Author Topic: 1/48 Eduard: Morane Saulnier type L Jean Navarre april of 1915  (Read 50579 times)
Offline xan
« on: December 18, 2014, 08:46:35 AM »
Hello this is the first ste by step in this wonderfull forum; by the way, it's my first step by step in English.
My English is quite poor and I'm afrais I won't always be able to say what I want.
If I don't know how to explain what I have done, I will just put the pic  ;)
I am doing the Jean Navarre's planes.
 As I showed in my presentation I did two of them
the Morane saulnier type N (called bullet by the english if iI'm not wrong)
and his first Ni-11 "bébé", the n°576:
I will present them better in the "Completed models" section.
The plane I will do is Morane Saulnier type L
i will explain the historical context of this plane when I will present it at the "completed models" section
jist say thet Jean join the MS-12 the first french hunter squadron equiped with this plane. With that plane (n°27),  He won his first victory (the third of the french army)
However,  here is the kit, the old Eduard. As far as I know, there is another one in resin and another one vacuformed.
those kits show the progress Eduard made  ;)
well the mout have officialy started!
Xan
« Last Edit: December 18, 2014, 09:01:44 AM by xan »
Offline xan
Re: 1/48 Eduard: Morane Saulnier type L Jean Navarre april of 1915
« Reply #1 on: December 18, 2014, 08:52:41 AM »
today's work:
Xan
Offline Pierre Giustiniani
« Reply #2 on: December 18, 2014, 09:04:54 AM »
Great job Xan associated with a very interesting story.
You should try EZ line for the internal rigging. It's very easy to use and well adapted for quarter scale.
Pierre
Labor omnia vincit improbus
Offline KitRookie37
« Reply #3 on: December 18, 2014, 03:58:47 PM »
Hello to all,
Very good beginning my friend. As Pierre, I think you should use EZline. If you want, I can order to WnW during my next ordering.  ;)
Friendly.
Alain.
Use the force, Luke.
Offline xan
« Reply #4 on: December 18, 2014, 04:43:50 PM »
Very good ideia Pierre, thanks. I will.applied it this.evening
Xan
« Reply #5 on: December 18, 2014, 04:47:29 PM »
You have made a very good start Xan, I will be following this build closely.
« Reply #6 on: December 18, 2014, 08:32:40 PM »
The Parasol is an interesting build, Xan.  I will enjoy following
your build. You are off to a good start. :D
« Reply #7 on: December 18, 2014, 09:08:55 PM »
Nice start Xan! I like how you have reinforced the PE frames with styrene!
Offline gruson
« Reply #8 on: December 18, 2014, 10:01:39 PM »
Hello Xan,
the layout is very nice, the Assembly also. It is well done... What more to ask?
michel
Je suis Charlie
« Reply #9 on: December 19, 2014, 12:57:32 AM »
Nice beginning and a good story Xan.
Your english is good enough, because mine is also bad.
Offline IFF1418
« Reply #10 on: December 19, 2014, 01:55:13 AM »
Hello Xan,
Very nice start! I like the MS type N very much. One of my favourite aircrafts.
Kind regards
Patrick
Offline sodium
  • SPA48 chante et combat
« Reply #11 on: December 19, 2014, 02:54:04 AM »
Hello xan
I know that you love difficulties. Is it really a model to rest you ?
The cutting of the wood fuselage is quite strange and complicated.
I will follow you, I am sure it will be magic
philippe
« Reply #12 on: December 19, 2014, 03:10:51 AM »
Excellent start, Xan, and your photographic presentation is marvelous.  This is going to be a fun build to follow.
Offline MS406
« Reply #13 on: December 19, 2014, 03:43:59 AM »
Do you use "Piment d'Espelette" for the weathering? ;)
Excellent job as usual with you! Cheers.
Best regards from France.
Offline xan
« Reply #14 on: December 20, 2014, 10:05:39 AM »
Hello!
You were right Pierre and the result is much better then with the photoetched rigging!
I will follow you
I hope so, that's why in part I decide to do the step by step in this forum  ;)
You are right, this wood fuselage is a non sens in the upper side...
I will follow you
here what it looked like
(pic taken in the step by step of the superb parasol of Edo)
http://forum.ww1aircraftmodels.com/index.php?topic=794.0
anyway the photoetched is a little bit to large for the fuselage, the plastic of the fusselage is very very thick and I 'm thinking that I could take the same way than Edo and rebuild the fuselage...
I have to think a little more...
Xan
