Author Topic: Hobby Craft Sopwith Camel  (Read 43065 times)
Offline Cajun
Re: Hobby Craft Sopwith Camel
« Reply #120 on: November 17, 2015, 11:15:25 PM »
Beautiful work!
« Reply #121 on: November 18, 2015, 12:21:48 AM »
Your build is continuing to be absolutely stunning! The wings and MGs look outstanding!
« Reply #122 on: November 18, 2015, 06:27:33 AM »
Looking forward to seeing the next progress report on this excellent model.
Offline Suffolk Lad
« Reply #123 on: November 18, 2015, 06:41:02 AM »
Suitably chastised George - there was another pic of another fixture with an F-100D in position but I thought that might just be stretching it a bit. Phew - glad I decided not to push my luck too far  ;) - ahem! I did say I had a penchant for jets though didn't I ?  :D :D
Cajun, RAG, Des - thanks for continuing to look in and your encouraging comments. I'm taking a day or two break then I'll get back to dealing with that lower panel and fixing the wing on.
Regards - Tug
Offline Suffolk Lad
« Reply #124 on: November 23, 2015, 09:12:25 AM »
Hi all  :)
Finally managed to find some time to take a better look at that bottom wing/lower cowl problem. Whilst it's not perfectly accurate it is close enough I feel to convey the original make up that I can see on what pics of the area I have.
The wing centre section was scraped and sanded to fit as flush as possible with the fuselage then further scraped and filed to simulate the panel line
Some more fasteners were made as per the side panels and CA'd in place and trimmed flush on the inside
A ten thou plastic card 'extension' was cut and dry fitted to the fuse outlines first then glued to the kit part and finally pared away to the edge of the recess
This brings the panel down toward the wing allowing the extension to overlap the panel which is how it appears to be on the full size. The overlap portion was sanded to about five thou thickness. It's only just laid in place here hence the misalignment
With this little problem solved the last of the internals can finally be dealt with and then that bottom wing can be attached at last  :)
There's a busy week ahead but I'll try to keep at this as and when I can.
Regards - Tug
« Reply #125 on: November 23, 2015, 09:33:56 AM »
Nice work with the modification to allow you to get the bottom wing fitted soon.
Des,
« Reply #126 on: November 23, 2015, 09:56:50 AM »
  Tug,
Outstanding save on her lower wing attachment problem my old friend. Your skill and craftsmanship very much came in handy. Enjoying each update and looking forward to the next.
« Reply #127 on: November 24, 2015, 01:12:48 AM »
Outstanding fix on the wing undersurface and lower cowl.
« Reply #128 on: November 24, 2015, 02:56:33 AM »
Very nice work, Tug.
Keep going!
vB  ;)
Offline Suffolk Lad
« Reply #129 on: November 24, 2015, 09:56:06 PM »
Hi Des, Gregory, RAG and Von B, Thanks as always for your continued following and encouragement  :)
Michael - no apologies required at all - it's good to see you here and thank you too for your comments.
The post was more to show the fixture - the Crusader was just in the way  :D. I will however pop a pic or two on TTR later and provide a link to others. Despite my new found interest in WW1 subjects I find I still have an 'unhealthy'(?) interest in those at the other end of the spectrum  :o - I'm looking forwards to the forthcoming Mig 31 from Avantgarde.
I set out on the Camel well aware that WnW's were going to release one and feeling that in all probability what you say will happen will happen. Whilst I'm looking forwards to their version - which just has to be so much easier to put together - I've really enjoyed trying to overcome the challenges which this one has provided.
It has occurred to me that taking your analogy further I should (attempt) to scratch build a Vickers GunBus in the almost sure certainty that having done so they will release one - oh I so wish :)
Kind regards - Tug
« Reply #130 on: November 24, 2015, 11:39:56 PM »
Outstanding work Tug.
Offline Suffolk Lad
« Reply #131 on: November 30, 2015, 07:38:09 AM »
Thanks for continuing to look in Martin and for your encouragement  :)
I've had a fairly intense day on it today and made a significant step forward - well significant that is, in that the bottom wing is on at last  :D
I have to say I have learnt a lot throughout the day not least just how difficult it is to keep wayward pieces of rigging material (invisible thread) out of the way of each other, not to mention the inherent springiness of such stuff even though it's only 6 thou in diameter.
I'm afraid I was so engrossed in getting the lines through the fuselage and then getting the wing on followed by the front panel - all connected together - I forgot about taking pics early on.
First off was to fit the gun activating cables to the column using 0.2mm white coloured copper wire. Although painted dark grey I used white and left the ends unpainted so to be able to see their position better. The elevator control lines were threaded though the false guide set on the rear wing spar and through the small plate on the column. A minor disaster struck here when a touch of CA was applied to the small plate - it just disintegrated on the rear side - fortunately it remained intact on the fore side so the rear was reinforced with some Gator glue. With the cables threaded through their respective holes the column was added to the wing then the cables pulled through the fuse using a piece of copper wire. The lower cowling piece with the rudder bar hangs down the side.
The really difficult bit, believe it or not, proved to be the actual glueing of the wing on  - I began by using Contacta but by the time the wing was in situ with all the cables out of the way that had gone off. The only way was to bend the end of a paint brush and use MEK from the inside.
Once that was well set the cables were then gently pulled and tweaked into place around the return pulleys with a piece of bent wire and pulled taught at the rear .....
 ....and finally glued into slits cut into the lower fuse at the tailskid opening with a scalpel. Once set a good splodge of Gator glue was worked over the inside to reinforce the join. The 'croc' clips proved to be just the right weight to give sufficient tension while the glue set
I've never had the 'pleasure' of putting a ship in a bottle but I'm sure this must be the closest I'll get. The problem of dealing with all those lines to raise masts etc whilst working from one spot suddenly came into focus  :-\
I feel this is a big stage accomplished. It was very fiddly but in truth went far better than I anticipated. Apart from the small plate on the control column breaking no other breakages occurred which considering all the poking around inside was surprising to say the least.  Next off is to tidy up the gun cables and fit the guns then tackle the undercarriage.
Back soon - Tug
« Reply #132 on: November 30, 2015, 08:31:34 AM »
Excellent work getting the bottom wing fitted, always a challenge but you pulled it off nicely. I am still in awe of the wood effect you created on the fuselage, it looks brilliant.
« Reply #133 on: November 30, 2015, 08:42:36 AM »
Like Des no other words.
Offline Pgtaylorart
« Reply #134 on: November 30, 2015, 10:15:10 AM »
Excellent, Tug! I know this isn't the Wingnuts kit of course, but when I build my Wingnuts Camel I'm going to use your model as a guide!
George
