Author Topic: Revells FW 190 A-8 1/32  (Read 19798 times)
Re: Revells FW 190 A-8 1/32
« Reply #45 on: April 12, 2021, 11:59:28 PM »
Great work, Alexis.  I have the F-8 version and the same PE set.
Following along.
« Reply #46 on: April 13, 2021, 05:13:33 AM »
Hi Ken ,
I can say that so far the PE parts fit with out having to thin the kit parts . One thing to watch out for is the outer sections of the bay , If these parts aren't rolled right the others will not fit . I messed a bit on the leading edge of the wing . It is a weird shape and I had troubles with the shape on getting it correct . Some trimming on the formers were need and is hidden which work out for in the end .
« Reply #47 on: April 13, 2021, 06:34:57 AM »
Have missed your recent progress on this one Alexis so I have just read through and caught up. How anyone can spand time adding all of that PE is beyond my understanding - even though it is adding much to the model. I just would not have the patience!
« Reply #48 on: April 13, 2021, 10:26:22 PM »
Hey Stephen ,
I don't have the Patience for most of it , I always lose one or two of the tiny parts and most of those now I won't use .
I don't understand why I use so much of it , it can be frustrating at times but I still have my sanity and my hair !
There is only more kit's like this in 32 scale which I have more then the kitchen sink tossed in . F4U-1A , P-51D and a P-51B . 48 Scale I have about 8 more projects that same , tons of PE and resin for them . All other kits will be built out of the box with the exception for some of my WW 1 kits which will get detail .
« Reply #49 on: April 16, 2021, 08:36:01 AM »
I think we all use It (PE) the same insane reasons with a touch self torture/pleasue.
« Reply #50 on: April 22, 2021, 11:33:27 AM »
Other than tons of sanding not much progress has been made , but the gun pods are sanded down as far as I can take them . Any thinner will cause me sand through the underside of them . Inside of the wings I still have a fair bit of thinning , but this stage is getting there . The wing panels covers are larger on the kit . The resin replacements are smaller so I will need to square off the cut out in the top wing . The covers do match the cutouts on the fuselage sides so no work needed there . I'm used to this with Aries resin , and I'm lucky I still have my hair ! , but they do have beautiful replacement sets .
« Reply #51 on: April 27, 2021, 12:25:32 AM »
You are really putting in a lot of work on this one Alexis. I am sure the results will be worth the effort!
« Reply #52 on: April 29, 2021, 10:09:28 AM »
Thanks Rick ,
I finally got the right side gun bay where it fits but I still have a bit of work on the wing cut out but that is just gluing another piece of plastic on the rear of the opening . I can more over to the left side but the cutting out the panel I will do this different so I don't have to box it in .
« Reply #53 on: April 30, 2021, 03:59:25 AM »
Some tricky cutting and fitting Alexis, but it is coming together well.
« Reply #54 on: May 01, 2021, 01:58:12 AM »
Agreed!  This should look great when done, Alexis.
« Reply #55 on: May 09, 2021, 08:13:14 AM »
Hi Stephen and Dave , thank you so much for following still !
More time was spent on the left side and by george I think she's git it !!! This was a heck of a lot of sanding on getting these to fit . The plastic is so thin in some areas just a sneeze is enough to cause damage . Little more work on the top part of the wings . I over sanded on the right side cut cut out and need to add another stripe of card stock . Smoothing and blending this in better will get done when rest of the seems get filled and I will have to scribe new panel lines . Few more PE parts I need to add on to the fire wall then it is off to painting the interior parts and a bit of assembly . Once this stage is reached it's landing flaps and upper guns !
« Reply #56 on: May 09, 2021, 08:13:41 AM »
« Reply #57 on: May 09, 2021, 10:17:29 PM »
That is a lot of work but will be worth it in the end! Nice progress Alexis!
« Reply #58 on: May 10, 2021, 03:59:42 AM »
This one reads as though it is a bit more than a walk in the park.... However with all the sanding and scraping it is shaping into a really interesting looking model. Keep at it Alexis - you are winning!
« Reply #59 on: May 10, 2021, 08:30:39 PM »
Thanks Rick and Stephen . Bit more tweaking was done for a better fit and just need to fill the half circle on the left side of the top wing . Rest of the resin parts are added to the gun pods and the front of the fire wall is done . Today I will start getting the base colours are and maybe a jump on the detail painting . Will have some progress photo's later today .
Hi Stephen , yeah it is more than a walk in park ...it's a hike up the mountain !
