Author Topic: Wight Quadruplane, Spin 1/48, Upd 15.5.21 The end  (Read 37992 times)
Wight Quadruplane, Spin 1/48, Upd 4.5.21 Last wing!
« Reply #105 on: May 05, 2021, 05:47:12 AM »
Thank you Hugh, Alexis and Rick!
Last wing
Again an update ...
In meantime I soldered control horns from 0.2mm nickel silver and 0.4mm brass tubes.
Mounted into the control surfaces.
Control wires added.
So I'm prepared to mount the last wing!
But after this picture I noticed, that the middle of the wing sits to hight, so I removed the four struts in the middle, unpinned and shortened them for another mm. Re-pinned, glued to fuselage again and next try ...
... successful!
To put it on the nose will no more possible with the finished model.
The alignment is acceptable.
This was again an update after a short time, but I'm sooo happy with the result - I need to share it 8) This was a lot of work with all the wooden struts.
Let's see how the rigging will look like.
Let's have a beer now
Re: Wight Quadruplane, Spin 1/48, Upd 4.5.21 Last wing
« Reply #106 on: May 05, 2021, 05:54:00 AM »
You did it Frank!
I have one word:
B-R-I-L-L-I-A-N-T!
Besides that, you are an absolute master in micro-soldering.
« Reply #107 on: May 05, 2021, 07:10:31 AM »
Yes Frank!!!! Well worth sharing a happy success like this. I'm enjoying this build, you must be having real fun with it!
« Reply #108 on: May 05, 2021, 07:27:06 AM »
Simply Awesome Frank!
« Reply #109 on: May 05, 2021, 07:44:07 AM »
Hey Frank , top wing is splendid looking in place now  :) Looking forward seeing her all rigged up now  :)
« Reply #110 on: May 05, 2021, 05:03:53 PM »
This looks so great. Another showstopper is on it's way.
« Reply #111 on: May 06, 2021, 01:43:07 AM »
Sorry Frank but I have had another couple of days away and... you have made an excellent undercarriage from wood, tail skid, control horns and mounted the top wing.... I am breathless!
Just super - absolutely super. To get all four wings lined up so well and with the correct spacing - you deserve more than a beer!
Another mini-masterpiece in the making. I am seriously considering origami now!!
Offline Fvdm
« Reply #112 on: May 06, 2021, 01:52:57 AM »
The wings are good aligned Frank. The control horns look great. Great work.
« Reply #113 on: May 06, 2021, 05:13:50 AM »
Thank you for celebrating this moment with me!
A second beer can be unhealthy ;D
The spacing is the result of sanding those 24 struts ::)
It was a good decision to add the 0.6mm pipes to the wings at the begin. The wooden struts are very robust, so I can press a wing a bit harder in one direction to bend the brass pins and to get a good alignment.
Sounds strange, but works! Don't try this with kit struts ;D ;D
20 rigging threads are in now, but this is not even the halve of needed ones ::)
« Reply #114 on: May 08, 2021, 01:29:29 AM »
20 rigging wires = less than half the total? Try rigging a pusher then you will know that 20 wires are not enough to rig the wings on one side of the nacelle! I have counted that there will be 40+ just on the tail of the SIA which I am building!
« Reply #115 on: May 08, 2021, 02:49:52 AM »
Yes Stephen, I know that from my D.H.2 Stripdown, that one has also the rigging inside the wings! It has eaten a whole pack of One End turnbuckles in one wing.
https://forum.ww1aircraftmodels.com/index.php?topic=8552
I'm now around 36 8) Very hard to see against that PC10 :-\
And sometimes there are curses like in football "It was in!" when the thread is pulled out of the hole again by the electrostatic attraction through the tweezers ...
« Reply #116 on: May 08, 2021, 09:20:22 AM »
Nice work, Frank.  This is looking good.
Such a unique looking plane!
Wight Quadruplane, Spin 1/48, Upd 13.5.21 Rotherham air pump
« Reply #117 on: May 14, 2021, 01:31:01 AM »
Thanks Ken! It is also very small.
Rotherham air pump
The last days I had other things to do.
But most of the rigging is now installed, and I tried to add another detail: Rotherham air pump
There were different types, this one.
Source: sopwithcamelblog.files.wordpress.com
At the beginning I made a pump from brass. The pressure tubing is 0.2mm copper, the axle nickel silver.
My Sopwith Triplane built last year is not equipped with such pump, so I had still the Eduard PE. A bit flat, but I could use the mount frame.
I modified it a bit and added the PE parts and a real wooden prop.
The blades are very thin and the whole thing is very small!
Now it is mounted on a strut.
From another angle, and without airflow.
And here with airflow:
Another nice detail added 8)
Re: Wight Quadruplane, Spin 1/48, Upd 13.5.21 Rotherham air pump
« Reply #118 on: May 14, 2021, 02:21:59 AM »
Wow, that is impressive micro engineering, it even spins! I think you've earned a beer reward Frank!
« Reply #119 on: May 14, 2021, 02:38:33 AM »
Clever, clever work on your Quadruplane, Frank -
Love the little wind driven fuel pump - wow!
