Author Topic: 1:32nd scale Salmson 2-A2  (Read 25310 times)
Re: 1:32nd scale Salmson 2-A2
« Reply #105 on: January 07, 2022, 03:50:25 PM »
Wow, the closer the look, the more realistic it seems.
« Reply #106 on: January 09, 2022, 08:16:00 AM »
I've fitted the linen wrapped infills between the pairs of flying, landing and fin bracing wires.
I tried my previous methods of using baking parchment paper or 0.2 mm thick plastic card strips.
However, the length of these pairs of wires are long and they flexed too much.
Therefore, I cut strips of 'Aviattic' CDL decal to 1.75 width of each pair of wires.
The water I used to release the decals was cold, as this tends to release the decal in a more rigid state than warm water would.
That made it easier to position the decal strips onto the wires.
The decals were laid centrally onto the top sides of the wires and left to allow the residual decal adhesive to grip to the wires.
I then applied 'DACO Products' strong setting solution across the top of the decal strip.
As the decal started to soften, I teased the edges under the wires to fully wrap them with the decal.
Not easy but I think it should look OK once I've painted the decals.
This is necessary as the decal is thin and the blue rigging wires shown through.
Then it's onto finishing the rigging (drag and side wires),
« Last Edit: January 09, 2022, 09:10:35 PM by Mike 'Sandbagger' Norris »
Offline Whiteknuckles
« Reply #107 on: January 09, 2022, 08:51:30 AM »
That is truly outstanding work Mike, looks excellent!!
Eternal Apprentice
« Reply #108 on: January 09, 2022, 08:58:07 AM »
That is definitely well beyond my patience to decals. Amazing idea and the result!
« Reply #109 on: January 09, 2022, 09:21:49 AM »
Really outstanding results Mike. Better than the Other ones you have done and those were great 👍
« Reply #110 on: January 09, 2022, 11:22:15 AM »
Second Ricks comments
« Reply #111 on: January 10, 2022, 03:49:41 AM »
Don't mind my dumbstruck expression, it's due to 1) learning of wire wrapping after thinking I'd seen it all and b) your execution of same. Beautiful!
« Reply #112 on: January 10, 2022, 05:54:28 AM »
That is a beautiful and perfectly detailed model, where you can "zoom in" and find always new things!
« Reply #113 on: January 10, 2022, 07:07:38 AM »
No worries - I know that no criticism was intended and certainly none was take  :D,
« Last Edit: January 10, 2022, 09:06:43 PM by Mike 'Sandbagger' Norris »
« Reply #114 on: January 11, 2022, 05:21:45 AM »
You learn something new every day! How neat! What a clever idea, and well executed by yourself Mike.
« Reply #115 on: January 11, 2022, 10:29:12 PM »
Awesome work there, Mike.  Looks realistic.
« Reply #116 on: January 12, 2022, 02:07:47 AM »
Hats off, this is an impressive way to deal with this modelling challenge!
Offline Dirigible-Al
« Reply #117 on: January 12, 2022, 02:23:26 AM »
Great idea using decals on the wires. If faced with the challenge myself I am sure I would have wrapped foil round them but I will instead follow your lead and use decal strip.
Alan.
« Reply #118 on: January 12, 2022, 08:35:28 PM »
Wow. This is very impressive. The decal hack is a great idea. I will try to copy that, when I start mine.
Bye Manni
Offline Stuart Malone
« Reply #119 on: January 13, 2022, 01:44:25 AM »
Mike,
Each new post impresses me with your continuing ability to add the missing details no matter how minute.
Stuart
