this build.
Gaz
Thanks Amigo. Your very generous comments are always appreciated As fo Albatros King, I think I will leave that one to Bo or Bertl  ;D
Gaz
Thanks Gaz. My order of doing things is most often dictated by 2 factors:
1. Stuff I will knock off is added last
2: Stuff I forgot to do is even later  ;D
« Last Edit: July 17, 2018, 12:49:31 AM by RAGIII »
Well, yeah...  But, among us common mortals, you hold the crown.  ;)
Going on that theme Bo and Bertl are the Gods. Yourself and some others are Demi Gods, I am certainly in the Mere Mortal category  ;D That being said I forgot to comment on your inspiration to do an Albie in 1/32nd. Go for it. Having seen what you did in 1/48th I would be thrilled to see a DV done to your standards!!!!
SO the Albatros DV is finished: Photos here:
https://forum.ww1aircraftmodels.com/index.php?topic=9701.0
Thanks for all of the support. More on the DIII in a few days
« Last Edit: July 18, 2018, 05:59:42 AM by RAGIII »
