Author Topic: WnW Sopwith Snipe 1:32 scale  (Read 38528 times)
Re: WnW Sopwith Snipe 1:32 scale
« Reply #60 on: February 17, 2013, 06:14:52 AM »
Thank you for all your comments.
Don't be put off by what I said about assembling the cockpit, it was probably just me. Other modelers will find a different way to get things together and probably a lot easier, I tend to do things the hard way. One thing I will say though, the fit of parts is brilliant, every locating pin aligned with the appropriate hole perfectly and everything ended up square and true. A trial fit between the two fuselage halves show it as being very exact, the fuselage closes up with no gaps or any interference with the cockpit frame work, another one of Wingnuts expertly engineered kits.
Offline Flip Hendrickx
« Reply #61 on: February 18, 2013, 06:10:09 AM »
Great build, as always Des :-)
Can't wait for my Snipe to arrive (will have to hold back on it though... 3 other builds to finish first :-))
Flip
« Reply #62 on: February 18, 2013, 08:03:15 PM »
Some more photos showing where I am up to at the moment. I did a trial fit of the cockpit coaming, it fits beautifully, the machine guns are also fitted and slotted into their positions perfectly. I have done the tail skid assembly with some rigging as well, the stringers on the inside of the fuselage sides have been painted so now the fuselage is ready to be buttoned up. I fitted the cockpit assembly to one side of the fuselage to see how the fit would be, as per Wingnuts usual standards it fitted exactly.
Offline Pete Nottingham
« Reply #63 on: February 18, 2013, 08:54:13 PM »
Brilliant build as usual Des, well done mate, look forward to more updates.
Pete.
« Reply #64 on: February 18, 2013, 11:04:41 PM »
Beautiful work. Looking forward to the next stages.
Offline Ian from Doncaster
« Reply #65 on: February 18, 2013, 11:13:11 PM »
Absolutely tip top as usual Des.
Do you ever botch a model? ;)
« Reply #66 on: February 19, 2013, 05:51:18 AM »
Thanks for all the very kind comments.
Ian - Yes, I have my fair share of dramas, some builds are easy, some are a real pain in the butt, but I have never tossed a model,yet......
I have the fuselage buttoned up and the cockpit coaming fitted, it all went together so easy, the cockpit fitted perfectly and the two fuselage halves matched up without any gaps.
« Reply #67 on: February 19, 2013, 06:39:38 AM »
Hello Des:
You are certainly going to town on this one.  So far looking real good.  Typical of your craftsmanship Des, a nice clean, well detailed build.
Looking forward to more.
« Reply #68 on: February 19, 2013, 08:15:33 AM »
  Des,
As always your projects are the finest examples of excellence and the highest levels of craftsmanship. Looks as if this project is moving along at a fast clip too. The Snipe fuselage is outstanding my old friend. As always looking forward to seeing even more .
« Reply #69 on: February 19, 2013, 08:10:32 PM »
Looks to be one beautifully engineered kit from where I'm sitting.
vB
« Reply #70 on: February 21, 2013, 01:04:33 PM »
I splashed a bit of colour on the fuselage today, I used Gunze Brown Violet for the darkish green and Gunze Barley Gray for the front bits. The engine cowl is only just sitting in position for a trial fit. I also did some very subtle shading under the wing.
Offline LindsayT
« Reply #71 on: February 21, 2013, 01:56:35 PM »
That kit fits like it grew that way. Looking great, Des.
« Reply #72 on: February 21, 2013, 02:02:00 PM »
I agree Lindsay, so far the fit of parts has been nothing short of perfect, this would have to be the best engineered kit on the market, I have never built a model where absolutely no sanding or filing is needed to make parts fit properly, well done Wingnuts.
« Reply #73 on: February 21, 2013, 11:01:43 PM »
Now, that's an impressive statement. How much better can they get I wonder? The review and "re-visit" process WNW uses during final Kit development as mentioned by Richard A. in the interview here is certainly working. Very impressive, got to get moving on my order of this one sooner rather then later. Any forecast on availability date for Barker's Early version decals, Rowan?
« Reply #74 on: February 22, 2013, 12:04:21 AM »
It's turning into a real beauty Des. Everything looks so clean and precise as always.
