Author Topic: 1:32nd scale Bristol Scout C  (Read 29135 times)
Re: 1:32nd scale Bristol Scout C
« Reply #90 on: May 20, 2023, 10:56:21 PM »
Interesting approach.
« Reply #91 on: May 21, 2023, 01:25:48 AM »
I am thinking it is a "Slightly" easier Method than Masking and painting! Either way you are Insane...a good insane though  8)
« Reply #92 on: May 21, 2023, 03:56:54 AM »
I like that idea of using decal strips Mike, I look forward to seeing the results.
I love those BE2c wings!
Online Mike Norris (UK)
« Reply #93 on: May 21, 2023, 07:40:46 AM »
How it is really a fantastic work!!! excellent!
Anyway I am very interested in your black decals idea...+ linen decal
Exiting !
Xan
Hi Xan,
I realized today that I'd actually applied the decals for testing pre-shading to the top surface of the upper wing, instead of the underside  ::)
So now I can fully understand your earlier comment  ;)
As such I stripped it all off using cellotape and applied the decals to the underside of the upper wing and ailerons (original post has updated photograph) :)
« Last Edit: May 27, 2023, 05:32:18 AM by Mike Norris »
« Reply #94 on: May 21, 2023, 05:30:38 PM »
Do you use the Xtradecal stripes straight off the sheet, or do you microcoat or do something to them first? I ask as my experience with them has been less than satisfactory, breaking and crumbling as you apply. Maybe just the batches I have tried.
« Reply #95 on: May 21, 2023, 06:06:04 PM »
Hi Sandy,
Yes, that's about it.
Few seconds in warm water.
No surface preparation, apart from a smooth finish.
I use a brush to slide them of their backing sheet and position them.
Then press out residual water and apply 'MicroSol'.
They do slide around easily as there doesn't seem much adhesive on them.
But once fixed down, no problem,
« Reply #96 on: May 28, 2023, 07:05:36 PM »
I've had work done to my home, so haven't been able to model much the last week or so.
However, I'm back onto the Scout now and continuing the underside decals for pre-shading.
The upper wing, ailerons and tailplane/elevator are done.
Once I receive more 'Xtradecal' stripes, I can complete the lower wings and fuselage,
Offline Boch
« Reply #97 on: May 28, 2023, 08:39:09 PM »
Lots of it there. You put in a lot of work and it looks like a very interesting result. Can't wait to finish the wings. Beautiful work.
Lukasz
« Reply #98 on: May 29, 2023, 01:59:14 AM »
That looks like really time consuming work but I am sure the results will be Fantastic!
« Reply #99 on: May 29, 2023, 04:56:31 AM »
While I wait for more decals I thought I'd hit the two figures.
Both are from 'Copper State Models' to accompany their Bristol Scout,
« Reply #100 on: May 29, 2023, 03:03:53 PM »
Wow! Jaw dropped... fantastic figures!
Fantastic work overall and it'll be very interesting to see how decal project turns out.
« Reply #101 on: May 30, 2023, 12:29:12 AM »
Excellent work on the figures Mike!
« Reply #102 on: May 30, 2023, 05:44:12 AM »
Lovely work on the wings Mike. Your figures are excellent as always.
« Reply #103 on: May 30, 2023, 08:31:34 PM »
Interesting idea with the decals for the internal structure seen on undersides. Yet, I think I will stay at the permanent pen - contrary to what other experience I have no problems with possible bleeding the ink - acrylic paints cause me no issues.
Anyway, I am looking forward to see your results! up till now - a pleasure to follow, as usual ;)
« Reply #104 on: May 30, 2023, 11:28:11 PM »
Catching up on your build this morning, Mike and I have to say the work you've done on the framework lines looks great. A nice option to consider when tackling the job of showing the internal structure through CDL.
