Author Topic: Airfix 1/72nd :DO17z, He111-P, Ju87B, Blenheim 1F, Eduard Me110 , PLUS!  (Read 31368 times)
Re: Airfix 1/72nd scale DO17z: BoB. Also Eduard Me110 Profi in 1/72nd:
« Reply #45 on: January 12, 2023, 09:40:40 AM »
Putting the Do 17 canopy disaster aside I went ahead with some work on the Me 110. Flat finish applied as well as canopies attached. Final oil work and attaching the small parts is all that remains:
« Last Edit: January 12, 2023, 10:21:47 AM by RAGIII »
« Reply #46 on: January 13, 2023, 08:28:35 AM »
That looks very sharp!! Nice job. I'm sure the Do17 problem can be rectified. Airfix seems responsive to these situations.
« Reply #47 on: January 13, 2023, 10:22:48 AM »
Thanks Steve. I am working on a couple of things that I hope will solve the canopy issue. One includes Airfix spare parts. The other is a Squadron Vac Form that May or May Not work! On the positive side I finished working on the Eduard Bf 110.
PS: I just realized it's not done until I do the Antenna Wires!
« Last Edit: January 14, 2023, 02:40:29 AM by RAGIII »
« Reply #48 on: January 14, 2023, 02:25:42 AM »
Looks great - the telefunker would appreciate wires ;)
« Reply #49 on: January 14, 2023, 02:39:53 AM »
Super Bf 110 Rick.
I do hope that you can find a repacemet canopy for the Do 17 as that model too is really shaping up well.
« Reply #50 on: January 14, 2023, 02:50:20 AM »
Thanks Steve! The wires will be installed today  8)
Super Bf 110 Rick.
I do hope that you can find a replacement canopy for the Do 17 as that model too is really shaping up well.
Thanks Stephen!  I also hope Airfix comes through with a replacement, as I was very pleased with My progress! In the Meantime I have the Squadron vac form one on the way. I know it will need  some work to get it to fit. ( If that is even possible)  ::)
« Reply #51 on: January 14, 2023, 05:42:13 AM »
Very nice progress on this one!
Offline Brad Cancian
    • Brad's Models
« Reply #52 on: January 14, 2023, 08:48:06 AM »
That 110 looks gorgeous Rick, great work!
BC
« Reply #53 on: February 05, 2023, 05:13:47 AM »
Thanks for commenting Andreas and Brad!
The 110 had its antenna mast relocated to the proper position ( yep I screwed up originally) and the wire added. The DO17 is progressing although I still haven't resolved the broken/crushed canopy part on the fuselage side. I glued the parts in place with white glue for the painting process. The other canopy parts are masked with an Eduard mask set. A bit of pre shading overpainted with My RLM 65 mix using Tamiya paints.
PS: There May be some other BoB builds in the works,,,
« Reply #54 on: February 05, 2023, 05:52:46 AM »
Looking good Rick.
Good to see the Gladiator represented in the collection even though they were only 2nd line aircraft at the time.
« Reply #55 on: February 05, 2023, 11:39:54 AM »
Looking good Rick.
Thanks Stephen. The Gladiator was one of the Twelve Detailed in the book so I had to do one  8) This will actually be My second Gladiator having done  HP-B in 1/48th scale. I now only lack 4 of the Aircraft in the Book.
1. Ju88
2. He 1111
3.Beaufighter 1F
4. Hawker Hurricane Mk.1
« Last Edit: February 05, 2023, 09:28:09 PM by RAGIII »
« Reply #56 on: February 06, 2023, 12:58:52 AM »
Nice progress!! Looking forward to the other additions. Revell make a very nice Ju88A-4
« Reply #57 on: February 06, 2023, 09:34:15 AM »
Lovely work Rick! She's shaping up very nicely.
« Reply #58 on: February 06, 2023, 10:31:12 PM »
 The camo paint on the 110 looks very good.  Good work on the BoB subjects.  You seem to have a string of them going at the moment.  I don't recall seeing many Dornier Do17 models built.  Looking for ward to seeing yours, as well as the Ju88.
« Reply #59 on: February 07, 2023, 12:33:15 AM »
The 110 looks superb Rick!  Good to see you working on multiple builds, and BoB is an excellent theme.  I, too, have detoured a bit into WWII builds recently, although in 1/48 (although I pop back to 1/32 WWI now and again).  I wonder how many folks here build in multiple genre?
I hope you’re having fun with these, which is the whole point.  Enjoy yourself, and we’ll look forward to more of your inspiring work, whatever the subject!  Well done.
Best regards,
