Author Topic: CSM Pfalz Dr.1  (Read 37264 times)
Re: CSM Pfalz Dr.1
« Reply #255 on: September 21, 2020, 11:51:28 PM »
Looking great...again  8)
Re: CSM Pfalz Dr.1
« Reply #256 on: September 22, 2020, 09:50:25 AM »
Thanks Ken and Rick , should be able to start with the decaling soon .
Offline jeroen_R90S
Re: CSM Pfalz Dr.1
« Reply #257 on: September 22, 2020, 04:40:36 PM »
Keep at it, I'm sure it's going to look good, and definately one not too many will have on their shelves I suppose. Your trials remind of my Corona-Corsairs, where I had to keep sanding, filling and fiddling for an eternity -even after they were painted. Keep it up :)
Re: CSM Pfalz Dr.1
« Reply #258 on: September 22, 2020, 07:33:34 PM »
Amazing tenacity, Terri! Obviously you won't be beaten by this or any other kit!
Re: CSM Pfalz Dr.1
« Reply #259 on: September 22, 2020, 09:48:28 PM »
Thanks Jeroen and Fredrik , I will keep at it taking steps forward and get her done . I started with the decaling last night and have the left side done . Right side will get applied this evening and hoping by the weekend I can start with the assembly .
Re: CSM Pfalz Dr.1
« Reply #260 on: September 23, 2020, 11:25:51 AM »
Hurra ! Decals are on ...well for the most part . Still have the tamdum lines but before I do that I took the time to remove the fire wall and re-enforce the inside along the top seem and where the cab struts fit . With the resin being so damn thin now I'm hot sure how long this will hold up . So here is to hoping on that . I do have too added 2mm to the front on the fuselage after removing the cowl for repaint as well .Super glue can be a bitch to clean ! This is a quick fit and will be easy on blending this in , but I  feel more comfortable knowing that it has added strength now .
Re: CSM Pfalz Dr.1
« Reply #261 on: September 23, 2020, 11:26:17 AM »
Re: CSM Pfalz Dr.1
« Reply #262 on: September 23, 2020, 11:32:56 AM »
Outstanding recovery on the whole thing Terri! The markings look great!
Re: CSM Pfalz Dr.1
« Reply #263 on: September 23, 2020, 04:31:05 PM »
Keep going, Terri!
You're doing great  ;)
vB
Offline Radarman
Re: CSM Pfalz Dr.1
« Reply #264 on: September 23, 2020, 10:28:44 PM »
Terri,
Great to see this is back on track.
                                         Kevin
Re: CSM Pfalz Dr.1
« Reply #265 on: September 24, 2020, 11:52:01 AM »
Thanks you guys for the continuing support , you folks are awesome ! :)
Tonight I worked on the new fire wall and had to change the way the engine mounts . Bot that is okay , this won't be seen away and will also add extra support on the nose of this beast . The seem has been putty and this needs to dry overnight and if things go well sanding , priming and painting will be done tomorrow . I didn't notice this before until the last round of pic's I posted and have address that as well . Behind the right stabilizer there was a dip from a file while fitting the stabs .
Re: CSM Pfalz Dr.1
« Reply #266 on: September 24, 2020, 11:55:32 AM »
Oh-yeah ...feels like I took a few steps forward  ;D ;D ;D
Terri , one happy lady  :)
Re: CSM Pfalz Dr.1
« Reply #267 on: September 24, 2020, 10:42:41 PM »
I am still amazed at your steadfast determination to get this one done... and done correctly! Lets hope you are now only going to go forward Terri!
Re: CSM Pfalz Dr.1
« Reply #268 on: September 25, 2020, 11:08:15 AM »
Thanks Rick , but I don't think the rest will be smooth sailing . However ; I do feel that the worst is over and I will not be doing any more filling or sanding . I have had my fill on that . Everything lines up now that is good and shouldn't have anymore issue in on finally assembly .
Other then a clear coat and two more decals to go which will be tomorrows evenings goal I'm back on track and can finally continue with the rigging and mounting the middle wings .
Ta...da !
Re: CSM Pfalz Dr.1
« Reply #269 on: September 25, 2020, 11:18:43 AM »
Looks fantastic Terri. No one could tell you had any issues at all
