Author Topic: WNW DH2: J.T.B. McCudden 29 Squadron: Plus Albatros  (Read 88039 times)
Re: WNW DH2: J.T.B. McCudden 29 Squadron: Plus Albatri
« Reply #105 on: November 19, 2021, 08:50:40 AM »
Been a while since I last popped in , all are coming out fantastic so far . Really nice work Rick
« Reply #106 on: November 20, 2021, 04:24:55 AM »
Well another dual build going, looks good ! Am hopefully over the last 3 months of medical problems and can getwith it myself !
« Reply #107 on: November 24, 2021, 08:57:03 AM »
Thanks Alexis. Your comments are always appreciated and you are missed when not around!
Thanks Amigo! Actually a Tri build  ::)
So I started the rigging on the DH2. As I feared those TINY Pulleys proved troublesome! I tried but just couldn't drill rigging prep holes!! Then I lost one to the Carpet Monster   :( So I punched out some styrene discs and made replacements for both. They are a Bit oversized but will hopefully help me with the rigging process  ::)
The painting of the Albatros DIII continues. I have added the basic fuselage scheme. Next up is the Jasta 6 black stripes on the tail...then lots of touch up  8)
PS: That beige patch on the DIII wing will be overpainted then chipped and sanded to look worn like the original...or so I hope!
PPS: This is where I am on the Albatros DII. I struggled with mounting the upper wing losing a cabane and interplane strut in the process. ( Still to be fixed). I am still debating if the wing gap is correct. One positive outcome is that this finally inspired Me to Order a Biplane Jig! Lots of touch up needed  :o
« Last Edit: January 20, 2022, 01:16:55 AM by RAGIII »
« Reply #108 on: November 24, 2021, 12:22:29 PM »
Excellent work on that Albatros Rick. When I built my Roden D.II a couple of years ago, exactly the same thing happened to me - broke the cabane strut in two places when placing on the top wing. Too much pressure. Had to "steal" one from my Roden D.III kit. I fixed the strut eventually, so if I ever put that D.III together, it'll have a fixed strut (hopefully not too noticeable!).
« Reply #109 on: November 24, 2021, 07:06:34 PM »
Rick -
Wonderful work thus far - I like the look of the DIII
« Reply #110 on: November 25, 2021, 01:39:06 AM »
Thanks Gary. It is nice, in an abstract way, to know I am not alone in having difficulty with the upper wing  ::) If worse comes to worse and I need to disassemble the wing I have at least one spare cabane and the white metal interplane struts I didn't use. ( I cut the DI struts down to size) So a bit of clean up and drilling would get me back in business  8)
Rick -
Thanks Dave. I have a bit of filling to do as a crack has appeared behind the cockpit  >:(
Offline jeroen_R90S
« Reply #111 on: November 25, 2021, 08:02:26 PM »
Nice!
I always wondered why Roden didn't do an early D.II themselves. They even did one in 1/72!
« Reply #112 on: November 26, 2021, 12:31:00 AM »
You certainly have a lot going on in this thread.  Good stuff.
Just curious, what biplane jig did you order?
« Reply #113 on: November 26, 2021, 01:09:45 AM »
Nice!
I have the same question  8) It seems it should have been a Natural Progression!
Thanks Ken. I ordered the Vertigo Jig through UMM-USA
« Reply #114 on: November 26, 2021, 04:32:34 AM »
Very much liking the DH 2 Rick. Yes the pulleys on pushers can be a real pain to reproduce at an accurate size - ones that are slightly larger will not be boticed I can assure you.
The two Albi look very fine too - good work on both.
« Reply #115 on: November 27, 2021, 12:09:18 AM »
Thanks Stephen! I hope that once all of the wires are attached and painted the pulleys will sort of blend in with the Maze  8)
« Reply #116 on: December 05, 2021, 10:13:07 AM »
Rick,
       This is really excellent work all the way around. Your perseverance in the face of kit difficulties inspires me, I'm sure it does others too.
WD
« Reply #117 on: December 05, 2021, 11:23:56 AM »
Rick,
WD
Thanks Warren! This/ These builds have been a one step forward, two steps back thing but at least No Major Build ending disasters have occurred! I have started to assemble the Vertigo Jig. The basic instructions leave a GREAT DEAL to be desired!! That being said  I have progressed through what I would consider stage 1 of the assembly without issues.
« Last Edit: December 06, 2021, 01:37:09 AM by RAGIII »
« Reply #118 on: December 05, 2021, 11:59:40 AM »
I'm amazed at your building talents Rick.  Beautiful progress with sometimes
ornery Albi's.  Well done is a little tame but my admiration for your work isn't!
« Reply #119 on: December 06, 2021, 01:11:41 AM »
All three look amazing already, Rick! Very neat and clean modelling and spot on colours, just lovely! Not too sure about jigs myself, it would be quite easy to work in some "tension" that could have nasty consequences later... but watching intently! Regards, Marc
