Author Topic: Mikr Mir Fokker E.V / D.VIII  (Read 59795 times)
Re: Mikr Mir Fokker E.V / D.VIII
« Reply #75 on: July 10, 2017, 11:23:01 PM »
Thanks for the vote of confidence Guy! I'm a little unsure of my results on this one, and when you see the forthcoming photos of the wing streaking you'll probably understand why! :-[ :o
« Reply #76 on: July 11, 2017, 12:13:03 AM »
   After considerable thought and review of a great deal of commentary and speculation concerning the finish on E.V / D.VIII wings and yet more staring at Reference photos my mind is made up; I agree with Bughunter's (Frank) interpretation, green and purple uppers and light blue lowers as used on many previous German aircraft of the period.
   Here's my results; After spraying the upper surface with a Tamiya "wood base" equal parts mix of White, Desert Yellow, and Deck Tan the streaking is (all enamels) Humbrol (a concocted purple using  a mix of their #68 and an at least 25 year old tin of their HG 9 "German Purple (about 60/40 respectively) and Model Master Dark Green # 1710. I am really unsure of the results here, I know it was roughly applied but is this example too "sloppy"?? I am very open to comments, opinions, and recommendations on this.
   First, the cowling which is finally painted and ready to install: (C/W newer thumb prints on the future coat over the lozenge :( :-\ )
........... and here's several shots of the wing upper finish:
    Hoping for some constructive  feedback, I am not adverse to doing a paint removal/clean up and going back to the drawing board however the colour choice is not negotiable!
« Last Edit: July 11, 2017, 12:39:22 AM by lcarroll »
Online RAGIII
« Reply #77 on: July 11, 2017, 12:14:32 AM »
Lance,
 I am sure you will get a better result than most in spite of your doubts! As an aside, I just got my invoice from Pheon so I should get back to my EV in a week or so. I plan on taking full advantage of the jigs provided with the decals!
« Reply #78 on: July 11, 2017, 12:35:07 AM »
Rick,
    Great news from Pheon; I just sent payment as well! At my present rate of progress the decals should arrive just in time, even if I go back to "square one" on the wing finish.
Online RAGIII
« Reply #79 on: July 11, 2017, 12:54:20 AM »
Rick,
By the way I think you were posting the wing photos as I posted my previous reply  ::) I think your wing looks fine. I am still not sure about the combination of colors but that is your call and is pretty much open to any opinion as we discussed. I will repeat my only doubt as I said earlier. The amount for the 4 stains listed was "Just Enough" to cover the wings when used on the exterior so I wonder how an unmixed lower blue and an interior brown was used. That being said we still do not know for sure the wing wasn't green  :o In the end I like your results!!
« Reply #80 on: July 11, 2017, 05:24:11 AM »
Oh Lance, thank you!
I think last time I forgot to mention one other fact. There are four colors on the famous Fokkers parts list, but the brown was mentioned on a different place, I was told. So that is another fact which points to a usage of the brown stain inside the wing to improve the water resistance.
Back to you model:
I think, that your green streaking is a bit better, more vital, alive. But this may depend also by light and pictures. I'm sure it will look great in real, you are able to manage this issue.
« Reply #81 on: July 11, 2017, 06:01:17 AM »
Thanks Frank, I've since gone back to work more on the streaking and removed some of the heavier areas. It's toned it down a lot and given the wing a slightly lighter coloured appearance. I'll try some photos in natural light today and post them as a further update.
« Reply #82 on: July 11, 2017, 07:01:40 AM »
   Here's the photos of the reworked streaking, I'm much happier with it now.
   I also added the stacking bumps to the leading edge.
« Last Edit: July 11, 2017, 07:18:47 AM by lcarroll »
Offline xmald
« Reply #83 on: July 11, 2017, 07:06:20 AM »
The corrected version of the streaking is even better Lance. I think you`ve achieved a very convincing result, also similar to what I remember from DSA`s samples presented at the Aerodrome. Good job!
The decals are simply beautiful Lance. I would give the cowling (you probably will) a shinier look though.
The E.V is still one of my all time favourites!
Best regards
Filip
« Reply #84 on: July 11, 2017, 07:21:45 AM »
   Thanks Filip, I was fooling around with Imgur when you posted, still have a way to go to get comfortable with it's nuances! I will be doing the cowling in a much shinier semi gloss finish once installed.
« Reply #85 on: July 12, 2017, 03:35:29 AM »
Yes, you can, Lance!
« Reply #86 on: July 12, 2017, 03:41:09 AM »
Looking great Lance    :D
« Reply #87 on: July 12, 2017, 03:50:52 AM »
Frank, Juan,
    Thanks for looking and for your comments. Now for the lower surface blue and a coat or two of Future for decals. :)
« Reply #88 on: July 12, 2017, 06:44:45 AM »
Nice job Lance! I don't know much about Razor wings but yours looks pretty darned good. I'm intrigued by your Wood Base mix too - will have to try that sometime.
« Reply #89 on: July 12, 2017, 07:25:31 AM »
Coming along splendidly Lance, the wing turned out looking excellent, really nice colours and very nice streaking.
