Author Topic: CSM Pfalz Dr.1  (Read 37631 times)
Re: CSM Pfalz Dr.1
« Reply #45 on: July 24, 2020, 10:15:01 AM »
Thanks guys !  :)
Gary , yes I do wear mask when sanding resin and some times when scraping depending on the type of resin . Some is very hard while other is more like a bar of soap . In that case I when a mask .
Rick , it is still going to while before this one is button up , still lots and lots to do , but I'm getting there . With more rain in our forecast for the weekend it looks like I will be getting a bit more time at the bench .
Offline fredjocko
Re: CSM Pfalz Dr.1
« Reply #46 on: July 25, 2020, 11:29:26 AM »
That looks amazing and 1/48 scale as well!!
Re: CSM Pfalz Dr.1
« Reply #47 on: July 26, 2020, 08:25:09 AM »
Thanks Carl , will another up-date some time today or tomorrow  :)
Re: CSM Pfalz Dr.1
« Reply #48 on: July 26, 2020, 06:29:39 PM »
I'm looking forward to that update Terri. :)
Re: CSM Pfalz Dr.1
« Reply #49 on: July 27, 2020, 04:35:28 AM »
Work continues at a slow pace or it may seem , but this was a few hours well spent . I made a new floor for the old one was now to small . I re-installed the carb air intakes and now I know why my measurements were way off so may years ago . ( I had them installed the wrong way  ::) ) . The strap on the furl and oil tank is fashioned out of left off PE seat belt buckle and tamiya tape . I also made another ammo bin . Rudder bar is a Toms Model Works from their German PE set . I added a nut with a pin making it easier to mount later on . I did build up the surface with super glue a bit so it doesn't look so flat . A bit of primer will tell me if I need more . Rest of the framing is added to the left side . And this is where I'm at now . Still a fair bit of details left , control column , rest of the instruments and other details , but the frame is getting close to painting . I also had a little help on keeping my chair warm  :)
Re: CSM Pfalz Dr.1
« Reply #50 on: July 27, 2020, 04:35:52 AM »
Re: CSM Pfalz Dr.1
« Reply #51 on: July 27, 2020, 04:36:21 AM »
 :) Sorry about the crappy looking pic
Re: CSM Pfalz Dr.1
« Reply #52 on: July 27, 2020, 05:21:35 AM »
Apologies for absence Terri - I have been away from home again and am still trying to catch up with things (including my own project!) The frame and addition which you have made are strikingly good - with the new engine which you are proposing to put in this should be another of your winners.
Re: CSM Pfalz Dr.1
« Reply #53 on: July 27, 2020, 07:07:48 AM »
Looking Awsome Terri!
Re: CSM Pfalz Dr.1
« Reply #54 on: July 27, 2020, 07:19:46 AM »
Love the ammo box with its strap. That's a properly grumpy looking cat. I had a Siamese who looked really fierce but was the most placid cat ever. I still miss him 20 years later.
Re: CSM Pfalz Dr.1
« Reply #55 on: July 27, 2020, 10:18:33 AM »
Stephen , it is what is and no reason to apologies .  ;) Follow when you can . So far the build is going well and once the pit is finished the rest should good a little quicker .
Thanks Rick  :)
Richie , the ammo box doesn't have a strap . Those are the fuel and oil tank . Yeah he his grumpy . I poked him for the photo op , waking him from his nap .
Bit more progress , new tail feathers have been cut and sanded to shape so far . And that is all for this weekend .
Re: CSM Pfalz Dr.1
« Reply #56 on: July 28, 2020, 04:13:12 AM »
LOL, I'm not much of an engineer Terri, the FUEL and Oil tanks look great with strap. Great tail feathers too. 👏
Re: CSM Pfalz Dr.1
« Reply #57 on: July 28, 2020, 04:44:26 AM »
The tail feathers look great Terri!
Re: CSM Pfalz Dr.1
« Reply #58 on: July 28, 2020, 07:36:00 AM »
I'm impressed with the level of detail you're going to, Terri!
Re: CSM Pfalz Dr.1
« Reply #59 on: July 28, 2020, 11:10:22 AM »
Thank-you very kindly guys . Will be able to get some bench time in through out the week so should be interesting on turns up with progress .
Gary , I'm just getting start  ;)
