Author Topic: Eduards SSW D.III  (Read 44274 times)
Re: Eduards SSW D.III
« Reply #255 on: October 12, 2014, 12:16:53 AM »
You build a very nice engine Terri.
« Reply #256 on: October 12, 2014, 01:21:46 PM »
Your engine is looking good T!
Offline xmald
« Reply #257 on: October 12, 2014, 07:08:30 PM »
Great job Terri! BTW - are you going to build the new tool SSW as well?
Best regards
Filip
« Reply #258 on: October 13, 2014, 03:17:27 AM »
Thank-you very much guy's  :)
Xmald , yes I will be building the new tool one . Will be placing my per-order in at the LHS next weekend  :)
Yesterday I was able to get a few lick's of paint on the engine once the base coat of Humbrol # 11 mat alum followed by a dry brushing of Testors Model Master buffing alum . While this was drying the induction pipes got brushed with Burnt Iron . Back to the cylinders the tops I dried brushed Burnt Metal followed by a light dry brush of Exhaust . Time to load up the airbrush with a mix of Tamyia clear blue with a bit of smoke mixed in and just the tops of the cylinders got sprayed for the bluing effect caused by the heat . This was then tone down with smoke being sprayed over the whole engine . Once all this was dried a wash of black was applied . The lifter housing on the front of the engine is paint battle ship grey from the Model Master line . Once dried I glued the induction pipes in place and the wiring harness .
Todays goal will be fixing the leads in place and the push rods with a bit more weathering to follow .
« Reply #259 on: October 13, 2014, 03:17:58 AM »
« Reply #260 on: October 13, 2014, 03:18:26 AM »
« Reply #261 on: October 13, 2014, 03:59:05 AM »
The engine looks very great Terri. ;D
« Reply #262 on: October 13, 2014, 12:28:17 PM »
Thanks Martin !
Offline Dagmar Henderickx
  • Slow Builder
« Reply #263 on: October 20, 2014, 12:07:43 AM »
Hi Terri,
I followed this build for some time. I'm impressed by what you are able to get out from 'an old kit' like this. Will you also be queuing for the recent Eduard kit?
Dagmar
Offline xmald
« Reply #264 on: October 20, 2014, 12:12:32 AM »
Wow looking great Terri!
Best regards
Filip
« Reply #265 on: October 20, 2014, 09:50:42 AM »
Thanks Dagmar for following along . I like these " old " kit's , they are perfect of such projects as this  :) Yes I will be getting Eduards new kit of this bird  ;)
Thanks Xmald , I'm getting one step closer on getting her done !
Now that I have some what started to feel better and have the energy to sit in front of the bench work continues . Push rods are installed and so is the engine and front engine support as well as the guns . A bit of weathering and the top wing and struts will be up next ....
« Reply #266 on: October 20, 2014, 09:51:15 AM »
« Reply #267 on: October 20, 2014, 08:54:17 PM »
Your plane looks very great. Wonderful update.
Offline dtomko
« Reply #268 on: October 20, 2014, 10:56:35 PM »
Looks fantastic, Terri.  I had started mine years ago and got distracted.  Now I'll probably wait for the new version.  Having wrestled with this kit I can appreciate how much effort it takes to get it to come out as great as yours.
Drew
Offline NinetythirdLiberator
« Reply #269 on: October 21, 2014, 01:36:51 AM »
Like them guns...that looks just great, Terri!
Dan
