Author Topic: Meng and Roden Fokker DR1: Jasta 4, Jasta 6, and Jasta 11  (Read 153157 times)
« Reply #45 on: September 28, 2020, 06:57:17 AM »
More progress:
and the Roden kit: I see from the photo I have some touch up needed on the frame. I went with Valejo German Dark Grey instead of black to reduce the starkness.
« Last Edit: September 28, 2020, 07:11:50 AM by RAGIII »
« Reply #46 on: September 28, 2020, 08:38:21 AM »
Framing looks good in place on both .  :) The redbrown and black are starting to grow on me ,,,, :o
Offline Europapete
« Reply #47 on: September 28, 2020, 08:42:25 AM »
Looking great Rick! I kinda like the new red/black theory, nice color palette. Regards, Pete in RI
« Reply #48 on: September 28, 2020, 09:39:34 AM »
The framing is not glued on either kit but thanks, I think they are looking pretty good.
Thanks. I kind of like the"New" look myself.
« Reply #49 on: September 29, 2020, 05:23:22 PM »
Nice, Rick!  Your multi-builds are very impressive!  Wish I had your stamina.
« Reply #50 on: September 29, 2020, 10:54:35 PM »
Thanks Gaz!
« Reply #51 on: September 30, 2020, 12:31:09 AM »
Nice paint, Rick.
Do I understand correctly that the Dr.1s have that huge T handle on the right side of the cockpit for the pump to pressurize the fuel tank?
Any pictures of the real thing you can post?
« Reply #52 on: September 30, 2020, 01:22:54 AM »
Nice paint, Rick.
I don't think it is a "Pump' to pressurize. My understanding is the  Cross member forming the T is actually a valve handle. It was connected to the throttle and or could be operated manually, and also used like a blip switch. There was a Video on FB a few weeks ago showing it in operation on one of the Replicas. I know it is visible in the photo of the crash of 591/17. I will check for more images. By the way, I think the one in the kit is somewhat oversized but I am not going to change it on this one  8) IIRC there was no need for a Pressurization pump like on Mercedes and other inline engine powered aircraft. (I honestly don't remember why)
PS: Here is a Link to Lloyds Fokker DR1 website showing the aforementioned 591/17
http://www.fokkerdr1.com/images/Dr1-591-17%20crach.jpg
PPS: Looking at the photo again, I am Very Tempted to cut away what is supplied in the kit and replace with My own  ::)
« Last Edit: September 30, 2020, 05:30:52 AM by RAGIII »
« Reply #53 on: September 30, 2020, 05:59:38 AM »
I'm also impressed by your multitude of multiple builds. I find that I sometimes lose focus and make silly mistakes when building several models at the same time, but you just cruise through them it seems.
Cheers Fredrik
« Reply #54 on: September 30, 2020, 11:24:02 AM »
Cheers Fredrik
Thanks Fredrik! I do Make silly/simple mistakes! I was not satisfied with the bulkhead using the PE part from Part PE... ::) I had a surplus bulkhead from an old kit so I proceeded to do it myself with stitching from wire. I added a lot of oil weathering as this one represents a former Jasta 11 bird handed down to Jasta 4. THe New one is on the right of the photo.
and just the two I will use: Meng and Roden Modified:Touch up required  :(
« Last Edit: September 30, 2020, 11:28:46 AM by RAGIII »
« Reply #55 on: September 30, 2020, 04:35:08 PM »
Nicely done, Rick!
vB  :)
« Reply #56 on: September 30, 2020, 11:24:53 PM »
Nicely done, Rick!
vB  :)
Thanks Bob. I hope to get a lot more done today  8)
« Reply #57 on: October 01, 2020, 04:13:09 AM »
Does make for a nice contrast!
Offline jeroen_R90S
« Reply #58 on: October 01, 2020, 06:02:56 AM »
Looks good!
Thanks also for new picture of the Roden rudder on the drawing, I think I'll sand the attachment part at a slight angle to even out the incorrect looking curves on the forward and lower parts and live with it. Thanks again, I noted this in my instructions when I get to mine one day...
Jeroen
« Reply #59 on: October 01, 2020, 08:25:56 AM »
[/quote]
[/quote]
Yes it does Amigo. Not 100% convinced as to accuracy. My Only real misgiving is that Many serious researchers viewed the photos that Richard Alexander viewed and none seem to have come to the conclusion of red primer. Of course there May be More I don't know about. As Ray Rimell seems to be on board with the conclusion I figured I would roll with it  8)
Looks good!
Jeroen
Thanks Jeroen! Yes if using the kit rudder an angled cut will help. Perhaps why I originally lined things up the way I did.
« Last Edit: October 01, 2020, 10:55:09 PM by RAGIII »
