Author Topic: WNW Fokker DVIIF: Erich Lowenhardt, Jasta 10  (Read 75872 times)
Offline Vladimir Ziska
    • Nordland Models
Re: WNW Fokker DVIIF: Erich Lowenhardt, Jasta 10
« Reply #105 on: November 07, 2013, 04:00:34 PM »
Hi Rick,
superb difference between fabric and metal parts.
Vladimir
« Reply #106 on: November 09, 2013, 02:44:42 AM »
Thanks Vladimir! I greatly appreciate your comment!I have made very slight progress. More photos later or perhaps tomorrow night
« Reply #107 on: November 09, 2013, 11:27:43 AM »
Anxious to see your next photos, Rick.  You do good work!
Offline IFF1418
« Reply #108 on: November 09, 2013, 09:11:18 PM »
Hi Rick,
Like Ernie I'm looking forward to see your next pictures. Can't wait.
Kind regards
Patrick
Offline KONG
  • A day without sunshine is like...night
« Reply #109 on: November 11, 2013, 12:48:04 PM »
Got this one in my stash, and I hope when I get around to it
I make as great a job as you . . . I havent attempted lozenge
decals yet, so Im watching you closely . . Great work  8)
"If I could only have brought him down alive..."
« Reply #110 on: November 12, 2013, 04:10:07 AM »
Hello Rick:
I am just now catching up on your build.  I think you have done an outstanding job with the yellow.  You can see the lozenge through the overspray but it isn't overwhelming.  It looks just right.  Yellow is one of those colors, (a primary color) like red that if not done right tends to look toy like.  You have done well and it certainly doesn't look toy like.  It looks like a simple scheme but is quite difficult to pull off.  I can't make out the subtle weathering you have done due to your camera difficulties but I can make out some rib details etc.  I am working on the DVII F at this time as well and am about four pages behind you, so I will be watching your build as you progress.
« Reply #111 on: November 12, 2013, 10:28:17 AM »
Thanks Ernie, Taking a little longer than I thought. The fin for some reason gave me fits. Ended up removing the paint(and Lozenge twice). I finally left off the lozenge and sprayed a straight yellow. I will go back with some cadmium yellow oil to simulate the lozenge beneath. The fin and rudder are attached now and the cross is on. More tomorrow.
Hi Rick,
Kind regards
Patrick
Thanks Patrick!
Dave,
I am sure you will be more than up for the challenge! I am still debating whether to pre or post shade my lozenge on the wings. Right now I am leaning towards pre  :-\
Hello Rick:
Mark, Thanks for the comments! Yes the yellow is an interesting color to use in an overpaint! As I said earlier, deciding when to stop painting is the key! I am Looking forward to seeing your build!!
Offline Ian from Doncaster
« Reply #112 on: November 12, 2013, 10:40:31 AM »
This scheme is really going to stand out Rick, very effective.  With my build rate I'll get to do my DVII in about 3 years...
« Reply #113 on: November 12, 2013, 10:55:00 AM »
Thanks Ian, that is one reason I chose the scheme! As for build rate I could very well set a personal record for the last ten years or so. I have completed ,since January this year:
1. WNW Fokker DVII:Fok early
2. WNW Sopwith Triplane
3. Roden Nieuport 28 1/32nd
If I finish this one before December 31st that will be 4, yes FOUR finished in one year!
« Last Edit: November 12, 2013, 02:46:46 PM by RAGIII »
Offline IFF1418
« Reply #114 on: November 12, 2013, 04:48:42 PM »
Hi Rick,
About build rate, one must consider the rate of difficulty of the builds too, and also the grade of finishing which is always of high standard in your builds (e.g. your Nieuport) . So I think I will easely beat (downwards) your building speed. And look at the one your busy with : outstanding!
Kind regards
Patrick
« Reply #115 on: November 13, 2013, 02:57:37 PM »
Hi Rick,
Kind regards
Patrick
Thanks Patrick! I have made some progress and My Aviattic Lozenge( Fokker Built Cookie Cutter) decals arrived today!  :D So now a question. Those that have used Aviattic decals, Should I pre shade?, Use pastels? Oil washes along the ribs like the DVa pictures I posted earlier? What have you had success with? Let me know!
« Reply #116 on: November 15, 2013, 09:16:17 AM »
I have done the preshading using Artists Oils. My method is straight forward. Mix 50/50 Mars Black and Burnt Sienna. With a small pointed brush make a line or dots next to the rib edge. Wipe running parallel to the rib, ( this gives an edge to the rib) then rub away excess going across the rib. This outlines the ribs and adds just a touch of color between. The pictures show the process. The final pictures show the wings glossed and ready for the decals.
« Last Edit: November 15, 2013, 11:24:45 AM by RAGIII »
« Reply #117 on: November 15, 2013, 09:32:31 AM »
Looking forward to seeing how this (great looking) pre-shading looks when the decals go on.  I have some Aviattic lozenge too, so I watch with interest!
« Reply #118 on: November 15, 2013, 10:03:36 AM »
Awesome preshading technique, amigo!  Gonna have to give that one a try.  What's the drying time on the oils?
Offline Rob Hart
« Reply #119 on: November 15, 2013, 01:43:47 PM »
What a nice build! Loads of useful tips too.
