Author Topic: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6  (Read 42037 times)
Re: Wingnut Wings WNW Roland C.IIa "White 2", Schusta 6
« Reply #240 on: June 19, 2026, 11:49:21 AM »
Your model is looking "mouth-wateringly" good Bertl. I haven't built a WnW kit in a year...but this one certainly whets my appetite. Very nice detail...most of which most would not strive to achieve. So very impressive.
Offline Umlaufmotor
« Reply #241 on: June 20, 2026, 05:52:20 AM »
That looks fantastic Bertl, the weathering worked really well. The aircraft looks suitably grubby and dusty but not at all overdone. Very subtle, very effective.
Thanks a lot, Nigel.
It wasn't even that easy to weather and age everything so that it all matched up.
The model wasn't assembled yet, which means I still had the fuselage, wings, and landing gear subassemblies separate.
There was a little bit risky that the subassemblies would look different and the overall look would be off - one surface dirtier than the other, and so on.
Servus
Bertl
Offline Umlaufmotor
« Reply #242 on: June 20, 2026, 05:58:20 AM »
Thanks a lot, Gary.
"mouth-wateringly"
That's exactly what I was thinking as I followed your build log for your Hampden.
It's not exactly my scale, but I was still close to ordering the kit - precisely because your great build log really made me want to build this model.
Servus
Bertl
Offline Umlaufmotor
« Reply #243 on: June 20, 2026, 06:06:32 AM »
It?s sweltering today.
I was actually planning to remove the upside-down fork from my Ducati 996, take it apart, and reinstall it with new slide bushings, new dust caps, oil seals, and fresh oil, but I'm not going to put myself through that right now.
I'd rather keep tinkering with the Roland.
The front windshield and the front machine gun are now in place.
The machine gun, however, isn't the one from the kit - it's a 3D-printed version from Gaspatch.
That said, I carved the triangular mounts between the machine gun base and the fuselage from the kit machine gun, adapted them to the 3D-printed version, and added a good deal more detail to the whole thing.
It won't have an ammunition belt, because I think the empty ammunition feed looks more interesting to the viewer's eye.
I completely reworked this ammunition feed from the kit, added a small backing plate made of plastic card, painted it accordingly, and then attached it to the model with white glue.
I crafted the spent casing ejection tube from a small brass tube that I bent to the correct shape and then chemically blackened.
This time, the Observer has to do without his machine gun (not because I?m too lazy to build it - it was practically finished right in front of me) - no, here, too, I find that the representation of the mount parts is quite sufficient.
I could, however, add the weapon at any time, because I built the mount fork in such a way that I could still fold it up and down even after it's been glued in place.
Servus
Bertl
Offline Umlaufmotor
« Reply #244 on: June 20, 2026, 06:15:06 AM »
Hmm, ..........dumb ................. I can't find any more parts in my Roland C.IIa box right now  :o
That means the thing is finished  ;D
Here's just a quick look at the latest photos from a moment ago - I think these are the last pictures in this build log.
....... the view through the pilot's eyes  ;)
Pictures of the finished model will be coming soon in "completed models".
A big thank you to all of you for stopping by, for all the nice comments and your patience  ;)
Offline Dirigible-Al
« Reply #245 on: June 20, 2026, 07:19:30 AM »
Congratulations for getting to the finish line. What a great thread to follow. Truly inspiring work. I can't wait to see it in the completed section.
Alan.
« Reply #246 on: June 20, 2026, 03:44:26 PM »
Absolutely speechless, I've been watching this open-mouthed.
Stunning work.
« Reply #247 on: June 20, 2026, 06:13:48 PM »
I guess that's one way of deciding you are done.....
Another beauty, looking forward to the completed pics.
Offline Umlaufmotor
« Reply #248 on: June 21, 2026, 11:49:10 PM »
Thank you very much, Alan, Sandy, and Nigel
Servus
Bertl
Offline Umlaufmotor
« Reply #249 on: June 21, 2026, 11:51:44 PM »
You can now find pictures of the finished model here at the link below:
https://forum.ww1aircraftmodels.com/index.php?topic=15401.0
Once again, thank you very much to all of you for visiting the built log and for your patience - as usual, it took a little longer than expected to finish the whale.
Servus
Bertl
