Author Topic: Battaille Scratch build in 1:32 scale  (Read 34090 times)
Re: Battaille Scratch build in 1:32 scale
« Reply #75 on: March 19, 2014, 08:14:41 AM »
The bar climbs ever higher. Truly outstanding craftsmanship, Des.
Vb
« Reply #76 on: March 20, 2014, 08:36:14 AM »
Before fitting the tail I needed to complete the rigging of the fuselage frame, this has now been done, there is a total of 26 turnbuckles just in this section, I used 0.12mm monofilament for the wires and CA to hold it all together, the tail can now be fitted in position and rigged.
« Last Edit: March 20, 2014, 08:56:18 AM by Des »
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #77 on: March 20, 2014, 09:48:26 AM »
this is just too good!
Think globally, act locally!
Offline LindsayT
« Reply #78 on: March 20, 2014, 12:46:16 PM »
Did you notice an appreciable increase in the torsional strength? I should hope you got some sort of structural benefit out of all of that. But of course, I'm talking to Des, here. Whereas that rigging may take years off a mere mortal, that's just raw fuel in the afterburner for the rigmeister!
Great stuff, Des.
Lindsay
« Reply #79 on: March 21, 2014, 01:47:56 PM »
I finished the rigging on the top of the tail plane, elevator and rudder rigging is also done. Close-up photo shows the little metal brackets I made which fit over the top of the elevator control horns, small but functional.
« Reply #80 on: March 21, 2014, 04:36:06 PM »
Like candy to a kid! This 46 year old kid!!!
Keep inspiring us, Des.
Great stuff  :)
Von Wrappedinvisualcandy
« Reply #81 on: March 21, 2014, 04:57:32 PM »
Extraordinary, Des. I just love following your scratch builds.
Offline Ssasho0
« Reply #82 on: March 21, 2014, 05:31:17 PM »
It looks even better and better with every update!
Des,
What do you used to make the hinges and the other blue/greenish parts? Is this metal (custom PE) or very thin polystirol or something else?
Best regards,
Sasho
« Reply #83 on: March 21, 2014, 05:45:10 PM »
All the metal parts are just that, metal. I use thin brass sheet which is 0.2mm thick, I cut this to the required width, usually about 1.0mm, by using a razor saw, this gives a good clean cut, a steel ruler is used as a guide. The holes are drliied using tungsten carbide drill bits usually about 0.3mm in size, they will drill through the thin brass very quickly.
Offline IFF1418
« Reply #84 on: March 21, 2014, 06:22:09 PM »
I have no words for this Des! Unbelievable.
Kind regards
Patrick
« Reply #85 on: March 21, 2014, 10:04:45 PM »
Des, that are very good updates and it is a master build.
« Reply #86 on: March 22, 2014, 12:18:30 AM »
Incredible detail Des, the brass fittings are excellent, really take it steps beyond perfection!
« Reply #87 on: March 22, 2014, 12:26:44 AM »
Amazing work, Des.  I really like your use of brass for the fittings etc.
Superb work!
« Reply #88 on: March 22, 2014, 02:04:30 AM »
Stunning work, Des!  Wow!   :o
« Reply #89 on: March 22, 2014, 06:56:46 AM »
Just amazing what you do. Like the others I am lost for words - absolutely stunning is not nearly good enough to describe this.
