Author Topic: Avis/ Mikro Mir 1/32nd scale Fokker EV Jasta 6.  (Read 131169 times)
Re: Avis 1/32nd scale Fokker EV Jasta 6.
« Reply #210 on: September 23, 2017, 12:44:23 AM »
Rick,
    You are certainly doing your "homework" on this Build and it's looking very nice as well. I noticed the photo of the "patch" in the Data File after I finished mine, I'll leave it as is to represent the aircraft before the extra access panel was installed!
   Great work so far and looking forward to seeing how you paint/shade that wing.
« Reply #211 on: September 23, 2017, 05:50:23 AM »
Rick,
Thanks Lance. I also saw the photo first in the Data File. When I found the photo on a Fokker EV image site I figured it was worth posting. I figure this will be the only one I build for a while so I am trying to get it correct.
« Reply #212 on: September 23, 2017, 11:54:31 PM »
I finally got up the nerve to assemble the jig. This proved to be easier than I had feared  ;D That being said I have run into an issue. As most know I had progressed rather far along in my build when the decals and jig were released. The jig is designed for use without the tail plane attached. Mine is solidly glued into position! The result is that the fuselage doesn't rest as it should into D. As I see things I have two choices.
1. Remove the tail plane and use the jig as designed. This could result in damage to the paint and decals on the tail.
2. Try to adjust the height of jig part D to allow for the tail plane.
Any suggestions are appreciated!
Just to be certain all understand this is in no way a problem with the jig!!
« Last Edit: April 14, 2018, 08:35:10 AM by RAGIII »
Offline rowan broadbent
« Reply #213 on: September 24, 2017, 12:30:04 AM »
Rick, you've got a couple of options, I'd say:
1 Remove the rear cradle support, measure the distance between the tailplane and the base plate and add a new support or
2 Remove the rear cradle and tape the fuselage to the baseplate to hold it in place.
On balance, I'd go with option 1!
Love the colours on the underside - just as I'd expect to see them.
Rowan
Forget your perfect offering
Leonard Cohen
« Reply #214 on: September 24, 2017, 01:25:26 AM »
Rowan
Thanks for the quick response Rowan! If I am reading your suggestion correctly:
I am going to remove support D allowing the fuselage to drop into proper place on C. I will then measure the distance from the fuselage to base and replace D with a new support cut to the proper height?
« Reply #215 on: September 30, 2017, 10:22:26 AM »
I have repainted the Wing. I decided to go with the conjectural pattern on Rowans/Pheons decal sheet instructions. I used Tamiya sand and then Polyscale Acrylics for the Green, Violet, Brown, and blue. I am happy with my results.
DSCF6680 by Rick Geisler, on Flickr
DSCF6690 by Rick Geisler, on Flickr
DSCF6699 by Rick Geisler, on Flickr
« Last Edit: October 27, 2017, 12:44:51 AM by RAGIII »
« Reply #216 on: October 01, 2017, 06:34:37 AM »
I have progressed on this one since this morning. I have added the wing crosses, Fuselage serial numbers, and the black stripe behind the cowling. I also realized that after mixing a little AT&SF blue to the polyscale Mauve that I had put it aside and used the straight from the bottle paint on the underside. I went back and streaked some of the more lilac mixture over the Mauve. I also added the inspection panel to the left side of the fuselage.
« Last Edit: July 11, 2019, 12:13:53 AM by RAGIII »
« Reply #217 on: October 01, 2017, 06:46:49 AM »
Wow Rick, your wings are sublime.  Pure work of art.  Looking forward to your progress on this beauty.   :D
« Reply #218 on: October 01, 2017, 08:19:07 AM »
Tip top work, Rick  ;)
Always a pleasure to scope out your builds  ;)
vB
« Reply #219 on: October 02, 2017, 02:58:13 AM »
Thanks for the kind comments Juan!
vB
Thanks for dropping by and the generous comment von B!
Offline xmald
« Reply #220 on: October 02, 2017, 03:31:45 AM »
Top notch Rick!
Best regards
Filip
« Reply #221 on: October 02, 2017, 08:09:06 AM »
Top notch Rick!
Thanks for dropping in and commenting Filip!
« Reply #222 on: October 02, 2017, 11:16:21 AM »
Really good looking bird coming together!!
« Reply #223 on: October 03, 2017, 12:10:23 AM »
Thanks for commenting Steve! Greatly appreciated.
« Reply #224 on: October 05, 2017, 03:08:53 AM »
Looking good, not much longer Amigo !
