Author Topic: Eduards SSW D.III  (Read 44363 times)
Re: Eduards SSW D.III
« Reply #105 on: August 07, 2014, 02:04:12 PM »
Terri,
Terrific progress and as Des said, great added details!
Offline Dirigible-Al
« Reply #106 on: August 08, 2014, 03:54:15 AM »
Hi Terri
Great to see this little bird again and I see you have made fantastic progress too.
Alan.
« Reply #107 on: August 08, 2014, 09:56:48 PM »
Hi guy's , thanks for dropping by and leaving encouraging mojo !
LM , for the rib tapes I have a spot on my cutting mat with makes made so when I'm cutting the tapes I can stay consistent when I remember to use it . Most times it is just eyed balled  ;)
The main wings got spray with thinned Mr.Surface 1000 . After the first coat I realized that this is too thin and I switched to Mr. Surface 500 instead . I do recommend that one wear a mask when spraying this stuff . Strings will forum on the leading and trailing edges of the wings and there is fine dust which forums in the air as well . Don't worry about the string effect . this will sand or rub off with ease .
Once dried the surfaces got sanded down too smooth out the putty while also polishing the surface . Control surface I used future , giving a total of three coats . These are still drying .
« Reply #108 on: August 08, 2014, 09:57:14 PM »
« Reply #109 on: August 08, 2014, 09:58:21 PM »
I also started on the cad struts and will have pic's of this soon ......
« Reply #110 on: August 08, 2014, 10:40:16 PM »
Very nice Terri. 8)
« Reply #111 on: August 08, 2014, 11:16:14 PM »
Thanks Martin  8)
Here is where I'm at with the cab struts so far . The one on the left is before filling and sanding the joins . One on the right is the finished product waiting primer and paint .
I used contrail strut using the Eduards one as a template added 2mm in length . Center part of the N strut is the same length as the in the kit .
Terri , so close to the priming and painting stage , I can taste it !
« Last Edit: August 09, 2014, 01:39:20 AM by Terri »
« Reply #112 on: August 09, 2014, 02:40:26 AM »
Hello Terri:
'Yer Gettin there.  Looks good so far.  Can't wait to see you start the painting and decaling on this bird.
Offline Epeeman
« Reply #113 on: August 09, 2014, 03:06:48 AM »
Good work on your rib tapes, Terri -
Makes a real difference to the model.
« Reply #114 on: August 09, 2014, 03:19:31 AM »
Rib tapes are looking fantastic, T!  Can't wait to see 'em painted and lozenged.
« Reply #115 on: August 09, 2014, 07:54:48 AM »
Thanks Mark , Dave and Bud  :)
It really feels great to be at this stage of the build , long time in the waiting !
Will be laying paint tonight !
« Reply #116 on: August 10, 2014, 11:03:29 PM »
Okay , didn't get the paint laid down on here . Missed a few details . Those four little rivet heads on the fuselage side took me over a hour to get them in place . Had a hard time holding them with the tweezers and placing them in their holes . Went through 12 of them . Carpet monster was well feed the other day and should be good for awhile .
« Reply #117 on: August 10, 2014, 11:04:47 PM »
« Reply #118 on: August 11, 2014, 02:06:53 AM »
An exeptional build. 8)
« Reply #119 on: August 11, 2014, 03:05:03 AM »
Hi Terri:
Talk about "Painstaking" detail.  Your efforts are paying off.  You don't see too many of the SSW D.III's and your will be a beaut.   Looking forward as you move down the home stretch.
