Author Topic: WnW Sopwith Snipe 1:32 scale  (Read 38356 times)
Re: WnW Sopwith Snipe 1:32 scale
« Reply #45 on: February 15, 2013, 09:21:40 PM »
Nice looking cockpit. Fine progress! And encouraging to a purchase at a certain website from a far-off country... ;)
« Reply #46 on: February 15, 2013, 11:25:54 PM »
You've got a great looking cockpit going there Des. I particularly like the instrument panel. Is the seat identical to the one supplied in the Bristol Fighter kit? If so, I'll have to break out the grinder again to remove the extra plastic on the back of the caning.
« Reply #47 on: February 15, 2013, 11:27:36 PM »
Nice! Tach cable really looks the part ... What is it? guitar string?
Offline michael
« Reply #48 on: February 16, 2013, 12:51:29 AM »
fantastic craftsmanship as ever Des.
michael
« Reply #49 on: February 16, 2013, 03:20:50 AM »
Hello Des:
This is shaping up nicely and looking good to boot.  Thanks for the update.  I will be checking it out as I am thinking I will be seeing this under the "birthday tree" next week, and I too am planning on the Russian scheme.
« Reply #50 on: February 16, 2013, 05:39:54 AM »
Thanks guys for your comments, all very much appreciated.
Chris - Wingnuts have improved their wicker seat, it no longer has the extra thickness of plastic at the back of the seat covering the crossed open weave section, so drilling it out was very easy as the plastic between the weave was only very thin, made life a lot easier.
Bo - the Tacho drive is a very small spring, it is 0.5mm in diameter and 20mm long, easy to fit and very flexible, also the correct colour.
« Last Edit: February 16, 2013, 05:42:58 AM by Des »
Offline kornbeef
« Reply #51 on: February 16, 2013, 07:46:11 AM »
Well its looking very promising so far I have to say. Looking forwards to further updates.
Keith
« Reply #52 on: February 16, 2013, 12:31:55 PM »
Coming along beautifully Des. I may have to order this earlier then I planned, and following this build further may just lead to impulsive behavior in that regard!
Lance ;)
Offline miamiangler
« Reply #53 on: February 16, 2013, 12:50:24 PM »
I like   what you have done . I might have to rethink  my next purchase from WNW .this may be the first none German kit I buy  ;)
« Reply #54 on: February 16, 2013, 07:58:42 PM »
I managed to get the cockpit all together tonight, and all the rigging and control cables are also fitted. Assembling the components for the cockpit proved a little frustrating, apart from holding the rear fuel tank and floor boards, I had to align the control column, the rudder bar, the instrument panel and the forward fuel tank all at the same time, and while doing this trying to keep all the rigging and control wires out of the way. It all eventually went together with everything fitting perfectly, the rigging was finished off after the cockpit was assembled. The whole lot was given a spray of Humbrol Satin clear. Seat belt still needs to be added.
« Last Edit: February 16, 2013, 08:29:39 PM by Des »
Offline petrov27
« Reply #55 on: February 16, 2013, 11:00:38 PM »
great interior there - very nice - very complicated!
-Patrick
« Reply #56 on: February 16, 2013, 11:09:06 PM »
Oh, oh . . . if you found it frustrating, I'm more than a little apprehensive about how I'll fare with it.  :-\
« Reply #57 on: February 17, 2013, 12:16:11 AM »
Wow - pretty good - so youve built a model before?.... ;)
« Reply #58 on: February 17, 2013, 02:17:28 AM »
Brilliant work on the office, Des!  I'm a little disappointed to read that cockpit assembly is a bit tricky.  Like Chris, I hope I'm up to it.
« Reply #59 on: February 17, 2013, 03:39:52 AM »
Hello Des:
Looks good.  A little taken aback to read about your difficulties with the cockpit interior.  It looks complex and I am sure that is part of the problem.  To quote Julias Ceasar:  "Vini, Vidi, Vici", Looking forward to the next update.
