Author Topic: Airco D.H.2 Stripdown, Eduard 1/48  (Read 15848 times)
« on: May 28, 2017, 02:07:58 AM »
Now I like to present here a model, which I think it is my "masterpiece". At least it takes the biggest effort of my models up to now. It is a:
Airco D.H.2 as stripdown in 1/48
The kit was produced by Eduard in 2014. Additionally I used a Small Stuff Gnome Monosoupape 9B-2, which is able to rotate here, a huge number of Gaspatch turnbuckles of different types (may be the model with the highest number used), some PE of Parts, a lot of additional brass profiles and wood for struts and airscrew. Since the kit do not contain decals, I used a set from a Weekend Edition.
The paints are Gunze, Alclad and oils.
The main parts are soldered to get a model as robust as possible. The biggest effort was the rigging and control wires, there are 119 wires in. A normal D.H.2 model takes a huge amount of wires, but here I have also added the internal wires. I'm very satisfied with the different kind of rigging, only for the terminals of the RAF wires (from Parts here) I have found in meantime a better solution.
May be you have seen this model already, if you have visited the Eduard product page of this kit. Eduard use it a completed example :-*
There is a detailed build report available, but in german. If you like I can add some small interesting impressions.
I hope the pictures are not to big (300kb, 1280with), if so please tell me and I will replace them by smaller ones.
Enjoy the pictures!
Re: Airco D.H.2 Stripdown, Eduard 1/48
« Reply #1 on: May 28, 2017, 02:22:21 AM »
Hi Frank, masterpiece is an understatement.  I am at a loss of words at this beauty.  Congratulations.
« Reply #2 on: May 28, 2017, 03:12:15 AM »
I have already seen this on another site but I am more than willing to look at it all again. Masterpiece is certainly an understatement .
« Reply #3 on: May 28, 2017, 03:48:18 AM »
Frank, I cannot agree more!  I've been alternately tempted and intimidated by this kit.  I wish I had the talent to tackle such a feat.  Utterly magnificent!
« Reply #4 on: May 28, 2017, 05:18:47 AM »
That's bonkers Frank!
Amazing...
What else have you got up your sleeve?
« Reply #5 on: May 28, 2017, 06:51:30 AM »
An incredible model Frank and a testimony to your superb modeling skills, this is a top quality museum piece.
« Reply #6 on: May 28, 2017, 07:17:32 AM »
Nothing more to say-- just Wonderful !!
Offline ondra
« Reply #7 on: May 28, 2017, 02:14:12 PM »
Wow. Just wow!
Ondra
« Reply #8 on: May 28, 2017, 08:56:17 PM »
I've long wanted to see one of these and you have done a brilliant job, Frank. Thanks for sharing it with us.
« Reply #9 on: May 28, 2017, 11:42:46 PM »
   This is a spectacular bit of model building, every time I go back to it I see more! Beautifully done Frank, it is indeed a masterpiece! 8) 8) 8)
« Reply #10 on: May 29, 2017, 12:09:05 AM »
Frank, unglaublich, was du da machst - just incredible what you're doing here!
Borsos
« Reply #11 on: May 29, 2017, 01:29:22 AM »
Thank you all! It was a great pleasure for me to show my work to this group of experienced model creators!
Nigel, especially this kit (the only Eduard stripdown in 1/48, and I know now why you see it often as fresh kit 8)) or those stripdowns in general? Around 1996 or so they produced 6 kits in 1/72, I collected them all and soldered three of those until now. So if you like this small scale too ....
Some details of the D.H.2, it is really soldered:
The plastic tailbooms of the kit are too short and not robust, so new ones in brass:
Prepared wooden struts:
« Reply #12 on: May 29, 2017, 03:18:43 AM »
 Frank,
I'm absolutely in awe my friend. Simply put a truly amazing project and a fitting tribute to your Master Class talent. Well Done and Congratulations.
Offline compressor man
« Reply #13 on: May 29, 2017, 10:12:14 AM »
I think the following puts it perfectly.... :o
Amazing work!
Offline Syd Solo
« Reply #14 on: May 30, 2017, 11:54:00 AM »
Magnum opus!
 :D
Syd
