Author Topic: Toms Model Works Pfalz D.VII/III  (Read 59293 times)
Re: Toms Model Works Pfalz D.VII/III
« Reply #45 on: November 21, 2020, 10:31:18 AM »
Up-date starts on the end of page 3
« Reply #46 on: November 23, 2020, 12:23:01 PM »
Got the seat support installed and the ammo bin which was made out of scraps of card . Not the greatest but most of it will not be seen and it fits ! Some of the smaller items are painted and pretty much ready to go . The seat belts are recycled from a trashed Pfalz D.IIIa build . I still have have the control column to make which I will work on next . Wood parts have their base coat on and set for the grain effect and clear coating . Couple small details need to be work out ,but I'm actually enjoying this so far  :) Few more days I should have the cockpit finished up .
« Reply #47 on: November 23, 2020, 12:23:24 PM »
Offline Radarman
« Reply #48 on: November 23, 2020, 03:41:33 PM »
Looks like another day of well spent bench time, Terri.
Keep the updates coming, they’re very enjoyable.
                                                       Kevin
Offline ermeio
« Reply #49 on: November 23, 2020, 05:55:44 PM »
Excellent results, Terri!
« Reply #50 on: November 23, 2020, 11:38:50 PM »
Thanks Kevin and Ermeio  :)
« Reply #51 on: November 24, 2020, 12:20:35 AM »
and so it begins! Looking Great to Date Terri!
Offline Brian James Riedel
« Reply #52 on: November 24, 2020, 03:33:51 AM »
Awesome!  I am doubly interested in this build as I have just won an eBay auction of the kit yesterday! It is the second boxing ( green plane) and it comes with decals for Paul Baumer! Now I can do Baumer’s plane!
If only Wingnuts could have done one in 1/32.
Keep up the great work!
Brian Riedel
« Reply #53 on: November 24, 2020, 06:00:41 AM »
Thanks Rick and Brian  :)
Cool , good for you Brian , hope that you got it for a fair price for being a very , very hard kit to find . I would love to see this in 32 scale even a new tooled 48 scale would be a warm welcome .
« Reply #54 on: November 26, 2020, 11:26:23 AM »
Bit more progress on this little bugger . Start making up the control column and still have a few more details to add and while doing a bit of clean up I found a PE seat back which works better then the resin one from the parts bins . Just have to cut a new base for it . Little bigger then what I'm using now , but smaller then an Albatros seat . So this made my day ! I can almost start laying done some colours once the column is finished .
« Reply #55 on: November 26, 2020, 11:26:48 AM »
« Reply #56 on: November 27, 2020, 12:55:33 AM »
The seat should coe out Fantastic Terri. Also the control column is looking great!
« Reply #57 on: November 27, 2020, 06:14:35 AM »
Thanks Rick  :) Almost have the column done  ;)
« Reply #58 on: November 28, 2020, 12:01:55 PM »
I started off finishing the control column . A few cables for the guns will get added once it is fixed in place for good . Since I had the airbrush out I made a start on the paint as well . Ammo bin and the power planet got bathed in black and while I was at it . The seat and side panels have the first step for wood effects . Still need to make a cushion  ::)
For the inside of the fuselage I made my own mix for the pale blue grey . For this I used Tamiya J.N. Grey with Tamiya light blue . Not sure on the ratios though , just kept adding the blue until I was happy .
« Reply #59 on: November 28, 2020, 12:02:21 PM »
