Author Topic: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6  (Read 42371 times)
Offline Umlaufmotor
Re: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6
« Reply #120 on: May 10, 2024, 03:45:32 AM »
After the Windisch-Fokker and before the start of a new project, I found a little time to finish painting the Orcarina exhaust of the Roland C.II.
The colors I used were Mr. Metallcolor “Iron”, “Dark Iron” Mr. Hobby “Rust Red” and some watercolor “Brown” and “Black”.
The colors were applied in the order as written.
All colors were dabbed on with a short-haired brush, only the Mr. Hobby “Rust Red” was sprayed very heavily diluted with the airbrush.
Before the watercolors dry, dab them irregularly with a cotton swab.
The Mr. Metalcolor paints are polishing paints.
Do NOT (!) polish them after dabbing on with the short-haired brush.
The worn and matt-looking effect would be lost.
At the very end, after the dabbed-on watercolors, heavily diluted with water, have dried, they can be very carefully scratched over with a brush that has very stiff bristles.
These scratches make the metal colors, hidden under the watercolors and the rust red, shine a little.
I hope the meaning is clear, because I think this last two sentence are difficult to translate.
In the original, the exhaust was directly in the propeller wind.
For me, this meant that swirled-up soil/dirt and oil burnt onto the surface by the heat of the exhaust should be visible on the exhaust.
Servus
Bertl
« Last Edit: May 11, 2024, 04:48:48 AM by Umlaufmotor »
Offline Umlaufmotor
« Reply #121 on: May 10, 2024, 03:47:55 AM »
Absolutely brilliant - from start to finish. Congrats, Bertl!
Thank you Gary.
Yes, it was a funny experience.
But my colleague seems to be satisfied, the next model, the Dilthey-Albatros, is already in the works.
« Reply #122 on: May 10, 2024, 04:50:32 AM »
That is an Outstanding effect on the exhaust! I will keep this formula for use on future projects!
« Reply #123 on: May 10, 2024, 12:14:02 PM »
Sie sind ein Künstler, mein Herr...
« Reply #124 on: May 10, 2024, 04:15:32 PM »
Great work with the co-op build! The painting of the exhaust sounds straightforward, I'll have to give it a go to see if it really is, because the effect is exactly what I've been looking for!
Thanks!
Fredrik
Offline Umlaufmotor
« Reply #125 on: May 10, 2024, 08:40:46 PM »
Thank you so much, Rick, Dutch and Fredrik!!
Servus
Bertl
Offline Umlaufmotor
« Reply #126 on: May 11, 2024, 12:16:19 AM »
Since I just had the right colors at hand, I also painted the exhaust for the next project.
This is the exhaust of a Wingnut Wings Albatros D.Va.
I used a hot-drawn plastic-sprue to create the flare at the end of the exhaust.
Then I drilled and milled out the opening of the exhaust .
In the end, the wall of the sheet metal should be wafer-thin.
The procedure for painting is exactly the same as for the Roland exhaust.
Servus
Bertl
« Reply #127 on: May 11, 2024, 01:07:54 AM »
Perfection!
Offline richard.kiss
« Reply #128 on: May 11, 2024, 04:24:36 AM »
Amazing job with the exhaust. I'll try the technique this weekend. Thanks for the description!
« Reply #129 on: May 11, 2024, 06:54:43 PM »
Lovely work, I love that sprue at the end of the Albatros exhaust. Perfection!
Offline William Adair
« Reply #130 on: May 11, 2024, 10:26:02 PM »
Absolutely gorgeous! Thank you for sharing the recipe too. I can't wait to give it a try  :D
Offline Rafael Berlin
  • e^(i*pi)+1 = 0
« Reply #131 on: May 12, 2024, 11:57:29 PM »
Same for me, looks terrific. I for sure will give it a try. Thanks a lot, Bertl!!
Offline AngryJazz
    • @AngryJazz_Models
« Reply #132 on: May 30, 2024, 06:19:43 PM »
Wow this effect is perfect! My go to color is also the Mr Metal Colors - but i usually airbrush them. I have to try the brush method next time.
Thanks for sharing  :)
//Ben - @AngryJazz_Models
Offline Umlaufmotor
« Reply #133 on: June 10, 2024, 09:28:38 PM »
Thank you very much for your many kind approvals.
Servus
Bertl
« Reply #134 on: June 10, 2024, 09:38:17 PM »
If I had only 1% of your skills, I would be a very happy man...
