Author Topic: Encore/Roden SE5a McCudden 56 sq.. Phoenix thrice Risen  (Read 89426 times)
Re: Encore/Roden SE5a McCudden 56 sq....2nd try
« Reply #90 on: July 17, 2021, 11:07:11 PM »
your wrinkles look great (not often you can say that and get away with it  :D )
What's the technique if you don't mind me asking?
Thanks. The method I use for the wrinkles is simple. I start with a thick acrylic craft paint. I apply it where i Want wrinkles( heavy puddle) Next a pointed round brush is drawn through the paint in the direction I want the wrinkles. This pulls paint with it leaving a valley. Move to the next one and repeat. Smooth it out where you want the wrinkles to end. I usually go back and add a bit of the acrylic to each individual wrinkle to make sure it doesn't flatten out. When the paint is dry I brush valejo or polyscale over it all. Takes longer to explain than it does to do the painting  ::)
Nice wrinkles Rick, was looking at SE5a photos and wondering how to create them only a few days ago. I really like your PC10 colour, Raymond Collishaw described his Tripelane as being dark green, Cecil Lewis described his SE5 as being chocolate brown. Your mix could easily be described as both by different people. Must be pretty much spot on.
Thanks Richie. My goal with PC 10 is usually to get some color shift between brown and green depending on the light. I am Not Always successful  :o
WOW, with that big spinner and four-bladed prop and the square chin, is anybody else thinking of a Hawker Typhoon?
Great stuff!
Thanks Sandy. Well 56 did fly the Typhoon  ;D
 Once I receive My strippers I will go back and do some shading and more paint work on the PC 10.
Does your wife know Rich?  And how will they help with painting?
[/quote]
Had to tell the wife she runs the finances  8)
This is coming along really well. I like your PC10 mix, looks spot on to my eyes. Regards Pete in RI
Thanks Pete!
« Last Edit: July 18, 2021, 02:05:40 AM by RAGIII »
« Reply #91 on: July 18, 2021, 01:59:06 AM »
Good, fast progress here, Rick -
I'm filing that fabric wrinkle trick for future uses - very effective.
Offline Early Bird Fan
« Reply #92 on: July 18, 2021, 05:35:14 AM »
Thanks for the explanation, i gave it a go earlier but have used vallejo plastic putty rather than acrylic paint. I'll see how it looks once painted
« Last Edit: July 18, 2021, 07:56:24 AM by Early Bird Fan »
Offline Fvdm
« Reply #93 on: July 18, 2021, 06:57:08 AM »
Great progress Rick. Like others I like your wrinkles. Have to remember your method.
« Reply #94 on: July 18, 2021, 09:10:57 AM »
As usual, great progress and neat work Rick.
Thanks for explaining the wrinkle-technique for us. It's in my notebook now  :)
« Reply #95 on: July 18, 2021, 09:19:14 PM »
Good decision Rick to build it with a 4 blade prop, looks very special with this huge spinner.
This tells me to do also a 4 blade of the second kit of the Eduard Dual Combo in my stash, thanks for that.
May be I have overlooked it, how you masked the engine during the PC10 paint job? Is some liquid mask on it?
Great project with a lot of interesting info in this thread!
« Reply #96 on: July 18, 2021, 10:57:23 PM »
Great progress, Rick.  Nice touch with the wrinkles.  I've noticed a number of British aircraft tend to have wrinkling of the covering which is not seen so much on French and other aircraft.
« Reply #97 on: July 18, 2021, 11:27:40 PM »
Hmmm , old and wrinkly ... I like it !
Nice job on adding the wrinkles to the fabric , really adds to the overall effect bringing it to life !  :)
« Reply #98 on: July 19, 2021, 07:02:06 AM »
I like your wrinkles too... 😎 ... and the idea/tip comes just in time for me to use on my FK8. Thanks!
Offline KONG
  • A day without sunshine is like...night
« Reply #99 on: July 19, 2021, 04:04:11 PM »
Awesome build and amazing techniques . . Thanks
"If I could only have brought him down alive..."
« Reply #100 on: July 20, 2021, 07:29:36 AM »
Thanks! The wrinkles can be done more prominently, cover larger areas etc. I wanted small and subtle  8)
Thanks Willem. With a little practice this method works well!
Thanks Frank!
Thanks Ken. Yes, perhaps it has to do with all of the lacing on the sides  ;D
Thanks Alexis!
Thanks and good luck on the FK8!
Thanks for the comments!
In the meantime My strippers arrived today! Time to get back to work  8)
« Last Edit: April 05, 2022, 02:50:50 AM by RAGIII »
« Reply #101 on: July 20, 2021, 09:24:50 PM »
Oh, those are the strippers.
« Reply #102 on: July 21, 2021, 02:47:49 AM »
Only the best 'strippers' leave these premises, Ken  ;D ;D
Glad they made the trip across the pond without injury.
Keep up the great work on the SE5.a Rick.
« Reply #103 on: July 31, 2021, 08:51:47 AM »
So I have gone back to this one and here are the initial  results of using the Strippers: After using the masks I painted Tamiya Buff. Next is covering with thin coats of the Tamiya Mix of PC10.
« Reply #104 on: July 31, 2021, 09:19:05 AM »
Great to see this one back underway Rick, are the strippers decal strips or styrene? They're going to give a beautiful effect under the pc10. I love the business like lines of the SE5a, it's definitely not graceful like a Pup or a Nieuport but i find there's something very handsome about it.
