Author Topic: 1:32nd scale Salmson 2-A2  (Read 25426 times)
Re: 1:32nd scale Salmson 2-A2
« Reply #75 on: January 01, 2022, 05:20:54 AM »
Last update for 2021.
Landing gear fitted.
'GasPatch' 1:48th scale turnbuckles with 0.12 blue coloured mono-filament and 0.4 - 0.5 mm diameter brass tube.
Tubes and barrels of turnbuckles painted with 'Tamiya' Medium Blue (XF18).
« Reply #76 on: January 02, 2022, 02:22:26 AM »
Great progress, I like those blue rigging lines.
« Reply #77 on: January 02, 2022, 04:52:42 AM »
Nicely done as always and I too like the blue rigging wires!
« Reply #78 on: January 02, 2022, 05:29:24 AM »
In agreement with the others , top notch Mike
« Reply #79 on: January 02, 2022, 07:56:24 AM »
Hi All,
The twin bracing wires between the front and rear cabane struts are pre-rigged.
Also the win wires between the rear cabane struts.
The turnbuckles are fitted on the ends of the lines, but the lines are left loose at the anchor points.
This should make it easier to final rig these lines once the upper wing is fitted,
« Reply #80 on: January 02, 2022, 09:30:12 PM »
The blue wires really pop! Beautiful work, as always!
« Reply #81 on: January 03, 2022, 06:05:07 AM »
The underside of the upper wing is now pre-rigged.
This covers the twin flying and landing wires, twin cabane bracing wires, drag wires and interplane incidence wires.
The turnbuckles are fixed on the lines, but the anchor point loops are left loose for final fitting once the wing is fitted.
Now it's on to pre-rigging the aileron, elevator and rudder control horns.
Also the twin bracing wires for the fin bracing,
« Reply #82 on: January 03, 2022, 01:10:13 PM »
You have been busy little spider !
« Reply #83 on: January 03, 2022, 06:45:44 PM »
Rigging, rigging... Lovely! ;)
« Reply #84 on: January 03, 2022, 08:35:36 PM »
That will be a very beautiful Salmson, as one can expect from your work!
« Reply #85 on: January 03, 2022, 11:01:35 PM »
Outstanding and a very good how-to, when I start my Salmson (in a future, far, far away)
Bye,
« Reply #86 on: January 04, 2022, 12:34:20 AM »
The flight controls are now pre-rigged.
The control horns for the ailerons, rudder and elevator.
Now it's on to pre-rigging the fin/tail plane twin bracing wires,
« Last Edit: January 04, 2022, 08:22:53 AM by Mike 'Sandbagger' Norris »
« Reply #87 on: January 04, 2022, 01:40:25 AM »
Excellent work on the pre rigging Mike!
« Reply #88 on: January 04, 2022, 04:25:04 AM »
Itsy bitsy spider climbed up the wing strut .......
Looking good Mike !
« Reply #89 on: January 04, 2022, 05:12:11 AM »
This is some beautiful and intricate modelling Mike! I do love the effects and the complex but precisely executed rigging... Regards, Marc
