Author Topic: Albatros D.III Oeffag 1:48 Eduard  (Read 13890 times)
Offline Von Salza
Re: Albatros D.III Oeffag 1:48 Eduard
« Reply #45 on: September 03, 2021, 05:48:04 AM »
Today i fixed first (here and in my life) handles for rigging. I needed some time for selecting right materials and practice. Here's the result, I hope it will hold out the rigging process...
« Reply #46 on: September 03, 2021, 07:18:30 AM »
Fine progress. As for the strength of rigging fittings I test every single one before assembly for pull out. Pass a piece of fishing line, hold the ends and try to pull it out. If it holds then it will also stand the rigging. 😉
Offline Von Salza
« Reply #47 on: September 03, 2021, 07:28:39 AM »
I'll do that, thanks :)
« Reply #48 on: September 03, 2021, 03:06:00 PM »
Looks like a strong bond to work with!
« Reply #49 on: September 04, 2021, 10:11:34 PM »
The fittings should give you a nice solid anchor!
Offline Von Salza
« Reply #50 on: September 21, 2021, 10:08:06 PM »
No progress. I've ordered lines for rigging from Ushi store almost two weeks ago. I received mail with confirmation. And from that day silence. I sent two mails with no answer. Had anyone of You similar problems? Should I wait? (BTW what else can I do?).
« Reply #51 on: September 21, 2021, 10:21:52 PM »
Those anchor points should be plenty strong enough. They look very tidy too.
Offline Von Salza
« Reply #52 on: November 08, 2021, 01:36:28 AM »
I'd like to refresh this forgotten topic.
After two months of waiting for rigging lines (during this time I began to construct another Albatros) the work could be continued. The hardest task was fixing the upper wing with rest of the model, I had to use force and quick drying glue... Comparing to this, the rigging seemed to be rather easy. It is not perfect - next time I will choose different method for gluing the line. A few actual pictures:
« Reply #53 on: November 08, 2021, 02:42:18 AM »
Beautifully painted and the rigging looks Excellent!
« Reply #54 on: November 08, 2021, 12:35:19 PM »
My thoughts exactly!  Just amazing, especially the wing translucency.
« Reply #55 on: November 08, 2021, 08:10:38 PM »
I only can dito the above said. Beautiful work and a superb paintjob. Everything looks really coherent.
Bye,Manni
Offline Von Salza
« Reply #56 on: November 10, 2021, 01:13:16 AM »
Thank You  :)
« Reply #57 on: November 10, 2021, 02:49:26 AM »
That’s really a great one! I can’t see any flaws on your rigging.
Offline Von Salza
« Reply #58 on: November 15, 2021, 06:12:23 AM »
Thank You all.
Recently birdie got its wheels, waiting for propeller and some final touches.
Before the Hall of Fame I am going to make a small vignette to avoid placing it on the bare, cold cardboard.
« Reply #59 on: November 16, 2021, 03:32:46 AM »
This looks incredible now that it is on it's wheels. The view now really shows off the translucent wing effects to perfection! Beautiful work!!
