Author Topic: Encore/Roden SE5a McCudden 56 sq.. Phoenix thrice Risen  (Read 89283 times)
Re: Encore/Roden SE5a McCudden 56 sq....2nd try
« Reply #15 on: June 25, 2021, 08:17:44 AM »
I hope that you will not mind Rick if I just sit in a comfy chair....!
« Reply #16 on: June 25, 2021, 10:59:27 AM »
I'm not sharing the popcorn .... ;)
« Reply #17 on: June 26, 2021, 11:06:21 AM »
Todays work: I re did the linen and stains on the interior, worked on the seat, and started to add details.
« Reply #18 on: June 26, 2021, 10:12:00 PM »
looking good Rick !
« Reply #19 on: June 27, 2021, 03:57:18 AM »
/F
« Reply #20 on: June 27, 2021, 04:23:56 AM »
« Reply #21 on: June 27, 2021, 05:01:35 AM »
Off to a great start Rick, this looks like an excellent kit. Looking forward to the next update!
« Reply #22 on: June 30, 2021, 05:06:56 AM »
Hi Rick, I was allowed to get right up close to the original SE5a today and took a lot of detail photos which might be of interest. I've added them to the engine details thread. Hope you like them!
« Reply #23 on: June 30, 2021, 05:44:41 AM »
That is a good start Rick. Better luck with this one!
« Reply #24 on: June 30, 2021, 09:40:47 PM »
Great start, Rick -
I've built the Roden SE5a's in both Hisso and Viper engines and both are pretty decent kits that build up well from the box.  Look forward to seeing how you get on with this one.
« Reply #25 on: July 01, 2021, 12:48:40 AM »
Thanks Richie. Like all Roden kits it has it's challenges but overall it is quite nice!
Again thanks for the photos. I saw them yesterday and some will indeed help a lot!
Thanks Stephen!
Great start, Rick -
Like I have said, the kit is nice. Any disasters will be of My own doing  ::)
Offline Early Bird Fan
« Reply #26 on: July 01, 2021, 07:39:48 AM »
that's looking great, i'll be following along so all the others need to move along one seat to make room for me  :D
« Reply #27 on: July 01, 2021, 09:12:34 AM »
Thanks for commenting! A very small update. I have started on adding the resin pulley inspection panels. If one is an excellent modeler and great at making "Precise" cuts the idea is that the resin parts are inserted and you are done. I am not that Modeler! So that being said lots of filling and sanding to make them look right. I will use the PE triangles to finish things off. The lower wing is filled and sanded and the upper is photographed before that process.
« Reply #28 on: July 01, 2021, 08:52:27 PM »
Nothing wrong with a bit of filling and sanding. Is the kit Roden plastic with resin and etch additions? It looks familiar.
« Reply #29 on: July 01, 2021, 09:50:11 PM »
Following along on this one, too.  Can you show the detail on the pulleys?
I don't know how many Encore kits you've done, but would you say they significantly improve the base Roden kit?
