Author Topic: 1:32nd scale Siemens-Schuckert D.III (Early)  (Read 26270 times)
Re: 1:32nd scale Siemens-Schuckert D.III (Early)
« Reply #60 on: June 10, 2020, 07:49:19 AM »
Just catching up with this one. The aileron control rods are amazing and I love the milliput padding and seat back. Inspiring stuff as always.
« Reply #61 on: June 10, 2020, 04:06:19 PM »
I really like the padding at the rear of the upper wing!
« Reply #62 on: June 10, 2020, 09:48:01 PM »
Great detail work, Mike.
« Reply #63 on: June 11, 2020, 02:51:49 AM »
The top decking panel has its photo-etch panels fitted (the quarter turn fasteners will be fitted later).
I'd previously fitted photo-etch hinges to the panel, however the 'Brengun' photo-etch panels include these hinges.
Also the tail skid support brackets are fitted.
Well, I thought I'd covered all the necessary changes before starting the build.
However I've found other changes that need to be done.
The right fuselage half from the kit has a scooped vent, which was not fitted to the early D.III, so that was removed and filled.
That allowed me to fit the two photo-etch side access panels, which again are different in desin from those fitted to the later D.III.
The kit fuselage halves are missing a panel join at fuselage former E - this needs to be scribbed onto the fuselage halves.
The underside vented panel is different from the later D.III, which had two scooped vents fitted. The early D.II had no vents, but an access panel was fitted.
This means the photo-etch panel supplied with the 'Brengun' set is not correct for this model, so I'll probably modify the kit panel.
The left fuselage half from the kit has a poorly moulded pilot's foot step, which in reality was a retractable to close off when not in use.
The kit location for the foot step is incorrect as it's too high above the lower wing root. I'll fill this foot step and create a new one.
Apart from that it's plain sailing so far!!!
« Reply #64 on: June 11, 2020, 08:09:34 AM »
As always your PE and Mods are looking Spectacular. Your attention to detail is second to none!
Offline Dave Brewer
« Reply #65 on: June 11, 2020, 10:12:58 AM »
As always Mike,a fascinating and educational build,I'm glad I haven't started on my DIII yet,I'll be able to do a much better job with your "construction manual" to follow.
Dave.
« Reply #66 on: June 11, 2020, 10:25:13 AM »
Reaallly coming along wonderful Mike  :)
« Reply #67 on: June 11, 2020, 04:04:14 PM »
Love it!
« Reply #68 on: June 12, 2020, 02:29:22 AM »
Lovely attention to detail, Mike! This is inspirational stuff! I will be watching closely... Regards, Marc.
« Reply #69 on: June 12, 2020, 03:16:30 AM »
I've used the kit under panel and opened up the louvre vents and added the panels retaining screw and louvre rivet locations.
Unfortunately the required rectangular access panel needs to be position smack over the join between the rear edge of the panel (when fitted) and forward edge of the lower wing.
Therefore I'll not be able to create that panel until later in the build.
Also filled the original pilot's foot step and created a new one in the correct position.
Finally added the missing panel line at the fuselage former.
« Last Edit: June 12, 2020, 03:36:37 AM by Mike 'Sandbagger' Norris »
« Reply #70 on: June 12, 2020, 04:41:05 AM »
I am surprised at the excellence of your work.... No Not really, Magnificent as always Mike!
« Reply #71 on: June 12, 2020, 10:38:54 AM »
Excellent work on the chin Mike  :)
« Reply #72 on: June 12, 2020, 04:37:00 PM »
Awesome.
« Reply #73 on: June 12, 2020, 09:51:55 PM »
You are certainly nailing down the details.  Good references help that greatly!
« Reply #74 on: June 13, 2020, 09:24:27 AM »
Open louvres look so much better!
