Author Topic: Eduards SSW D.III  (Read 44483 times)
Offline Vickers
Re: Eduards SSW D.III
« Reply #75 on: July 26, 2014, 03:00:24 AM »
Sorry I'm late to the party, Terri.  This is one excellent build you've got going on a kit we seldom see built- marvelous attention to detail inside and out and I applaud your dedication toward getting all of the plastic parts together smoothly. This little putty hog appears to be coming together beautifully in your highly capable hands!
« Reply #76 on: July 26, 2014, 03:09:28 AM »
I'm not a fan on the use of PE parts , but they do aid in some of the details and I'm trying to avoid on using as much as possible and rather opt for making these details myself or at least what my skill set will allow me to do .
I wholly agree with you Terri as I too do not like or use PE. Your skill set is one to be envious of so I am sure that the details will be every bit as good when you finish adding them. I am really enjoying following this thread and watching how you add all of those tiny details.
« Reply #77 on: July 26, 2014, 11:05:44 AM »
No need to be sorry Sir . Folks are welcomed anytime ! Glad you are enjoying the build so far , it has had a few challenges but nothing which really held me back once I sat down and worked out it in my head . Not much putty actual , over all fit isn't bad until you get to the gun deck and cowl  :'(
« Reply #78 on: July 26, 2014, 11:15:17 AM »
Thanks LM , but I don't think my skills are something to be envious of when I see the work which all you guy's do , just mind blowing .
Not much more detailing on the airframe then it engine is up next and I must say . my work is cut out for me ...
« Reply #79 on: August 02, 2014, 10:11:59 AM »
Really not much progress , but I guess some is better than nothing . The rolled lip has been added to the cowl . I need to prime this and see how well I did and if I need to redo it . In the end I ended up replace the gun deck access panels using 0.5 card and PE hard ware . Drilled holes don't look right when this detail is raised so at the moment this is all I got . Cowl chips are also added . Now it is off to doing the rib tapes . Does feel nice on getting closer with spray the first coat of primer ...
« Reply #80 on: August 02, 2014, 10:12:45 AM »
 8)
« Reply #81 on: August 02, 2014, 12:23:39 PM »
Nice update T! The front end is looking great!
« Reply #82 on: August 02, 2014, 12:34:44 PM »
Hello Terri:
Nice update.  Your card work on the engine panel is a nice touch and looks great.  Looking forward to seeing you progress and your next update.
Offline oldalbie
« Reply #83 on: August 02, 2014, 01:01:09 PM »
Good work Terri.  It's great to see your progress on such a difficult kit.
Offline NinetythirdLiberator
« Reply #84 on: August 02, 2014, 02:38:01 PM »
Been away too long...I must echo all those other fellow, Terri.  Pretty dang lovely.  I do know that's a tough kit, too...
Cheers!
Dan
« Reply #85 on: August 02, 2014, 03:06:25 PM »
Super work on the gun deck and cowling, T!  I'm looking forward to seeing her primed.
« Reply #86 on: August 02, 2014, 10:09:47 PM »
Exeptional work Terri. ;D
guitarlute101
« Reply #87 on: August 02, 2014, 10:23:40 PM »
Very nice Terri, love this build!
« Reply #88 on: August 02, 2014, 10:44:02 PM »
Yarp... looking good indeed. Been reading the Herris book on SSW, pretty intriguing machines.
« Reply #89 on: August 02, 2014, 11:33:46 PM »
It's those little touches that you add to your models that make all the difference Terri. Nicely done!
