Author Topic: Battaille Scratch build in 1:32 scale  (Read 34027 times)
Offline Steven Robson
Re: Battaille Scratch build in 1:32 scale
« Reply #90 on: March 23, 2014, 03:59:38 AM »
An amazing aircraft and an amazing scratch build.
I love seeing the updates on this one.
« Reply #91 on: March 23, 2014, 06:09:47 AM »
Stunning work, Des!  Wow!   :o
I agree and must add Gorgeous, spectacular, Awesome, etc.....
« Reply #92 on: March 23, 2014, 03:26:33 PM »
Thanks guys for all your wonderful comments, they are very much appreciated.
Just a small update this time. I made all the bits and pieces for the bottom wing mount and incident adjusting mechanism, it may look a little fragile but it is quite a strong assembly. The first photo shows the components while the next photo shows it assembled and mounted to the aircraft.
This is a close-up of the undercarriage suspension set-up, quite different to a usual bungee cord wrapped around the axle.
Offline miecio52
« Reply #93 on: March 23, 2014, 03:51:33 PM »
Master-you are great.
 Mietek
 IPMS Poland / Silesia
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #94 on: March 23, 2014, 03:55:00 PM »
Totally cool work Des  8) Not only is this the best Battaille we will ever see, but probably the only one!
James
Happy Modelling
James Fahey
Offline IFF1418
« Reply #95 on: March 23, 2014, 07:30:34 PM »
Des, this is far better than the real replica in the museum. Can't believe my eyes!
Kind regards
Patrick
« Reply #96 on: March 23, 2014, 08:57:54 PM »
This is a masterwork Des!  Your fabrication, incorporation and use of small metal fittings and bolts, etc., is really quite remarkable and extremely realistic--looks great too! ;D  What are the gearboxes on the incident adjusting mechanism made from?  Thanks!  This is sublime modeling.
« Reply #97 on: March 23, 2014, 09:04:29 PM »
The lower V shaped housing is made from styrene sheet while the small top one is brass sheet. The gears are from watch/clock parts. The main large support which mounts to the fuselage is made from 1.0mm thick styrene sheet with 0.5mm copper wire fitted for the mounting brackets, these were flattened and a 0.3mm hole drilled, I used a 0.3mm brass pin to secure them to the fuselage with CA.
« Reply #98 on: March 24, 2014, 12:00:20 AM »
Des, Your work continues to be AMAZING! I guess I need to buy a watch so I can tear it apart for gears  8)
« Reply #99 on: March 24, 2014, 01:00:05 AM »
You're running the risk of bettering yourself yet again, mate!  Truly astonishing stuff.
« Reply #100 on: March 24, 2014, 01:12:12 AM »
I am in awe of your work, Des.  While the total view of the fuselage is amazing...the wood
colours are wonderful, by the way, the close-up of the undercarriage is absolutely inspiring!
More, please. :D
Offline IvotB
« Reply #101 on: March 25, 2014, 01:25:28 AM »
Des,
Somehow I didn't follow this topic as the subject Battaille isn't very appealing to me. But now I went through 8 pages and I must say that you have produced a tremendous scratch built sofar. It is becoming a really stunning model of a very rare plane.
I can only admire and praise your scratchbuilding skills.
with kind regards,
Ivo
« Reply #102 on: March 27, 2014, 05:34:30 AM »
The engine for this plane was an inverted Gregoire-Gyp 40hp water cooled 4 cylinder type. This engine had the unusual aspect of having all four cylinder enclosed within a cooling jacket. The only reference material I have are three very blurry photos so a lot of the build will be guess work. Here is the engine so far, the box sitting on top of the engine appears to be an oil tank, I still need to add a few pipes. Next job is to make the cooling jacket to encase the cylinders. The propeller I have sitting on the engine is not the one Ihat I will be using on this model.
« Last Edit: May 30, 2014, 04:18:40 PM by Des »
« Reply #103 on: March 27, 2014, 04:49:13 PM »
Spectacular, Des. Yet again...
Offline Andi Little
« Reply #104 on: March 27, 2014, 05:39:40 PM »
Excellent vocabulary or not ...... sooner or later words fail one!
Bliddy marvellous.
KBO ............. Andi.
