Author Topic: 1/32 Table?  (Read 1348 times)
Offline ade
  • "..ambition? To be Elvis Costello"
1/32 Table?
« on: May 30, 2015, 06:36:13 PM »
Currently in the middle of my WNW Roland build and thinking ahead as to how to display it - with the engine cowlings off, i would like them to sit beside the model on a suitable period maintenance table.
Any recommendations as to finding one...EBay search fruitless..
Offline hiddeous1973
Re: 1/32 Table?
« Reply #1 on: May 30, 2015, 07:57:56 PM »
try 1/35 scale. differance in scale is not so great. (you can always shorten the legs if you feel it is to big)
Re: 1/32 Table?
« Reply #2 on: May 30, 2015, 10:17:20 PM »
You could get the RFC Mechanic and table.  Reassign the
mechanic and keep the table for the Roland. ;) ;D
http://www.kellerkind-miniaturen.com/product_info.php?info=p126_rfc-mechaniker-an-der-werkbank.html&XTCsid=271375a53413c810505a47b38dd94993
Offline tinsmith
Re: 1/32 Table?
« Reply #3 on: May 31, 2015, 12:32:37 PM »
Scratch-building inspiration: two of the maintenance tables in the WW1 hall at NASM/Washington, D.C. :)
Offline davecww1
Re: 1/32 Table?
« Reply #4 on: June 04, 2015, 11:58:19 AM »
Yes, since they were just wooden 2x4's nailed together with whatever sized boards they had for the top they should be easy to scratchbuild using basswood strips available in the model railroad section.  Just find a photo of one like above and estimate the size needed in 1/1 scale and divide by 32, this should give you size of wood needed to make the finished table.  And making real wood look like wood is much easier than painting a piece of resin!
