Author Topic: 1/32 Handley Page V/1500 scratch build (slowgress report)  (Read 80261 times)
Re: Handley Page V/1500 scratch build (slowgress report)
« Reply #180 on: November 21, 2022, 08:00:43 PM »
Fantastic update! I agree with all the above comments!
« Reply #181 on: December 15, 2022, 05:47:27 AM »
Magic work Willem! How neat to see the raw material transformed into small replicas of the original. Brilliant!
It doesn't matter how slow the progress, it looks like you are enjoying the project and every piece you have made so far is another perfect step towards the finished model.
Hear hear!
and another Hear  8)
Re: 1/32 Handley Page V/1500 scratch build (slowgress report)
« Reply #182 on: December 17, 2022, 01:54:57 AM »
Thanks for the compliments gentlemen!
I've since done some work on the cockpit floor, but time is limited due to work and preparations for the holidays with family coming over.
It will take a few weeks, but...
I'll be back.
« Reply #183 on: December 17, 2022, 09:00:15 AM »
Be back when you're ready Willem and not a second before. We all love what you are achieving here and you must never rush anything to post here. We all want to see the best of your magnificent best craftsmanship
« Reply #184 on: December 17, 2022, 10:04:12 AM »
I can only echo what Richie said. Your updates are always worth the wait and there's no need to rush on our account!
Offline kkarlsen
« Reply #185 on: December 18, 2022, 07:43:16 PM »
Just... WOW incredible build Willem.
Cheers: Kent
« Reply #186 on: December 22, 2022, 09:44:08 PM »
Amazing work so far! - that steering wheel is fantastic
« Reply #187 on: January 01, 2023, 01:33:35 AM »
Thanks for the kind comments Richie, Zac, Kent and Dave.
Work on the cockpit is in progress and there will be pictures in a couple of days.
I wish everyone a healthy, productive, happy and better New Year!
« Reply #188 on: January 01, 2023, 08:48:06 PM »
I had some wood left from a boatbuilding project (don't ask). These were meant for deck planking, but with a little fantasy and adjusting they can be used for the slats of the cockpit floor.
The seams are prescribed and so it is easy to cut very straight slats, single or doubled. They are of the right size and scale. Since the actual floor was made of wood, I thought I might give it a try and I am very happy with the results. I used simple PVA wood glue. The bottom is a little warped because in same places I used the glue a little too liberally, but that can be fixed easily.
The last slats are glued on and held down between two glass plates with weights on them. I will leave it to dry for at least 24 hours. After that I will trim off the excess wood.
My ToDo list for the coming weeks:
- building up of the vertical construction with the struts, the brace wires and the plywood sides.
- mapping out he position of the steering column, and the elevator and rudder controls, that protrude through the bottom and the pilot’s seat.
In the meantime I am also working on all the gauges, meters, tumbler switch boxes, pushbuttons and engine control levers that have to find a place in the crammed cockpit on the instrument panel and the sides.
I’ll be back.
« Last Edit: May 04, 2025, 10:35:06 PM by Rookie »
« Reply #189 on: January 01, 2023, 09:46:29 PM »
Now that was an update well worth waiting for! The use of wood from your boat project will really elevate this build to a much higher level. It must have been very satisfying to make the floor decking, it looks beautifully precise and you will soon have the very slight warp cured.
Happy new year!
Offline PJ Fisher
    • Aero Rarities
« Reply #190 on: January 02, 2023, 12:27:39 AM »
Where did you acquire your metal ruler? I need that!
« Reply #191 on: January 02, 2023, 01:40:51 AM »
PM sent
« Reply #192 on: January 03, 2023, 07:34:44 AM »
Beautiful wood work! Looks really neat!
« Reply #193 on: January 06, 2023, 09:41:45 AM »
Really Impressive work! That floor decking looks awesome! I am continuing to be Gobsmacked!
« Reply #194 on: January 06, 2023, 07:00:15 PM »
Thank you Fredik and Rick for your encouraging words  :)
It was time consuming but worth the trouble.
I am now working on a mockup of the cockpit to determine where everything goes, because I don't want to risk damaging anything I've made sofar.
An update will follow (after) this weekend.
