Author Topic: AMC DH.9a (1/32,Wingnut Wings)  (Read 23094 times)
Re: AMC DH.9a (1/32,Wingnut Wings)
« Reply #45 on: August 21, 2020, 01:58:23 AM »
The wheels... :)
« Reply #46 on: August 21, 2020, 02:50:01 AM »
Excellent wheels.  You nailed the tire tyre color perfectly!
« Reply #47 on: August 21, 2020, 02:50:26 AM »
The engine and wood look fantastic Prez. I am interested in the wheels as I am using Gaspatch wheels on my project. Both look very good but I am a little puzzled by the blue colour of the tyres.
« Reply #48 on: August 21, 2020, 02:54:29 AM »
Thanks!
The photos are taken in rush with my phone, which has problems with WB. These are usual WNW grey plastic tyres painted in dark grey.
« Reply #49 on: August 21, 2020, 02:18:46 PM »
Whoa Przemo!  Those wheels are beauties!
« Reply #50 on: August 21, 2020, 09:21:11 PM »
Excellent job on getting the wheels together . I would have made a mess out of the PE spokes .
« Reply #51 on: August 21, 2020, 11:13:19 PM »
excellent work on the wheels! I tried PE spokes a couple of times and met with disaster. You are a Master!
« Reply #52 on: August 23, 2020, 06:14:46 AM »
Thank you, everyone.
Rick, I am sure you would do well with these, the key to the success is that axle hub which centres it all and facilitates the assembly. Great design from Rowan!
And here a few more steps
The fuselage joints are finally cured. I have also added the PE side steps. Also some fitting of the PE generator support revealed that the rear hole is mislocated - I had to fill it (the white spot).
I did not quite like the way to lead the control lines for the ailerons as designed by WNW. So I decided to remove the plastic imitation of turnbuckles and the cable from the control horns and replaced them with Gaspatch bits. Thus I will have a chance to lead the cables from the openinigs in the wings through the holes drilled in the horn tips to the eyelets in the turnbuckles.
« Reply #53 on: August 23, 2020, 06:21:34 AM »
Lovely Prze,
Wheels, fuselage, PE, the whole bally lot!
« Reply #54 on: August 23, 2020, 07:56:06 AM »
Impressive work as always, Prze!
Offline Early Bird Fan
« Reply #55 on: August 23, 2020, 04:16:11 PM »
that's gone together rather nicely and the pe parts look great
Offline fredjocko
« Reply #56 on: August 24, 2020, 11:28:36 PM »
That is very nice. I really like the wheels.
« Reply #57 on: August 25, 2020, 02:30:29 AM »
Impressive work on the PE and those control turnbuckles!
« Reply #58 on: August 25, 2020, 12:27:19 PM »
« Reply #59 on: August 25, 2020, 06:18:19 PM »
Love the PE bits!
