Author Topic: AMC DH.9a (1/32,Wingnut Wings)  (Read 23293 times)
Re: AMC DH.9a (1/32,Wingnut Wings)
« Reply #60 on: August 29, 2020, 12:28:52 AM »
Thank you again.
More preparations:
1) well over 120 eyelets installed and tested for pull-out
2) turnbuckles for control lines installed or prepared
3) exhaoust outlets drilled out
4) control surfaces hinged connections reinforced with wire bits
5) gun ring assembled
6) engine cowls which will be set aside the model - with removed assembly bits and thinned down
« Reply #61 on: August 29, 2020, 03:57:52 PM »
Nice!!
« Reply #62 on: August 29, 2020, 09:21:04 PM »
Everything is looking great. That is a LOT of Eyelets  8)
« Reply #63 on: August 30, 2020, 12:10:10 AM »
Nice clean work, Przemol, but that is your style.
Offline Jammed Vickers
« Reply #64 on: September 02, 2020, 07:35:04 AM »
That's beautiful work.
Wayne
"Courage is doing what you're afraid to do.  There can be no courage unless you're scared."
Capt. Eddie Rickenbacker, 94th Pursuit Squadron, AEF
Offline smperry
« Reply #65 on: September 02, 2020, 08:06:42 AM »
Przemol
That is brilliant using the turnbuckles to wind the anchors. I intend to copy that where it is appropriate on my future builds. Once you see it, it's obvious, but I doubt I would have thought of it. Thanks for sharing, it will help.
sp
« Reply #66 on: September 03, 2020, 06:36:11 AM »
Finally some play with colours!
Offline smperry
« Reply #67 on: September 03, 2020, 07:05:08 AM »
So incredibly neat. You really set the bar high Przemol
sp
« Reply #68 on: September 03, 2020, 09:31:15 AM »
I really like that shade of red !
« Reply #69 on: September 03, 2020, 09:56:35 AM »
As always your painting is neat and clean. Looking Fantastic
« Reply #70 on: September 03, 2020, 09:20:51 PM »
Looking good! I like the masked numbers. What kind of masking material do you use?
Cheers Fredrik
« Reply #71 on: September 04, 2020, 05:09:57 AM »
Great work, all the substituted, exquisite details make your DH.9 really gorgeous!
« Reply #72 on: September 04, 2020, 06:56:10 AM »
Thank you, everyone.
Cheers Fredrik
I am sorry, I do not know, these masks were custom made but not self made. Still, the material looks quite ordinary, like the other masks I used up till now.
« Reply #73 on: September 04, 2020, 04:00:19 PM »
No problem, just curious but not really needing to know. Thanks for your answer anyway.
« Reply #74 on: September 04, 2020, 09:30:05 PM »
It looks like ORAMASK 810, which I also use for my cutter.
I was told to not use ORAMASK 810S, it can be applied wet, but the glue is solvent based. So it may be aggressive to our paints.
PrzemoL, nice work!
