Author Topic: Fokker Scourge  (Read 19115 times)
Re: Fokker Scourge
« Reply #30 on: April 16, 2013, 12:34:44 PM »
Beautiful work on the prop and MG, Willi.
Offline miamiangler
Re: Fokker Scourge
« Reply #31 on: April 19, 2013, 03:55:20 AM »
Thanks Guy`s ,
   I have decided to do Manfred Von Richthofen`s A/C. I am still waiting for parts to arrive in the mail so not to much progress has been done on the Model . I just painted and decaled the tail . I still not sure which turnbuckles to use .The R&B productions or GasPatch models ?
Thanks , Willi
Offline dirk
Re: Fokker Scourge
« Reply #32 on: April 19, 2013, 03:34:53 PM »
Hi Willi,
great progress on your fokker. I am impressed by the look of the metal parts. The foil you've used is very convincing. I will also be interested on your progress on the cowlings. Is it possible to use the foil on those round /curved parts? The resine engine is a masterpiece and looks very realistic.
I think its time for a fokker group-build and especially because I am on the same stage in my build,  i will have a close look on your progress.
With kind regards,
Dirk
Re: Fokker Scourge
« Reply #33 on: April 20, 2013, 12:18:03 AM »
Willi,
   How did you add the pattern/burls to the bare metal foil? Also, can you confirm which Taurus Engine Kit you used? Coming along beautifully BTW.
Offline JoeDxMB
Re: Fokker Scourge
« Reply #34 on: April 22, 2013, 02:27:42 AM »
Some of us are  are modelers and some are true artists in addition.
You are the latter. :)
Offline miamiangler
Re: Fokker Scourge
« Reply #35 on: April 23, 2013, 08:44:47 AM »
Willi,
Hi Lance ,
  I used a demel tool with a tooth pick and a small 1/16th inch disk glued to the end . I used kit #D3208.
  Thanks ,
         Willi
Offline miamiangler
Re: Fokker Scourge
« Reply #36 on: April 23, 2013, 08:46:08 AM »
Thanks Joe for your kind comment !
                                              Willi
Re: Fokker Scourge
« Reply #37 on: April 23, 2013, 11:41:36 AM »
Willi,
Hi Lance ,
  Thanks ,
         Willi
Thanks for the info Willi, I'm "all over it"! ;)
Offline miamiangler
Re: Fokker Scourge
« Reply #38 on: April 27, 2013, 10:46:19 PM »
Here`s the cowling done in bare Metal foil  (two pieces ). I dry fit and left the engine in the cowling so not to damage the engine :).
  Thanks ,Willi
Re: Fokker Scourge
« Reply #39 on: April 28, 2013, 12:35:55 AM »
Perfection.
Re: Fokker Scourge
« Reply #40 on: April 28, 2013, 03:40:18 AM »
Truly gorgeous, Willi.  So glad it fits after all that work.
Re: Fokker Scourge
« Reply #41 on: April 28, 2013, 04:45:38 AM »
Gorgeous cowling and engine Willi! ;D  Thanks for sharing this new technique. :)
Offline dirk
Re: Fokker Scourge
« Reply #42 on: April 28, 2013, 07:55:48 AM »
Man that's great...
Dirk
Re: Fokker Scourge
« Reply #43 on: April 28, 2013, 09:05:33 AM »
   Willi,
Your cowl is nothing short of excellence my friend. Awesome technique!
Re: Fokker Scourge
« Reply #44 on: April 28, 2013, 11:50:17 PM »
Amazing work!! Its like you formed it out of actual metal!!
