Author Topic: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6  (Read 42255 times)
Offline Umlaufmotor
Re: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6
« Reply #90 on: January 15, 2024, 10:27:25 PM »
Many thanks to all of you for your kind comments
Offline Umlaufmotor
« Reply #91 on: January 15, 2024, 10:28:53 PM »
Magnificent work, Bertl! And your English translations are perfectly clear... I'd never heard of Deep L before, but as it seems to work so well for you I looked them up and may start using it myself instead of Google Translate.
In fact... hervorragende Arbeit, Bertl! Und deine englischen Übersetzungen sind absolut klar... Ich hatte noch nie von Deep L gehört, aber da es bei dir so gut zu funktionieren scheint, habe ich es nachgeschlagen und werde es vielleicht selbst anstelle von Google Translate verwenden.
(how was that? :) )
PERFECT!  ;)
Offline Umlaufmotor
« Reply #92 on: January 15, 2024, 10:33:50 PM »
I also continued to work a little on the Roland C.II engine.
The spark plugs are missing on the wingnut engine.
Suitable and excellent replacements can be found in the Taurus range.
The spark plugs were painted with Mr.Metalcolor "Iron" (the body with the wrench size attachment), Tamiya "Gloss-White" (the insulator) and Mr.Metalcolor "Brass" (the connection for the ignition cable).
I added the copper sealing rings, the ignition contacts and the eagle decal on the insulator body. Then weathering with oil paint. Here is a greatly enlarged macro photo of one of the twelve spark plugs needed
The biggest challenge was the D.R.P. engraving on the flank of the wrench size. ::)
All spark plugs were then attached to the cylinder head with two-component adhesive.
« Last Edit: January 15, 2024, 10:42:31 PM by Umlaufmotor »
Offline Umlaufmotor
« Reply #93 on: January 15, 2024, 10:38:47 PM »
No, the "super-macro-Spark-plug-picture" is of course just a joke  ;D
The spark plug is an original, which was allegedly removed from the engine of a Fokker D.VII.
The ignition cables were made from annealed 0.25mm thick copper wire.
Here only one side of the engine is finished.
Servus
Bertl
« Reply #94 on: January 16, 2024, 01:20:05 AM »
Toll!
« Reply #95 on: January 16, 2024, 06:19:54 AM »
Magic work Bertl, and I'm so pleased you persevered to paint the maker's mark on each sparkplug  ;) ;D
Offline Thumbs up
« Reply #96 on: January 16, 2024, 07:44:45 AM »
Outstanding work as usual!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #97 on: January 16, 2024, 06:14:43 PM »
Wow that engine and plugs look great  ;D
//Ben - @AngryJazz_Models
« Reply #98 on: January 19, 2024, 05:45:23 PM »
Breathtaking!
But where do you fool us again? I can hardly take pics of originals from your model parts.
« Reply #99 on: January 19, 2024, 07:32:49 PM »
More lovely work, stunning details. It is very interesting to see your approach here, I've always glued the cylinders to the engine block before painting but this approach makes adding the plug wire detailing easier.
« Reply #100 on: January 20, 2024, 10:38:15 PM »
I am baffled by your attention to detail and realistic weathering.
This is a great build Bertl!
Offline Pup7309
« Reply #101 on: February 08, 2024, 06:23:08 PM »
Omg I’m speechless at your abilities.
‘Not all who wander are lost‘
« Reply #102 on: February 09, 2024, 12:50:28 AM »
For a second I really had thought the photo of the spark plug was really an enlargement...
BTW ... Fantastic work Bertl
« Reply #103 on: February 12, 2024, 09:31:38 PM »
Beautiful work.  You really had me with the picture of the original plug!
Offline Umlaufmotor
« Reply #104 on: March 23, 2024, 07:14:22 AM »
Thank you all very much for your kind comments.
The Roland C.II is currently on a break, I am busy with a WingnutWings Fokker D.VII (OAW).
This model belongs to a fellow model builder who does not have the possibility for airbrush painting.
So no primer etc. as a base for the Aviattik-Lozenge.
Well, we both arranged a deal - he assembles the model in parts and I do the painting, decaling, sealing and weathering work for him.
When my part of the work is done, I will send it back across Germany to him and he will then assemble the model completely.
I used Tamiya Gloss-White as a base for the Aviattik-Lozenge.
The remaining colors were used according to the instructions in the WingnutWings building instructions.
The Aviattik-Lozenge is excellent to work with, but does not fit the model correctly in terms of the ribbon spacing.
Here it is advantageous to divide the wing lozenges into smaller sections in order to "adjust" the rib spacing somewhat.
The Rudolf Windisch marking of the Jasta66s shows a very early Fokker (OAW) 2035/18 from the first construction batch 2000-2199.
The decals are the Lifelike Fokker D.VII decals #32019 part 4.
Be careful with these decals with decal softer, they react very VERY sensitively.
Servus
Bertl
« Last Edit: March 23, 2024, 07:25:05 AM by Umlaufmotor »
