Author Topic: 1:32nd scale Salmson 2-A2  (Read 25238 times)
Re: 1:32nd scale Salmson 2-A2
« Reply #60 on: December 02, 2021, 05:40:38 AM »
Wow, some stunning work and great detail, Mike! I'm enjoying this complex build enormously! Regards, Marc
« Reply #61 on: December 02, 2021, 09:19:06 AM »
Splendid modelling. Not my favourite aeroplane, but this one is coming along beautifully.
« Reply #62 on: December 03, 2021, 06:52:15 AM »
Just a quick update.
I forgot to fit the generator drive belt.
To represent the generator drive belt, I cut a strip of photo-etch 1.0 mm wide, then annealed it (softened over a flame).
It was then bent around a 1.8 mm diameter drill to form a semi-circle.
It was then brush painted with ‘Tamiya' Rubber Black (XF18).
Once dry it was secured in position around the forward shaft of the generator, with the two ends onto the round ‘pulley’ on the rear of the engine.
Offline Grant
« Reply #63 on: December 03, 2021, 10:54:44 AM »
Mike,
Absolutely stunning work! The detail is amazing on this aircraft, wonderfully presented.
Grant
Offline jeroen_R90S
« Reply #64 on: December 03, 2021, 06:17:27 PM »
Did you turn her over and put a volt meter on the battery terminals  already? That looks fabulous!
« Reply #65 on: December 04, 2021, 06:34:49 AM »
Oh wow, good catch Mike! I should've caught that myself before now  ;D
« Reply #66 on: December 04, 2021, 07:41:29 AM »
Great eye for the detail on this busy airframe. I think you definitely got the look of the foto quite right!
« Reply #67 on: December 04, 2021, 08:23:44 AM »
Damn, that is nice work Mike!
« Reply #68 on: December 25, 2021, 01:43:16 AM »
I've been fighting off a cold and cough (not Covid) for the past few weeks, so I've not posted updates.
However, here's and update for the Salmson.
I've used a combination of 'Tamiya' acrylic and 'Hataka' lacquer paints for the external camouflage scheme.
This was all airbrushed with 'Alclad' Aqua Gloss 600 for applying the decals.
I cut templates to create the various shapes required then transferred them onto the 'Aviattic’ Linen Weave effect (ATT32236) decal sheets.
These were applied after which the kit decals were added.
Everything was given a coat of 'Alclad' Light Sheen (ALC311) lacquer as the base for applying weathering, which I'll be applying next,
« Reply #69 on: December 25, 2021, 07:23:06 AM »
Fabulous job on the details Mike and that is a cool motif !
« Reply #70 on: December 25, 2021, 11:08:37 AM »
Gorgeous painting and decaling Mike!
« Reply #71 on: December 28, 2021, 05:05:45 AM »
Just a few updates.
The wheels have 'Aviattic' linen weave effect decal applied.
The landing gear is painted ready to assemble.
The two Lewis and single Vickers machine guns are prepared for fitting.
The 'Proper Plane' laminated wood propeller has got it decals and semi-matte clear coat.
All of these have yet to be weathered etc,
Offline Stuart Malone
« Reply #72 on: December 28, 2021, 05:59:42 AM »
Mike,
All your models are gorgeous and this one might be at the top.  I love the detail photos you post.
Stuart
« Reply #73 on: December 29, 2021, 01:56:58 AM »
Beautiful detail painting of the small parts/struts. The Machine guns look awesome!
« Reply #74 on: December 29, 2021, 06:09:00 AM »
Amazing detail! You'd expect some mistakes to show up with the kind of magnification you're using, but no... it's still perfect! Utterly amazing!
