Author Topic: Hobby Craft Sopwith Camel  (Read 42768 times)
Re: Hobby Craft Sopwith Camel
« Reply #135 on: November 30, 2015, 07:17:31 PM »
Excellent, Tug! I know this isn't the Wingnuts kit of course, but when I build my Wingnuts Camel I'm going to use your model as a guide!
George
+1  ;)
vB
« Reply #136 on: December 01, 2015, 02:05:09 AM »
Tug,
Brilliant is the term ! I may have already used it but it is well deserved! You are one Modeler that will have NO Use for a WNW Camel  8)
Offline Suffolk Lad
« Reply #137 on: December 09, 2015, 09:33:44 AM »
Des - thanks for the kind words of appreciation on the woodwork but I think it more beginners luck than anything as it's the first time I've done anything like it. You'll have to put it down to some good tutorials I've followed :)
Martin, George, Von B and RAG - thanks as always for your comments too - glad to see you are still following  :)
Not much to report tonight but I have got the guns mounted at last with the cocking levers mounted the right way up this time  ::) Also found enough time to get another little phase out of the way in getting the undercarriage mounted and rigged. I think I may have over done the early weathering a tad but hopefully it will all meld in once on it's base
First up was to paint the underside to finish. I tried, not that successfully, to mask the lines using stretched Teflon tubing (ex CA tubing) but it kept sliding back so I will remove the over-spray on the lines later with some thinners and repaint the lines. The underneath had a thin flash of Life Colour Tensochrome 'Oil Stains' dusted over to begin the weathering process underneath
A couple of pieces of balsa made for a simple jig to keep the wings level to sight the U/C parallel and this was fixed in place using Gator Glue. The small locating pegs on the ends of the legs had been pre-drilled and copper wire pins inserted to help reinforce the joins. Once in position the legs were (just) restricted from movement using masking tape.
The wires were then positioned and held with CA, reinforced with a tiny application of Gator glue and the bungees simulated with some fine tan coloured thread run through some Vallejo 'grey white'  between finger and thumb.
Quite some time was spent trying to weather the wheels with pigments. They don't look in keeping at the moment and I have to say I'm not that happy with them but hopefully, as said, once on the base it will all come together.
And finally it's on it's wheels. The wings are just off level by slightly less than a mm tip to tip which all things considered I was quite pleased with. Final leveling can be tweaked once on the base. The small green blobs inside the cowling vents are Miliput. This was needed to give the U/C some support. These will get painted later and won't be too obvious once the engine and cowl are on.
That's it as of tonight - it's been a 'bitty' week with not much time to get a fair crack at it but even the smallest progress is always a step in the right direction  ;)
Not long now though before that top wing gets tackled
Regards - Tug
« Reply #138 on: December 09, 2015, 09:49:53 AM »
Tug,
You are continuing to do an absolutely amazing job on this kit! Although you obviously don't need one, you have certainly wetted my appetite for the WNW Camel!
« Reply #139 on: December 09, 2015, 09:52:29 AM »
Great work Tug.
Offline Rob
« Reply #140 on: December 09, 2015, 10:41:10 AM »
Great work! That jig really looks like it would be handy. Can't wait to see your next update.
v/r,
Rob
« Reply #141 on: December 09, 2015, 10:56:02 AM »
Been following when I can , very nice work so far  8)
Online lcarroll
« Reply #142 on: December 09, 2015, 12:41:19 PM »
Tug,
   I see the weathering on the wheels as perfect, you've done a marvelous job! I still can't believe what you've achieved with this, at best, mediocre Kit. Nice  work!
« Reply #143 on: December 09, 2015, 01:04:06 PM »
 Tug,
Outstanding painting and weathering skills my old friend.The project to date is absolutely awesome! Well Done.
Lance,
I respectfully disagree about the kit being at best mediocre. The Hobbycraft Camel's (original and two upgraded) are basic yes but they do build up well.In the hands of talented and skilled modeler they transform from a sow's ear to a silk purse.  Just my 2 cents.
Online lcarroll
« Reply #144 on: December 09, 2015, 01:37:25 PM »
Greg,
   No contest! I have both the Clerget and LeRhone versions in my stash however have not built them. Truth is it's the imminent arrival of the Wingnut Wings Camel that's kept them in the Stash! What Tug has done is exactly as you stated; put a lot of effort and talent into a sow's ear to produce a silk purse. No slight of the Kit meant, this is a heck of a nice model in the result.
Tug,
   Again, very nice work!
« Reply #145 on: December 09, 2015, 02:00:23 PM »
havent checked in for a while but this build has really come along nicely.all of your embellishments to upgrade the areas lacking in the kit have made this a real gem. very nice paint work as well, your woodgrain has a very nice tone etc. will be watching this slide into the home stretch.
Offline Pgtaylorart
« Reply #146 on: December 09, 2015, 02:28:00 PM »
Getting better all the time!
George
« Reply #147 on: December 09, 2015, 02:31:50 PM »
This is as good as any other kit being built on the forum, you are doing a superb job with a somewhat iffy kit and turning it into a show stopper.
Offline Suffolk Lad
« Reply #148 on: December 09, 2015, 06:46:04 PM »
Oh but I do RAG I do  :)
'Guys' thanks as always - your continued input and encouragement is so very encouraging and means a lot, truly - much appreciated.
I've just been out to take a look in the fresh light of day and those wheels don't look quite as bad as I thought yesterday.  Running through what's next I can see there's a lot of small preparatory work to do before setting up for the top wing to be installed so I'll get that all done before posting again. That said whilst waiting for glue to set I've been cleaning up some of the parts for the next model (for the French GB) but will finish this before starting that in earnest.
Given the current constant seasonal interruptions however this may be a while but I'll get back as soon as I can.
Again my thanks
Regards - Tug
Online PrzemoL
« Reply #149 on: December 09, 2015, 07:57:12 PM »
Great progress, Tug, on your Camel. It is going to be a masterpiece.
