Author Topic: WNW Sopwith Snipe: Early: Albatros DVa Jasta 6  (Read 107399 times)
« Reply #180 on: May 11, 2014, 10:21:09 AM »
Stunning work, as usual, Amigo!  Almost done!
Cheers.
Thanks Amigo! I always appreciate your comments!! Here is the last update on the Snipe until the Albie catches up: Rudder Stripes painted on. Fin and Rudder attached.
« Reply #181 on: May 11, 2014, 09:43:19 PM »
Wow, wow and wow, Rick!  Absolutely gorgeous job, better every look
we get of her.  Well done, my friend. :D
« Reply #182 on: May 11, 2014, 10:07:37 PM »
Thanks Ernie, I truly appreciate your kind comments!
« Reply #183 on: May 12, 2014, 01:26:21 AM »
Stunning build Rick.
Offline justin1980
« Reply #184 on: May 12, 2014, 02:44:27 AM »
Fantastic build, it still amazes me the quality of the builds on this site!  Impressive looking snipe!
Bessie Braddock: Sir, you are drunk.
Churchill: Madam, you are ugly. In the morning, I shall be sober!
Nancy Astor: Sir, if you were my husband, I would give you poison.
Churchill: If I were your husband I would take it.
Offline mc65
« Reply #185 on: May 12, 2014, 04:03:59 AM »
sigh!
I would be able to be so clean as you in the assembling and painting those kites.... stunning work, rag!
Offline Epeeman
« Reply #186 on: May 12, 2014, 04:42:37 AM »
Great progress on your Snipe, now Rick -
Getting ever closer to finish line on this one, mate ...........
Offline IFF1418
« Reply #187 on: May 12, 2014, 05:02:03 PM »
Really lovely Rick! I admire your paint master capacities. This is a top build!
Kind regards
Patrick
« Reply #188 on: May 13, 2014, 11:11:35 AM »
Thanks for the Very Generous Comment Martin!
Thank you Justin! You are certainly correct about the quality of the builds here. Mine are  in the Middle of the range... IMHO  :)
sigh!
Thanks for the kind comments! You will surpass my work I am sure. Just takes practice!
Kind regards
Patrick
As always, thank you Patrick my Friend!
« Reply #189 on: May 14, 2014, 05:14:10 AM »
Hi Rick:
Just catching up a bit here.  Really looks the business Rick.  I am pretty much doing the same as you.  I like the painted on stripes on the rudder.  Did you have any difficulty attaching the rudder?  I am a little behind you and will comment on the upper wing, but I am sure it will be a cinch.  Looking forward to your next update.
« Reply #190 on: May 14, 2014, 08:00:49 AM »
Really looking sharp !!!! Await next photos.
« Reply #191 on: May 14, 2014, 11:07:57 AM »
Hi Rick:
Thanks for the comments Mark! I am looking forward to seeing your "Take" on the Scheme! No difficulty with the rudder and the fin should get sturdier after rigging. The whole thing may or may not sit a little high. I know Des adjusted the height, I did not. As for the stripes I just felt it was easier and cleaner to paint. I will add a little post shading later. I am sure you will have No Issues with the Wings!
Thanks Amigo! I always appreciate you dropping in! I am now working on the Albatros Engine, then will attach the lower wings and hopefully the upper.
« Reply #192 on: May 17, 2014, 10:20:59 AM »
I have spent the last two days working on the Albatros. The band with chevrons seemed to be a simple matter. It proved to be quite a challenge, AT LEAST TO ME! I first masked the white band, then painted. No real issue here although a little of the wood grain painted fuselage lifted when I removed the mask. No big deal I can handle the touch up. I then attempted to use black decal strips to make the chevrons. Failed TOTALLY! In the end I enlarged the profile from the Osprey book, cut out the chevron that represented the one on the "Most" flat surface of the fuselage, and replicated it numerous times on Post it note paper. I applied the post it chevrons in position and outlined with Tamiya tape. I removed the post it note mask and sprayed black. This has me close enough that I can go back and touch up using black and white decal strips to even things out. I have also applied the serial number to the left fin. I will touch up all of the glitches on my next off of work rotation!
PS: Funny thing about those chevrons. Anything but a Straight on shot makes them look Very Wonky. The good news is that the photo of the real aircraft has the same thing going on!
« Last Edit: May 17, 2014, 10:54:37 AM by RAGIII »
« Reply #193 on: May 17, 2014, 11:04:00 AM »
Beautiful work on the Albatros Rick, your technique to apply the white band and chevrons worked really well and looks great, this is shaping up to be an excellent model and the Snipe is also looking great.
Offline treadhead1944
« Reply #194 on: May 17, 2014, 11:54:17 AM »
Looking good Rick!
