Author Topic: Hobby Craft Sopwith Camel  (Read 42785 times)
Offline zsu234
Re: Hobby Craft Sopwith Camel
« Reply #150 on: December 11, 2015, 05:44:08 AM »
Well
I an lucky Tugs a good friend of mine and l have seen this Camel very close even before he stared building it, and the photos do not do the camel justice .
Offline Doug Mace
« Reply #151 on: December 16, 2015, 11:29:48 AM »
Tug....just curious....if you've mentioned it before on previous pages, it got by me... who and what are your markings for this wonderful creation? Looks like it could be No. 3 Sqn?                 -M
Offline Suffolk Lad
« Reply #152 on: December 17, 2015, 03:06:58 AM »
Good to see you here PrzemoL and you too Paul  :)
Doug - it is indeed from 3 Sqn and is as featured in the Windsock Datafile. I can only find the one image of it plus the profile on the back cover.
I've had a bit of deviation for a couple of days - it's our Norfolk club Xmas bash tonight and a small comp with a bit of a difference - well a big difference actually. One of our members is an extraordinarily talented 'paper modeller' and earlier in the year he suggested we try it for ourselves. Having struggled with the intricacies of folding and gluing I know it's not for me but I have finished a light house. When I see what Adam has produced I can tell you I truly am in awe of his skill with this medium.
But - I have at last managed to get close to getting the top wing on. No it's not on yet  ::) I spent today trying to work out how to get all the struts in position without the whole lot collapsing in the process.
In the end I decided another jig was required and after initial deliberation to only fix and align the cabane struts first. Again balsa was used and the jig quickly assembled with CA. Once the airframe was in position however it very quickly became obvious the wing prevented any visual access to the strut locations. The strut hole positions in the wing were transferred to a piece of clear plastic and the whole thing set up by gentle positioning.
Nothing has been glued on the model as yet - this is just a dry run- but the principle appears to be a viable one. The wing support uprights are fixed in position but the support bars are freely moveable. The clear plastic is stressed in a slight curve which holds the struts quite firmly
With the plastic able to move in three axis the struts prove easy to align to the fuse.
Once the principle was established the struts could be finished off. A Rotherham pump was cobbled together from various materials
and mounted to the rear right hand strut. In actual fact this should be the front strut on this particular aircraft but I felt that that was going to make things a tad awkward when rigging the cabanes. Not quite in Bo's league I'm sorry to say but it will give a reasonable impression
And finally all the bits are ready - well not quite, the little propeller needs re doing. I used Vallejo Flesh Tint for the undercoat - a wrong choice as it transpired ::)
Well that's another step forwards. The plan is to get the struts in using Gator glue, mount the wing and then slip the main struts in last. First though I need to attend to the rigging line attachment.
Well it's time for a shower and get ready for a pint tonight - (see you later Paul)
Regards - Tug
Offline Pgtaylorart
« Reply #153 on: December 17, 2015, 03:32:42 AM »
Beautiful work as always, Tug! Your use of clear plastic to align the struts is brilliant.
George
« Reply #154 on: December 17, 2015, 03:55:20 AM »
  Tug,
Outstanding update my old friend.
« Reply #155 on: December 17, 2015, 04:08:31 AM »
   Brilliant work with the jigs Tug. I use roughly the same method doing the cabanes but the clear plastic is a very clever touch, well done. This is going to provide for far less urgency to grab a WNW Camel when it's released, you'll already have a spectacular Camel in your collection!  ;)
« Reply #156 on: December 17, 2015, 04:46:05 AM »
Excellent Jig, Tug  ;)
Nice scratchy work on the pump... very nice!
BVB
Offline UFAG
« Reply #157 on: December 17, 2015, 06:24:46 AM »
I missed a lot after absence of 6 months on this site...fantastic build.
« Reply #158 on: December 17, 2015, 06:30:14 AM »
You are moving along brilliantly Tug, your clear plastic wing jig is a very good idea.
Offline Suffolk Lad
« Reply #159 on: December 18, 2015, 08:42:16 AM »
Hi Guys thanks for your comments - glad you liked the clear plastic idea.
UFAG - thanks for looking in and taking the time to comment . It's nice to see a new face on the thread  :)
Well - had a reasonable day today and, pleased to tell, the clear plastic proved a good aid. First off though was to make that little 'acorn' button. I'd considered the merits of turning this but in the end just shaped it by scratching it to shape with a scalpel after cross drilling the hole. The rigging material was to prevent it disappearing!
After fitting the screen the cabanes were drilled for the rigging and just dry fitted in place at this stage
The transverse rigging added through the acorn
Then everything was positioned carefully  ..
.....before easing each strut out in turn, gluing with Gator glue and clicking back in place
This was then set aside to let that glue really consolidate and the rest of the time was spent gluing the rigging into the top wing ready for the next phase. I'd like a good clear run at that so due to the weekend's interruptions that's unlikely to be until next week.
Back soon - Tug
« Reply #160 on: December 18, 2015, 10:49:37 AM »
She is coming along wonderfully so far , nice detail work on the struts Tug  :)
« Reply #161 on: December 18, 2015, 05:18:59 PM »
Super work, Tug  ;)
vB
Offline Suffolk Lad
« Reply #162 on: December 25, 2015, 04:29:06 AM »
I'm struggling with this at the moment guys  :(.
Had to walk away from it day afore yesterday when trying to glue the top wing on. Despite the jig this proved extremely tedious due to not being able to see. Got two cabane struts in and then a third, then, as the fourth went, in all the others popped their joints. Believe me I spent some time trying but it wore me down in the end. I just cleaned all the glue off, re-drilled the holes to clean them out and put it aside for a while. I just so glad I didn't use CA or epoxy as the Gator glued cleaned up reasonably easy
I did check your build log again Des and note you did yours upside down but decided to persevere with the jig for now.
Today I glued  two struts in on one side and have left it to really set before trying the second. I'm keeping my fingers crossed they will hold as the second two are done. It also looks as if the main struts are a tad short. I note you tweaked the dihedral on your lower wing Des so I may have to try to do that in situ - not looking forwards to that if so. I'm having rather negative thoughts at the moment - that's an awful lot of work if the top wing wont go on :o
Anyway - Merry Christmas, have a good time - it's a workshop free day tomorrow you know  ;) ;)
Regards - Tug
Offline Radarman
« Reply #163 on: December 25, 2015, 09:27:55 AM »
Happy Christmas Tug! May you open a box of serenity to see through to the end.
I look forward to the end result of this great build.
                                                   Kevin
« Reply #164 on: December 25, 2015, 01:58:57 PM »
walking away for a couple of days was the right thing to do! I am sure you will overcome your attachment issues!
