Author Topic: Special Hobby Lloyd C.V 1/48  (Read 38962 times)
Re: Special Hobby Lloyd C.V 1/48
« Reply #255 on: June 27, 2020, 05:04:59 PM »
Splendid, Terri!
« Reply #256 on: June 27, 2020, 10:23:39 PM »
A Real Beauty T! The Satin finish looks perfect to me!
« Reply #257 on: June 28, 2020, 12:40:07 AM »
That looks REALLY good, Terri.  Thanks for sharing this build.
Offline Radarman
« Reply #258 on: June 28, 2020, 12:51:59 AM »
Terri,
The wet weather may reduce the chance of wild fires this summer, but things are really on fire around your work bench.
This is one smoking' hot build!
                                                     Kevin
« Reply #259 on: June 28, 2020, 05:32:10 AM »
Super wood tones and finish on this one Terri. A wonderful set of builds going on in your area at the moment.
« Reply #260 on: June 28, 2020, 08:01:37 AM »
Thanks guys for the very kind comments , glad that you are enjoying the build as much as I am . I started the rigging with the control cables from the cockpit to the top wing and the only two on the right side so far . It was a few hours just making these turnbuckles , fare more amount to go , but I'm in no hurry .
« Reply #261 on: June 29, 2020, 01:59:22 AM »
This is proper modelling eye candy you are producing here Terri.
« Reply #262 on: June 29, 2020, 03:11:28 AM »
Super detailing there Terri.
« Reply #263 on: June 29, 2020, 04:00:18 AM »
Excellent update T!
« Reply #264 on: June 29, 2020, 05:57:16 AM »
With all the details in the macro shot the wood looks even better! What an amazing model 8)
« Reply #265 on: June 29, 2020, 08:59:33 AM »
Hi guys !
Not much more to report on the rigging but four lines are done while another four are set in place for stringing later . Before the tops wings get mounted I need to finish the weathering on the tail planes as well as the flight controls on the main wings . I totally missed this  ::) But I'm getting closer and closer on warping this one up !
Thanks for following along guys  ;)
« Reply #266 on: June 29, 2020, 08:59:59 AM »
« Reply #267 on: June 29, 2020, 09:00:23 AM »
« Reply #268 on: June 29, 2020, 04:34:35 PM »
Terri,
   Another great step in the right direction.
Gaz
« Reply #269 on: June 30, 2020, 09:31:43 AM »
Thanks Gary , It is very time consuming making the turn buckles . I'm out of 0.4mm brass tubing , 0.5mm is too big and it takes me a few tries on getting the right diameter from heat stretching q-tips . I also drop many ....many wire hoops when making them  ::)
