Author Topic: Roden Nieuport 28c  (Read 19624 times)
Re: Roden Nieuport 28c
« Reply #30 on: February 23, 2014, 09:27:58 PM »
Now you have me wondering, Patrick.  I'm sure it would be ok, but maybe get some other opinions before diving in.  Despite what I have told my wife, I have been wrong before. ;D
« Reply #31 on: February 23, 2014, 10:46:28 PM »
Patrick,
Very nice work on the wing camo! You have done an excellent job with the demarcations between colors!!
« Last Edit: February 24, 2014, 03:13:38 AM by RAGIII »
Offline IFF1418
« Reply #32 on: February 23, 2014, 11:17:25 PM »
Thank you so much Rick, I owe a great deal to you. Do you think I could paint a new layer of light green above the clear one?
Thanks a lot my friend!
Kind regards
Patrick
« Reply #33 on: February 23, 2014, 11:34:43 PM »
Kind regards
Patrick
Patrick. Are the "Spots" what I see just to the right of the Black Footprint? If so since the roundel will cover this area I would just give a light sanding with 8000 grit micromesh or similar product and re gloss. If it is necessary to repaint then I would think it is OK to paint over the gloss depending on what paints you are using. You could always shoot some color on a little sheet plastic, gloss it and then try painting over the gloss just to be sure. I hope this is helpful,
Offline IFF1418
« Reply #34 on: February 23, 2014, 11:41:59 PM »
Hi Rick,
Thank you my friend. I'll try it out and I'll see how close the roundels come.
Kind regards
Patrick
« Reply #35 on: February 24, 2014, 12:18:34 AM »
Patrixk,
What he said. ;D. The wing gives a very pleasing appearance--great soft colors and tone!  Well done Patrick.  :D
« Reply #36 on: February 24, 2014, 03:18:46 AM »
That`s a Beauty Cockpit and wing so far Patrik.
Offline IFF1418
« Reply #37 on: February 24, 2014, 06:15:29 AM »
Hello Bob and Martin,
Thank you for your very nice and friendly comments. It's much appreciated coming from such great modelers.
Patrick
Offline Dal Gavan
« Reply #38 on: February 24, 2014, 07:07:56 AM »
G'day, Patrick.
This model is coming together nicely, mate.  I also like the colours you used for the wing, would you mind telling us which colours you used?  But I really like your cockpit.  You've done the rigging very well and I like the colours you used.
As for the spots, this has happened to me when using Future/One Go/ Kleer on humid days (and sometimes with Humbrol Matt varnish as well). With Future, another light coat over the spots can make them disappear (it also works if decal setting solution has made the Future go cloudy).  Or you could incorporate the spots into weathering, if you are going to weather the model?
You're doing well, Patrick.
Dal.
Offline IFF1418
« Reply #39 on: February 24, 2014, 05:30:04 PM »
G'day, Patrick.
Dal.
Hello Dal,
Thank you very much for your appreciation. I'm very pleased with them. The cockpit although not bad doesn't come close to the one you did. The colors were a great problem to me because it was the first time I did the French Camo. Now Bo advised me to look at the instruction booklet of the WnW Salmson and looking at the schemes I really found there what I was looking for. I used all Tamiya acrylics
Aluminium Dope :  2 parts Flat Aluminium XF16
Offline IFF1418
« Reply #40 on: February 24, 2014, 05:42:57 PM »
Oops my post  was send accidently!
Here we go again
Aluminium Dope            2 parts Flat Aluminium XF16
                                    1 part Sky Grey  XF19
Beige Dope                   10 parts Desert Yellow XF59
                                    1 part Aluminium Dope
Light Green                   10 parts Olive Green XF58
                                    10 parts Flat Yellow XF3
Dark Green                    10 parts Field Grey XF65
                                    1 part Alu Dope
Chestnut Brown              10 parts Nato Brown XF68
                                     1 part Alu Dope
Black                              Nato Black XF69
Patrick, I wonder if you could repaint the areas with the spots with the original colours,
then try the varnish again?  The dividing line between colours is very nicely done. Could
you tell me what you used for the CDL?  Good work, my friend.  I look forward to the next
steps.
Ernie I forgot to answer your question about the CDL :
Tamiya acrylic "Buff" XF57
Kind regards my friends
Patrick
« Reply #41 on: February 24, 2014, 07:58:44 PM »
Thanks Patrick...the Buff is a good choice.
Offline IFF1418
« Reply #42 on: March 01, 2014, 08:40:51 PM »
Hello,
I finally decided to have a try in modifying the pilot's seat myself, so Ron is a bit more at ease. I can use its (much better!) seat in another Nieuport later on. I tried to make it look a bit worn. It's my first experiment with those slats and the miniput. Thank you for stopping by.
Kind regards
Patrick
« Reply #43 on: March 01, 2014, 09:22:54 PM »
Patrick,
You have done a BEAUTIFUL job on modifying the seat! I tried but came no where near your results! Lovely work!!
Offline IFF1418
« Reply #44 on: March 01, 2014, 09:34:26 PM »
Hi Rick,
Now that's a very conforting appreciation. Glad you like it. It's not coming near Dal's seat, but I will be glad now to incorporate it in the interior. Many thanks my friend!
Kind regards
Patrick
