Author Topic: Hobby Craft Sopwith Camel  (Read 43080 times)
Re: Hobby Craft Sopwith Camel
« Reply #105 on: November 06, 2015, 10:37:51 AM »
Great stuff Tug. I like what you did to represent those inspection panel fasteners.
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #106 on: November 06, 2015, 07:29:12 PM »
Now this is an excellent build! I have been skipping it so far, because I don't really like the subject (a boring Camel), but now when I have looked it, I admit, that it was a mistake and yours definately looks beautiful.
The woodgrain is awesome, the sienna seems to work perfectly for the warm reddish hue:) The wings looks excellent, I'm going for a very similar technique on the Fe.2b and hopefully similar effect. Like Bo said, the idea of the fasteners is great and will be shmalessly using it!
Best regards,
Sasho
Think globally, act locally!
« Reply #107 on: November 07, 2015, 01:35:52 AM »
Outstanding work Tug.
Offline Dave Brewer
« Reply #108 on: November 07, 2015, 10:48:58 AM »
http://www.wickerworks.com.au/wicker-pilot-seat.html
[/quote]
That's some site Des,I'm glad you posted it.They'll be getting a big order when I renovate next year.
Dave.
Offline NickT
« Reply #109 on: November 14, 2015, 02:06:26 AM »
Tug,
thought I'd check out your build after our chat at Telford.
Glad I did, lovely work so far and I can't wait to see how it will turn out.
Nick
Offline Suffolk Lad
« Reply #110 on: November 16, 2015, 06:54:56 AM »
Hi guys - nice to hear from you all as usual. Sasho - nice to see you here and you too Nick. That was good meeting you and Nigel at Telford and putting faces to names. That was a really nice  DVll you've done Nick but that tripe was looking even better to my eyes.
It's been a bit of a week kicking off with a funeral no sooner back from Telford and time wise the week seemed to go downhill from there. That said however there has been some progress ......
First up was to get some seat belts on before fitting the seat. I had bought some HGW fabric ones but after experimenting with the spare material found it extremely difficult to get it to 'mould' around the seat. I didn't want to use CA in case it wicked through the weave and made the material brittle so decided after a while it might be better to make the belts from 2 thou ali foil (ex food container) using the HGW belts as templates by taping them over it and cutting them out through the ali. In combination with the HGW etched parts the result wasn't too bad.
I see elsewhere on Lances SSW build that he mentions the fact that the Macro [lens] accentuates even the smallest default to often disappointingly gigantic proportions - couldn't agree more  ::)
These holes looked so neatly drilled to my eye before I saw the image  :o
The seat support was built from evergreen strip and card and a representation of the fuel selector switch made from plastic rod etc. No attempt was made to 'grain' this as it virtually disappears beneath the seat
Now came the time to begin to fit the internals. A simple holding fixture was knocked up from particle board and balsa - the black tube rotating on a stub of ali bolted to the up right. In hindsight this should have been made sooner as it made a distinct improvement in 'handle-ability'
After quite a bit of very fiddly 'fiddling' the support finally found its home without damaging the cross wires in the frame work
The seat located in the square cut out and went in with ease ... followed by the dashboard which proved even more fiddly than the seat support
But after a bit of patience was exercised plus the odd mumble or too  :D it finally found its position.
The guns were fitted to the top cowling along with the oil filler cap. Also began to degrade the paint surface on the cowl and associated metal parts at this stage - quite a bit of further work on this to come once all together
I had installed the etched cocking levers at this point but on a trial fit to the fuselage realised they'd been installed upside down ::) They were quickly prised off without too much damage to the paintwork or the parts and will be re-fitted later
Final shot is of what I feel is the first major flaw with this kit. The under cowling is clearly meant to fit as shown but leaves the wing protruding well (as viewed) above. Taking a good look at various images of the full size I think this can be got round by installing this under cowl at a slight angle to meet the wing and adding a cover plate that overlaps the wing part but more on this later.
Well that's it for this stage - hope those pics are of interest. It's fast approaching that time of year when time available for modelling gets affected by 'seasonal interference' but I'll try to keep this on track.
Regards for now - Tug
« Reply #111 on: November 16, 2015, 07:02:29 AM »
An excellent progress report Tug. First off, your stand to hold and rotate your model is a very simple but brilliant idea, well done. All the latest work you have done has come up a real treat, the seat belts are excellent, this is turning into a really nice looking model.
« Reply #112 on: November 16, 2015, 10:12:55 AM »
Great update Tug, I echo Des's comments about the "maintenance stand", brilliant! The model itself is simply outstanding, great work and the belts really set off the cockpit.
Really REALLY nice work! 8)
« Reply #113 on: November 16, 2015, 01:35:19 PM »
 Tug,
Outstanding progress my old friend.I'll gladly chime in with Des and Lance on your build fixture,truly an excellent idea. Eagerly looking forward to continued Excellence. Well Done.
Offline Pgtaylorart
« Reply #114 on: November 16, 2015, 02:03:06 PM »
Your Camel is coming together perfectly, Gregory! The stand you made is very ingenious. I love Rotisserie Camel!  ;) ;D
George
Offline NinetythirdLiberator
« Reply #115 on: November 16, 2015, 03:35:43 PM »
I agree with George! Camel on a spit...
Beautiful work.  Learning a lot just lookin!
Dan
« Reply #116 on: November 16, 2015, 11:18:14 PM »
Offline iwik
« Reply #117 on: November 17, 2015, 01:43:28 AM »
Hi y'all!
Excellent. Love every bits.
Iwik
Offline Suffolk Lad
« Reply #118 on: November 17, 2015, 09:27:00 AM »
Des, Lance, Gregory, George, Dan,Martin and Iwik - thanks for looking in.
Hope you are continuing to improve Gregory.
The little 'rotisserie' as George has called it is something I have been doing for quite sometime. (You'll have to forgive the subject matter  ::) )
It followed on from using the white faced particle board and balsa blocks to make bespoke and very accurate jigs for building wings for flying model aircraft.
It was not long after taking up plastic modelling that it found a use here too after I found that constantly handling the fuselages of two models during the painting phase lead to paint de-lamination when masking the fuse markings. I have never found Tamiya paints to suffer with that problem elsewhere except on these two particular occasions. Putting it down to the paint gradually absorbing finger grease which subsequently affected further layers of paint I have no longer experienced this since using a holding fixture.
Balsa is so easily worked with nothing more than a scalpel and sandpaper and it sticks virtually instantly to the WF board with thin CA (I use Zap) providing the balsa surface is flat and even.
This one materialised due to holding problems fitting that seat support but another, fixed version, is on the cards for fitting the top wing and struts. I think this one will be extended vertically to allow rotation when the rigging is attempted.
Hope that's of further interest
regards - Tug
Offline Pgtaylorart
« Reply #119 on: November 17, 2015, 09:35:46 AM »
I'll forgive you for the Crusader because it's so well done. :D It looks great!
(Just don't let it happen again!) ;)
George
