Author Topic: Eduard’s Udet’s Trio ‘Du Noch Nicht!!’ 1/48 *Picture  (Read 20500 times)
Re: Eduard’s Udet’s Trio ‘Du Noch Nicht!!’ 1/48
« Reply #30 on: February 04, 2021, 06:10:17 PM »
The Fokkers are so eyecatching and also straightforward kits. But with my many open, unfinished builds I have very little if anything to say...  ;D ;D ;D
« Reply #31 on: February 04, 2021, 11:00:57 PM »
D.7 ....nuff said  :)
« Reply #32 on: February 05, 2021, 12:44:33 AM »
Hi,
Your wish is my command Alexis  :D D.VII it is.
I’ve actually made a start! Whatever next  ;D
I thought I’d ordered the Aviattic lozenge for the Fokker, but I seem to have the Albatross lozenge instead - which is a slight pain as I’m planning on a non lozenge Albatros! Don’t know how I got mixed up on that. I may order the D.VII one as well, unless anyone wants a swop? Faded. I just opened up the boxing properly to have a pre look, but ended up sticking some wings together.
The boxing comes with a (rather lovely) seated resin Mr. Udet, specifically for the D.VII and if you choose to use him, there’s a slightly different resin cockpit layout to use also. So although he goes in post build you do need to commit to which option pre build. He’s so nice I’m leaning towards using him?
Anyway, the kit looks really nice. Coloured PE, wheel masks, extensive (really) decal sheet (2 Udet options) with not bad lozenge. Anyone built one?
I think I’m building the red fuselaged one but probably not the candy stripe wing - maybe this one:
As always, any input most welcome.
« Reply #33 on: February 06, 2021, 12:40:25 AM »
Nice start. That figure looks awesome! Too bad no one does a decent Udet in 1/32nd scale  :-[ I am looking forward to your further progress!
« Last Edit: February 06, 2021, 12:46:57 AM by RAGIII »
« Reply #34 on: February 06, 2021, 02:45:42 AM »
Hi Guy!
Great to see some progress, but I hope it won't stop you from finishing the kitchen. We've lived in our house for 18 years but there are some (some would say a lot) of finishing touches left undone still... Maybe this summer?!
Great choice of livery and everything can be painted if you want to. But then again there is that problem of masking on top of the lozenge.
Looking forward to the rest!
« Reply #35 on: February 06, 2021, 03:06:45 AM »
See how easy life is when you listen to the Woman  ;)
Progress is progress no matter how slow it many seem , before long you will be back into the swing of building and will be turning them out at a fast pace  :)
« Reply #36 on: February 06, 2021, 05:28:49 AM »
Ah thanks Rick  ;)
Frederick, yes, but I’m not going to risk masking on lozenge! I’ve tried that before.... I can still mask the fuselage though...  ;D
Alexis, yes excellent advice!  ;D I wish I’d learned that earlier in life  ???
So I’m having lots of fun already (I really did miss my modelling). The lozenged version of the red fuselaged LO! seems to have had the engine cowlings removed. I was going to go for a simple as possible build, but I do really like this look so I’ve tried my hand at a little surgery... I think it will look quite cool and it might be possible to put the engine in after the main building/ painting process which could be an advantage.
« Reply #37 on: February 06, 2021, 05:40:11 AM »
Nice clean work on removing the panels! You are moving right along with this one  8)
« Reply #38 on: February 06, 2021, 04:43:38 PM »
Quote
I think that is the sane option! It is good to learn from experience,. I should try that myself some day... 🤪
Good job on the removal of the engine panels.
« Reply #39 on: February 06, 2021, 06:56:18 PM »
Morning all,
I’m suddenly a bit confused...  ???
Is the candy stripe wing the same aircraft as the Wingnut Wings camouflaged wing? ie 4253/18? I assumed it was.. but the Eduard boxing has the low exhausts poking out of the central hole in the cowling, whereas the WW instructions show a high mounted (standard) exhaust?
As you may know, I’m not one to be that bothered by total accuracy as long as it looks right! I’d much rather see a beautifully finished model than a ‘correct’ lesser model, I realise you can do both of course!  :P
« Reply #40 on: February 08, 2021, 02:00:39 AM »
Afternoon all,
A progress update!
I’m quite enjoying 1/48 for a change, big enough to have a bit of detail but small enough that you don’t need to go crazy (unless your name’s Frank). Although, as is my modus operandi - I’ve not added anything at all to the cockpit - The resin figure will all but obliterate any views inside. So out of the box:
It all went together very nicely.
As far as I can tell the camouflaged and striped wing are the same aircraft? Although I’ve seen the striped wing one labelled as a Fokker and Eduard have it as an OAW versioned D.VII?
« Reply #41 on: February 08, 2021, 02:16:01 AM »
Morning all,
Not the same aircraft Guy. The Candy striped wing was either Early Fokker or OAW built, depending on what sources you want to believe. It would have had the downward exhaust either way. The other was a later BMW engined Fokker built bird. IHTH,
PS: Your interior is looking Fantastic!
« Reply #42 on: February 08, 2021, 06:10:42 AM »
Ah, Rick, that now all makes sense. I think I just made a subconscious assumption that it was the same aircraft with a different wing. Doh.
That puts a bit of a spanner in the works as I’ve now ordered the Aviattic lozenge. So I either now do the candy stripe/ pretend I hadn’t noticed/ use the higher standard exhaust and hope it passes of as an ‘F’/ do a totally different scheme...  :P
Was it only his aircraft that had a red fuselage or would it have been Staffel wide?
Chastened Guy
« Reply #43 on: February 08, 2021, 06:16:22 AM »
Chastened Guy
Only Udet  and perhaps Heinz Dreckman. If it were My Model I would just do 4253 with standard exhaust and call it good. I do think Roden did a BMW engine so perhaps someone has a spare? If not just dare anyone to notice  ::)
« Reply #44 on: February 08, 2021, 10:57:00 PM »
A superbly clean interior, Guy.  Realistic wood grain on the cockpit floor.  Well done.
