Author Topic: Fokker Scourge  (Read 19280 times)
Offline miamiangler
Fokker Scourge
« on: April 07, 2013, 02:30:18 AM »
Hello Everyone ,
  I will be starting on the Fokker E.III (late) From WNW. It was a Christmas present from my daughter . I will be using the engine from Taurus Models and seat belts from HGW.
  I started with the engine first . There`s lots of tiny parts so you have to take your time here !
Here`s the finished engine :
Thanks ,
Willi
Re: Fokker Scourge
« Reply #1 on: April 07, 2013, 02:39:00 AM »
   Willi,
Outstanding first progress my friend. Love that engine,wonderful details. Looking forward to following along with this latest opus.
Re: Fokker Scourge
« Reply #2 on: April 07, 2013, 04:05:02 AM »
Brilliant work on the engine, Willi.  Those Taurus engines certainly build up into magnificent replicas, with the proper skills applied.
Offline stefanbuss
Re: Fokker Scourge
« Reply #3 on: April 07, 2013, 04:44:29 AM »
I hope the engine fits into the cowling. I will be watching this very closely, as that Fokker is one my watchlist.
Stefan
Offline miamiangler
Re: Fokker Scourge
« Reply #4 on: April 07, 2013, 05:15:21 AM »
Thanks Guys ,
 Since this is the first Taurus engine I built . It came out O.K ,but next time I am going to put the small parts (#7 &#8) together first then glue the parts to the  main body #1. Then put part  #2 on to part #1 . then add #9 and make sure it is in the right position . Then add a small wire to part #9 that way it makes it easy to slide on  part#5 . Then you can add the spark plugs and add part # 8 which needs to be cut to size . Take your time here .rather cut it a little at a time or it will be too short ! Becareful when cutting part #5 ,I ruined 3 of them till I got the hang of cutting the part off the resin block. Thanks to Mr. Lukasz he sent me replacement parts . So a big Thank you goes out to him . Instead of using part #10 it was easier using a length of wire and then cutting it to it`s size . I hope this helps as this is how I will be building the next one when I build another Fokker E.II (early ).
   As for the fit in the cowling .It is tight and the cowling will have to be thinned down .
        Willi
Offline Vickers
Re: Fokker Scourge
« Reply #5 on: April 07, 2013, 07:15:21 AM »
Looks very nice, Willi. Highly detailed and suitably grimy. Thanks for the build tips- I'll keep your proposed order of assembly in mind when the time comes for mine!
Re: Fokker Scourge
« Reply #6 on: April 07, 2013, 07:56:31 AM »
Very nicely done Willi, the detail on the engine looks great and thanks for the tips on assembly, this will assist a lot of people.
Offline Whiteknuckles
Re: Fokker Scourge
« Reply #7 on: April 07, 2013, 08:55:07 AM »
Great engine Willi, nicely done.
Eternal Apprentice
Offline michael
Re: Fokker Scourge
« Reply #8 on: April 07, 2013, 06:39:32 PM »
Great start Willi  :)
looking forward to the rest of your work on this kit.
michael
Offline miamiangler
Re: Fokker Scourge
« Reply #9 on: April 08, 2013, 08:42:39 AM »
Thanks for the kind comments,
  I started work on the cockpit . Here`s some photo`s of what I have done .
Thanks ,
Willi
Online lcarroll
Re: Fokker Scourge
« Reply #10 on: April 08, 2013, 10:31:52 AM »
Very nice start Willi, that Taurus Engine is a jewel and you've done a beautiful job thus far on the cockpit. This will be an enjoyable, and very educational Build to follow.
Offline miamiangler
Re: Fokker Scourge
« Reply #11 on: April 09, 2013, 01:11:18 AM »
Thanks Lance ,
  I think the engine will look great in the Fokker E.III just too bad not much will be seen . I might for the next Fokker (In the Future ) I`ll build it with out the cowling .
  Here`s some more progress :
 I am going to use matte bare metal foil for the metal parts . I have been trying for a few weeks to get the right pattern and think I am getting close to the effect I want .
 Heres more work on the pit :
 I didn't use foil on the dash I tried using the painting method . I also added copper wire and a clear plastic rod for the pulsameter A35 .To bad WNW did not make this part in clear plastic !
That`s all for now ,I`m just waiting on the HGW seat belts to arrive .I hope soon ::)
     Willi
Re: Fokker Scourge
« Reply #12 on: April 09, 2013, 01:33:43 AM »
  Willi,
Outstanding metal works my friend. Excellent thread to be following,lots of great tips.Well Done.
Re: Fokker Scourge
« Reply #13 on: April 09, 2013, 02:22:37 AM »
Fantastic looking cockpit, Willi!
Re: Fokker Scourge
« Reply #14 on: April 09, 2013, 03:21:35 AM »
Hello Willi:
Outstanding work on the engine and cockpit.  I have one of these engines and your comments will be helpful when I tackle mine.
I will be following this as you progress through the build.
