Author Topic: Albatros D.III Oeffag 1:48 Eduard  (Read 13753 times)
Re: Albatros D.III Oeffag 1:48 Eduard
« Reply #15 on: May 14, 2021, 07:29:39 AM »
Lovely choice of schemes!
Offline Von Salza
« Reply #16 on: July 25, 2021, 06:36:52 AM »
Reanimation of dead topic... Here's some progress:
- fuselage closed, sanded (few evenings, disaster), painted. Camo pattern is coarse, finer is out of my range at the moment.
- wings... During painting the unit's stripes I've secured too narrow area. When masks were removed wings had light, happy beetroot tone all around. So, again - from the beginnig :) Now, it looks better:
- some small staff: cowling, propeller..
Next, I will paint rest of the unit's insignia on the fuselage and wings, then spray varnish, put decals, wash between panels and make some oil weathering.
Offline ColonelKrypton
« Reply #17 on: July 25, 2021, 07:18:03 AM »
I think the wood work looks quite nice - subtle and not over done.
Well done.
cheers, Graham
Offline Brad Cancian
    • Brad's Models
« Reply #18 on: July 25, 2021, 08:45:30 AM »
Wonderful work Graham - and you say this is your first aircraft kit...? Surely not :o ;D ;D
Question - how did you paint the metal nose cowl? It looks very good.
BC
Offline Von Salza
« Reply #19 on: July 25, 2021, 04:30:59 PM »
Thanks for Your posts.
Brad - black base and Mr.Hobby Silver with aero, then Mr.Hobby Aluminium with fine brush and optics.
This is my first plane at all, I made three tank builds before.
Cheers.
« Reply #20 on: July 26, 2021, 12:46:39 AM »
Very nice model so far. Beautiful woodgraining and wings transparency.
« Reply #21 on: July 26, 2021, 01:16:27 AM »
Agreed  :)
Offline Von Salza
« Reply #22 on: July 26, 2021, 06:33:15 AM »
Thank You :)
It's motivating...
« Reply #23 on: July 26, 2021, 09:00:52 PM »
Your paint work is outstanding! Really looking Fantastic.
Offline Von Salza
« Reply #24 on: August 03, 2021, 05:00:51 AM »
Small progress, Flik's stripes are painted, decals are being set (I am not quite sure of this grammatic form  ::)).
Now I have a question: the rudder seems to be a difficult place for decals:
Does anyone remember if Eduard's decals are easy to be set on that location? If not, maybe I should paint german cross with white border? Despite that it's time consuming process...
« Reply #25 on: August 03, 2021, 06:29:51 AM »
This looks Terrific! Sorry I can't answer your decal question for Eduard 1/48th but painting always looks fantastic  8)
RAGIII.
« Last Edit: August 04, 2021, 04:04:09 AM by RAGIII »
« Reply #26 on: August 04, 2021, 02:28:26 AM »
Absolutely beautiful! 🙌
Eduard's decals are as good as any, so I don't think they will cause problems. On the other hand, decals in tricky areas can always cause problems. If you can paint the cross with less issues than what may arise from using decals, go for it!
« Reply #27 on: August 04, 2021, 05:56:45 AM »
Wonderful painting going on here! The translucency looks absolutely real and the woodwork is just beautiful.
The decal should go on just fine with micro sol and micro set. If it doesn't it would be easy to remove with tape leaving you free to paint it instead. Your work looks so skillful that you wouldn't have any trouble with either method.
Offline Von Salza
« Reply #28 on: August 04, 2021, 06:31:11 AM »
Thanks for Your kind replies. I am not skillful - I spend a lot of time and sacrifice my mental health to reach acceptable results. ;)
Unfortunately I don't have Microscale liquids but only some Vallejo products which were for sure manufactured for quite different purposes.
Micro SOL is actually not available in Poland (at least I couldn't find it in any store) so I have to order it via Amazon or Ebay - two weeks of waiting. Because of that I am going to paint those symbols. If it fails - there's only one small rudder to repaint.
Richie - could You write anything more about "tape method" for decals?
« Reply #29 on: August 04, 2021, 08:45:48 PM »
Sure, when I have had decal problems and needed to paint markings instead I just stick Tamiya tape on the decal and then rip it off. They usually come off quite easily in one piece.
