Author Topic: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6  (Read 42311 times)
Re: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6
« Reply #150 on: June 21, 2024, 03:24:03 AM »
Beautiful work!!
I enjoy playing with my watercolor pencils.
Offline AngryJazz
    • @AngryJazz_Models
« Reply #151 on: June 28, 2024, 07:44:52 PM »
Its really impressive! I have to try it next time!  ;D
//Ben - @AngryJazz_Models
« Reply #152 on: July 08, 2024, 10:41:43 PM »
If taken from the correct angle one could not discern whether they were real or scale models! Amazing!
Offline Umlaufmotor
« Reply #153 on: November 24, 2024, 02:36:53 AM »
It's been ages since I found the time to continue building the Roland C.IIa.
Almost all the work inside the fuselage had been completed by the break - in principle only the two rudder control cables still had to be installed and fixed.
Well, that's done now.
The two fuselage halves are now glued together.
I had written that the kit came from an estate.
Some of the components had already been separated from the casting branch by the previous owner.
This included the two fuselage shells. Unfortunately, the wrong tools were probably used, or the previous owner did not know that the fine, slightly raised edge on the fuselage was correct.
The production process of the fuselage must be kept in mind - it was wrapped as a left and a right shell with thin wooden strips (called wrapping technique - Pfalz-Flugzeugwerke also produced some airplanes in this way) and then both halves were joined together.
The seam of the two halves was later protected against environmental influences (moisture, dirt, etc.) with a fabric tape glued over the entire length of the fuselage.
OK, however - I had no other option than to remove the raised edge completely and to fill the glued joints of the fuselage shells cleanly.
Here is a comparison of the hull (right) as it is in the kit.
Servus
Bertl
Offline Umlaufmotor
« Reply #154 on: November 24, 2024, 02:49:47 AM »
Now that the tube of Tamiya filler had already been opened, further adhesive seams, which should not be visible later, were filled.
This concerns the lower joints from the fuselage to the wings,
the gluing seams of the complete rudder fin which can be seen next to the mounting slot of the tailplane and
of course, the two-part fairing (upper and lower part) on the nose of the aircraft, which was made of aluminum sheet.
But there is one more glued seam that should not be forgotten.
A stringer is attached directly in front of the pilot to stiffen the fuselage shell - you can hardly see it on the finished model, but it is by no means wrong if it is filled.
Servus
Bertl
Offline Umlaufmotor
« Reply #155 on: November 24, 2024, 03:00:59 AM »
A word about the assembly of the motor.
You really have to work very cleanly here when fixing the motor.
If it sits at a slight angle in the motor mount, or if there is too much paint on the inside of the glued areas, then this problem is immediately apparent when you look at the motor from the front.
This will then be slightly offset from the gap in the fairing.
I only glued the motor to the two front gluing points after I had made sure that the gaps around the spinner were all equally correct with the propeller and spinner attached.
I had milled off a lot of material on the inside of the fairing nose.
When compared to the original picture of a Roland C.II "Early" you can see that this was actually an advantage for the model.
Servus
Bertl
Servus
Bertl
« Last Edit: November 24, 2024, 03:52:20 AM by Umlaufmotor »
Offline Umlaufmotor
« Reply #156 on: November 24, 2024, 03:57:20 AM »
Enough filling - now it's time to sand with sandpaper and fine steel wool.
The repaired cockpit stringer-area was painted with a brush and Tamiya XF-66 light grey.
Servus
Bertl
Offline Umlaufmotor
« Reply #157 on: November 24, 2024, 04:16:46 AM »
Some of the Roland-Walfisch two-seaters have had their rear windows converted from hinged to sliding windows.
This was also the case with the aircraft that I would like to model.
To do this, the folding hinges were removed and a wooden strip was attached to the top and bottom of the window as a guide rail.
On the underside of the window, the fuselage ran fairly straight to the rear - a longer rail could be mounted here.
At the top, however, the fuselage was a little more rounded when viewed from the rear because of the cutout for the gun carriage.
Therefore, only a relatively short guide strip could be mounted at the top so that the window did not jam when pushed.
A small wooden block was mounted as a handle on the inside and outside of the window frame at the front.
In order to convincingly represent these features on the model, the frames of the rear windows had to be sanded down a little at the top and bottom.
The first model picture shows a kit-window where the frame has not yet been sanded down.
Here the frames have been sanded and the guide rails mounted.
I used thin strips of Evergreen material to represent the wooden guide rails.
The wooden blocks mentioned as handles are not yet glued to the windows.
I hope that it won't be nearly nine months before the next update, but I have to put the Roland C.II aside again
I'm currently finishing an Aviattic Pfalz D.VIII.
You can see a little bit of that in my avatar picture. ;)
Servus
Bertl
Offline Umlaufmotor
« Reply #158 on: November 24, 2024, 04:42:26 AM »
I almost forgot:
Back to post #153, ​​the repair of the sanded fuselage seams.
I will depict these with decals.
This is relatively easy to do, the rib band decals from Wingnut Wings do the job.
I did this many, many years ago on a Wingnut Pfalz D.IIIa - the fuselage of the Pfalz D.III/D.IIIa was also made using this wrapping technique.
When the model has been painted/primed, the rib band decals are glued lengthwise in the middle.
If necessary, two decals can be glued on top of each other if the fabric strips are to be made thicker (more raised).
Here are old pictures of the Pfalz D.IIIa model mentioned:
The model is painted silver-grey, the decal (fabric) stripes are glued on, the black paint is still missing here.
On the finished model, the fabric strips - here under the nose and between the undercarriage legs at the maintenance hatch -, are faintly visible in the side light.
The fabric band also runs under the lower wing along the fuselage centerline.
The decal (fabric) band can also be seen on the fuselage back.
Original pictures from Roland show that the fabric strips are only visible flat - here in the picture is an aircraft that has crashed, the center seam covered with fabric tape can be seen in front of the rudder fin.
I therefore think that the decals will be sufficient to represent the fabric bands.
Servus
Bertl
Offline Jorgo
« Reply #159 on: November 24, 2024, 06:27:21 AM »
Hallo Bertl!
Great that you have resumed work on the Roland C IIa, excellent as always. I also think that you can learn something from every single one of your contributions and thus make progress for your own work, thanks Bertl!
Cheers Joerg
« Last Edit: November 24, 2024, 06:32:12 AM by Jorgo »
« Reply #160 on: November 24, 2024, 06:17:21 PM »
Fabulous work Bertl, this is a joy to watch and thanks so much for sharing your in progress shots, they are very helpful.
Offline Rafael Berlin
  • e^(i*pi)+1 = 0
« Reply #161 on: November 25, 2024, 04:00:40 AM »
Wonderful work, I really love every detail and the efforts you make for every detail. Really really impressive and inspiring. All thumbs up. Thanks a lot.
Viele Gr??e aus Berlin und Danke f?r den tollen Beitrag!
Rafael
« Reply #162 on: November 25, 2024, 07:51:31 AM »
And it is written that on the 8th day, God created Bertl and on this day, Bob's Buckles gave up modelling for knitting instead... lol
You're a marvel for the hobby, Bertl.
Thank you for the inspiration.
Now, what did I do with those knitting needles...
BB  ;D ;D
« Reply #163 on: November 25, 2024, 12:04:49 PM »
Hear hear! While the Rolands aren't a family of aircraft I'd model I'm finding your build thoroughly entertaining and inspiring. Bravo, Bertl!
« Reply #164 on: November 25, 2024, 06:02:49 PM »
Amazing attention to the details and perfect execution - as always from you :-)
