Author Topic: Fokker Scourge  (Read 19282 times)
Offline miamiangler
Re: Fokker Scourge
« Reply #60 on: June 10, 2013, 02:56:06 AM »
Thanks for the comment s ,
     Today I got some of the metal work done on the final pieces . All that is left to do is the jeweling which I will do in a few day`s . I finished the painting of the wings and fuselage. I added some Tamiya smoke to show the staining as seen on some of the photo`s of the real Fokker EIII`s. The decals went on with no problems ,but on the wings I used a mix of water and white glue before placing the large decals .
@ Ernie I used the Product Bare Metal Foil .It has a tacky backing that makes it easy to apply .
@ Isitwindyyet I put the foil on the part first then I use the demal tool with a toothpick and a small disk of sand paper glued on the end. Before doing the jeweling on the finished product I practice on a foiled piece of plastic to get right size of the lines.
That`s all for now ,
                             Willi
« Last Edit: June 10, 2013, 02:58:17 AM by miamiangler »
Re: Fokker Scourge
« Reply #61 on: June 10, 2013, 07:10:49 AM »
Willi,
The painting on this one is superb as usual with your work! Well Done!!
Airboss 55
Re: Fokker Scourge
« Reply #62 on: June 11, 2013, 06:28:15 AM »
It is absolutely amazing to see the various way we put these planes together.  I learn something new every time I visit forum.  Thanks for sharing your skills with us.
Rick
Re: Fokker Scourge
« Reply #63 on: June 11, 2013, 07:49:04 AM »
Excellent work. The fuselage paint work/staining is perfect.
Offline miamiangler
Re: Fokker Scourge
« Reply #64 on: June 11, 2013, 09:28:51 AM »
Thanks Rick and Airboss (Rick):),
  Here`s what I have done today. All metal work done and the Taurus engine is installed .
thanks,
    Willi
Re: Fokker Scourge
« Reply #65 on: June 11, 2013, 10:25:54 AM »
Very sharp. Are you going to dull down/weather - just a bit- the metal work?
Offline miamiangler
Re: Fokker Scourge
« Reply #66 on: June 12, 2013, 05:14:09 AM »
Hi Steve ,
   I will do some weathering , with the camera flash it looks very bright. the wings still need some staining .
        Willi
Online lcarroll
Re: Fokker Scourge
« Reply #67 on: June 12, 2013, 11:27:39 AM »
Willi,
    Beautiful work, you have a real winner coming here!
Lance :)
Offline miamiangler
Re: Fokker Scourge
« Reply #68 on: July 20, 2013, 06:40:14 AM »
Thanks guy`s for your comments ,
It`s been a long while since I have looked at this kit . I have been waiting for the .04mm tubing to arrive from JBModel but no luck after e-mails . So now if anyone knows a company that sells micro tubing I can finish the Endecker and tripe I have been working on.
  Well this is not WW1 but this showed up at my doorstep today .One of my Fav`s  little pricey but well worth it !
Thanks ,
             Willi
Re: Fokker Scourge
« Reply #69 on: July 20, 2013, 09:18:47 AM »
Willi,
Good to hear from you. I hope you get that tubing soon as I am really looking forward to seeing your continued work on both projects!
Re: Fokker Scourge
« Reply #70 on: July 20, 2013, 09:33:42 AM »
Hi Willi...I've got some 0.4mm brass tube from Model Hobbies in the UK.
Hopefully this will help...I'm really anxious to see more of your Eindecker.
http://www.modelhobbies.co.uk/shop/advanced_search_result.php?search_in_description=1&inc_subcat=1&keywords=brass+tube&x=182&y=7
Re: Fokker Scourge
« Reply #71 on: July 20, 2013, 09:55:09 AM »
Looks big, Willi.  Where's the top wing?
Offline miamiangler
Re: Fokker Scourge
« Reply #72 on: July 20, 2013, 11:47:34 AM »
Willi,
Hi Rick,
  I have been doing some diving and snorkeling on the weekends . Also work on my reef aquariums that I let go because of my modeling . Everything is back in order so I can start work as soon as I get some tubing . I dropped the tripe and it suffered some damage . working late at night and sleepy is not good for modeling !
                                      Willi
Offline miamiangler
Re: Fokker Scourge
« Reply #73 on: July 20, 2013, 11:50:21 AM »
Thanks Ernie ,
          Tubing will be ordered!
                            Willi
Offline miamiangler
Re: Fokker Scourge
« Reply #74 on: July 20, 2013, 11:55:19 AM »
Hi Bud ,
  If I guess right it`s about the size of a 1/48th Lancaster .  Sorry no top wing on this bird but it will be fun doing the camo on this A/C.
Willi
