Under Construction
Fokker D.VII - 4.Wlkp Sqn. J.Hendricks (1/72, Eduard)
Pages:
3
4
5
10
Topic: Fokker D.VII - 4.Wlkp Sqn. J.Hendricks (1/72, Eduard) (Read 20791 times)
PrzemoL
Re: Fokker D.VII - 4.Wlkp Sqn. J.Hendricks (1/72, Eduard)
Reply #30 on:
January 21, 2022, 06:59:24 AM »
Thank you!
Today I have reached my limits. Installing of 6 control cables and two from throttle strained my weakening eyesight and more and more clumsy hands beyond anything I could expect. Well, they are mounted but it was a 2 hours horror and the nature of Uschi material did not help, either. After that adding the resin firewall from Ed Brassin engine set was a breeze. Enough for today...
Guest
Reply #31 on:
January 21, 2022, 07:16:32 AM »
If I look at you pictures quickly I would say you are doing a WNW again here!
Great modeling!
Take some hours break, have a good sleep and continue!
WD
Reply #32 on:
January 21, 2022, 10:35:01 AM »
Prze, that is some beautiful work friend.
WD
gedmundson
Reply #33 on:
January 21, 2022, 11:38:27 AM »
Simply amazing! Stunning work on this.
jeroen_R90S
Reply #34 on:
January 21, 2022, 06:13:12 PM »
Gorgeous, hard to believe that's 1/72!!
Having done 2 of the 1/72 Roden D.VII this one looks much, much better, even out of the box. I like those 1/72 Roden kits, but the D.VIIs definately aren't among the best of them.
Jeroen
Reply #35 on:
January 22, 2022, 01:02:32 AM »
Quote from: gedmundson on January 21, 2022, 11:38:27 AM
What Gary said!!
PrzemoL
Reply #36 on:
January 22, 2022, 05:26:46 AM »
I am extremely happy that you like my modeling.
The last glimpse...
and the fuselage is closed...
Love the self
Reply #37 on:
January 22, 2022, 08:35:37 AM »
Excellent work on the interior
Reply #38 on:
January 22, 2022, 09:09:03 AM »
Stunning!
hadzi
Full Member
Reply #39 on:
January 23, 2022, 03:30:05 AM »
Wow! Good work Przemek!
pepperman42
Reply #40 on:
January 23, 2022, 12:58:31 PM »
Beautiful!!
FAf
Reply #41 on:
January 23, 2022, 04:38:04 PM »
As stated above - it's very difficult to believe that this is done in 1/72 scale! Such neat work!
PrzemoL
Reply #42 on:
January 28, 2022, 08:17:11 AM »
Thank you for the kind words.
In recent days I worked on further details. Spandaus are a mix of kit parts, Part and EdZoom.
Mercedes is of course Ed Brassin with water pipe and timing gear transmission column from soldering wire.
The radiator which is a modified kit element (one of many) will have the interior grill from EdZoom and a filling pipe with cover from scratch. Also the air pump at the engine forehead will be added.
All nicely fits after just a slight trimming at the opening for the prop shaft. Ready for colouring!
Thumbs up
Reply #43 on:
January 28, 2022, 09:01:25 AM »
Classic Prez
WD
Reply #44 on:
January 28, 2022, 10:21:25 AM »
Stunningly wonderful!
Prze, how do you get such a clean roll on the p/e Spandau jackets? I still struggle with this.
WD
Pages:
3
4
5
10
Under Construction
